1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30
| Définition du pipeline à PAUSED...
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:rtpbin0: latency = 2000
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc1: timeout = 5000000
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc4: timeout = 5000000
Le pipeline est actif et n'a pas besoin de phase PREROLL...
Passage du pipeline à la phase PLAYING...
New clock: GstSystemClock
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc1: timeout = 0
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc4: timeout = 0
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0.GstGhostPad:recv_rtp_src_0_106139473_96: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)420033, sprop-parameter-sets=(string)\"Z0IAM+KQKDPz4C3AQEB4eJEV\\,aM48gA\\=\\=\", a-framerate=(string)2147483647.0, clock-base=(guint)844827517, seqnum-base=(guint)4768, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0.GstGhostPad:recv_rtp_src_0_106139473_96.GstProxyPad:proxypad8: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)420033, sprop-parameter-sets=(string)\"Z0IAM+KQKDPz4C3AQEB4eJEV\\,aM48gA\\=\\=\", a-framerate=(string)2147483647.0, clock-base=(guint)844827517, seqnum-base=(guint)4768, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:rtpbin0.GstGhostPad:recv_rtp_src_0_106139473_96.GstProxyPad:proxypad7: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)420033, sprop-parameter-sets=(string)\"Z0IAM+KQKDPz4C3AQEB4eJEV\\,aM48gA\\=\\=\", a-framerate=(string)2147483647.0, clock-base=(guint)844827517, seqnum-base=(guint)4768, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0.GstGhostPad:recv_rtp_src_1_3131727327_97: caps = application/x-rtp, media=(string)audio, payload=(int)97, clock-rate=(int)16000, encoding-name=(string)MPEG4-GENERIC, encoding-params=(string)1, profile-level-id=(string)15, mode=(string)AAC-hbr, config=(string)1408, sizelength=(string)13, indexlength=(string)3, indexdeltalength=(string)3, profile=(string)1, bitrate=(string)32000, clock-base=(guint)513587548, seqnum-base=(guint)56970, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0.GstGhostPad:recv_rtp_src_1_3131727327_97.GstProxyPad:proxypad10: caps = application/x-rtp, media=(string)audio, payload=(int)97, clock-rate=(int)16000, encoding-name=(string)MPEG4-GENERIC, encoding-params=(string)1, profile-level-id=(string)15, mode=(string)AAC-hbr, config=(string)1408, sizelength=(string)13, indexlength=(string)3, indexdeltalength=(string)3, profile=(string)1, bitrate=(string)32000, clock-base=(guint)513587548, seqnum-base=(guint)56970, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:rtpbin0.GstGhostPad:recv_rtp_src_1_3131727327_97.GstProxyPad:proxypad9: caps = application/x-rtp, media=(string)audio, payload=(int)97, clock-rate=(int)16000, encoding-name=(string)MPEG4-GENERIC, encoding-params=(string)1, profile-level-id=(string)15, mode=(string)AAC-hbr, config=(string)1408, sizelength=(string)13, indexlength=(string)3, indexdeltalength=(string)3, profile=(string)1, bitrate=(string)32000, clock-base=(guint)513587548, seqnum-base=(guint)56970, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
ERREUR*: de l'élément /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc4*: Erreur interne de flux de données.
Information de débogage supplémentaire*:
gstbasesrc.c(2507): gst_base_src_loop (): /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc4:
streaming task paused, reason not-linked (-1)
Execution ended after 236857515 ns.
Définition du pipeline à READY (prêt)...
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0.GstGhostPad:recv_rtp_src_1_3131727327_97: caps = NULL
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0.GstGhostPad:recv_rtp_src_0_106139473_96: caps = NULL
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:rtpbin0.GstGhostPad:recv_rtp_src_1_3131727327_97: caps = NULL
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:rtpbin0.GstGhostPad:recv_rtp_src_0_106139473_96: caps = NULL
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:rtpbin0/GstRtpPtDemux:rtpptdemux1.GstPad:src_97: caps = NULL
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:rtpbin0/GstRtpPtDemux:rtpptdemux0.GstPad:src_96: caps = NULL
Définition du pipeline à NULL...
Libération du pipeline... |
