1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57
package allocine;
* HelloWorldSwing.java requires no other files.
import java.awt.Color;
import java.io.IOException;
import javax.swing.*;
public class GraphVersion extends JFrame{
private static final long serialVersionUID = 1L;
* Create the GUI and show it. For thread safety,
* this method should be invoked from the
* event-dispatching thread.
* @throws IOException
public GraphVersion() throws IOException{
GetInfos g=new GetInfos("http://www.allocine.fr/film/fichefilm_gen_cfilm=56136.html");
StringBuffer sb=g.read_str();
JFrame frame = new JFrame(g.getTitle(sb).toString());
frame.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
Search s= new Search("http://www.allocine.fr/film/fichefilm_gen_cfilm=56136.html");
Color color= new Color(40,83,119);
frame.setBackground(color);
frame.setAlwaysOnTop(true);
String path=s.path;
String rel=g.getRelease(sb).toString();
JLabel release=new JLabel(rel);
JLabel label=new JLabel(path);
frame.getContentPane().add(label);
frame.getContentPane().add(release);
//Display the window.
frame.pack();/*Mettre à la taille optimale de la fenetre*/
frame.setVisible(true);/*mettre en visible */
public static void main(String[] args) throws IOException {
//Schedule a job for the event-dispatching thread:
//creating and showing this application's GUI.
new GraphVersion();
