1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80
| import java.io.*;
import java.util.*;
import javax.comm.*;
import com.sun.comm.Win32Driver;
public class SimpleRead implements Runnable, Seriai lPortEventListener {
static CommPortIdentifier portId;
static Enumeration portList;
InputStream inputStream;
SerialPort serialPort;
Thread readThread;
portList = CommPortIdentifier.getPortIdentifiers();
while (portList.hasMoreElements()) {
portId = (CommPortIdentifier) portList.nextElement();
if (portId.getPortType() == CommPortIdentifier.PORT_SERIAL) {
if (portId.getName().equals("COM1")) {
// if (portId.getName().equals("/dev/term/a")) {
SimpleRead reader = new SimpleRead();
public SimpleRead() {
try {
serialPort = (SerialPort) portId.open("SimpleReadApp", 2000);
} catch (PortInUseException e) {System.out.println(e);}
try {
inputStream = serialPort.getInputStream();
} catch (IOException e) {System.out.println(e);}
try {
serialPort.addEventListener(this);
} catch (TooManyListenersException e) {System.out.println(e);}
serialPort.notifyOnDataAvailable(true);
try {
serialPort.setSerialPortParams(9600,
SerialPort.DATABITS_8,
SerialPort.STOPBITS_1,
SerialPort.PARITY_NONE);
} catch (UnsupportedCommOperationException e) {System.out.println(e);}
readThread = new Thread(this);
readThread.start();
public void run() {
try {
Thread.sleep(10);
} catch (InterruptedException e) {System.out.println(e);}
public void serialEvent(SerialPortEvent event) {
switch(event.getEventType()) {
case SerialPortEvent.BI:
case SerialPortEvent.OE:
case SerialPortEvent.FE:
case SerialPortEvent.PE:
case SerialPortEvent.CD:
case SerialPortEvent.CTS:
case SerialPortEvent.DSR:
case SerialPortEvent.RI:
case SerialPortEvent.OUTPUT_BUFFER_EMPTY:
break;
case SerialPortEvent.DATA_AVAILABLE:
byte[] readBuffer = new byte[20];
try {
while (inputStream.available() > 0) {
int numBytes = inputStream.read(readBuffer);
System.out.print(new String(readBuffer));
break;
