1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
import java.awt.BorderLayout;
import java.awt.Color;
import java.awt.Dimension;
import java.awt.event.ActionEvent;
import java.awt.event.ActionListener;
import javax.swing.BorderFactory;
import javax.swing.JButton;
import javax.swing.JFrame;
import javax.swing.JLayeredPane;
import javax.swing.JPanel;
public class EssaiJLayeredPane {
public static void main(final String[] args) {
new EssaiJLayeredPane();
public EssaiJLayeredPane() {
JFrame frame = new EssaiFrame();
frame.setSize(new Dimension(320, 200));
frame.setLocation(100, 50);
frame.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
frame.setTitle(">>> ESSAI LAYERED PANE");
frame.setVisible(true);
static private class EssaiFrame extends JFrame {
private JLayeredPane contentPanel;
private JPanel panelDuDessous;
private JPanel panelDuDessus;
static private final Dimension C_PANEL_SIZE = new Dimension(250, 100);
public EssaiFrame() {
this.contentPanel = new JLayeredPane();
this.contentPanel.setLayout(null);
this.contentPanel.setOpaque(true);
this.setContentPane(this.contentPanel);
int layerIndex = 0;
this.contentPanel.add(this.getPanelDuDessous(), Integer.valueOf(++layerIndex));
this.contentPanel.add(this.getPanelDuDessus(), Integer.valueOf(++layerIndex));
private JPanel getPanelDuDessous() {
if (this.panelDuDessous == null) {
this.panelDuDessous = createPanel(C_PANEL_SIZE, Color.BLUE);
this.panelDuDessous.setLocation(10, 10);
JButton boutonDuPanelDuDessous = new JButton("Bouton du dessous");
boutonDuPanelDuDessous.addActionListener(new ActionListener() {
@Override
public void actionPerformed(final ActionEvent e) {
System.out.println("Clic sur bouton du dessous");
this.panelDuDessous.add(boutonDuPanelDuDessous, BorderLayout.EAST);
return this.panelDuDessous;
private JPanel getPanelDuDessus() {
if (this.panelDuDessus == null) {
this.panelDuDessus = createPanel(C_PANEL_SIZE, Color.ORANGE);
this.panelDuDessus.setLocation(50, 30);
JButton boutonDuPanelDuDessus = new JButton("Dessus");
boutonDuPanelDuDessus.addActionListener(new ActionListener() {
@Override
System.out.println("Clic sur bouton du dessus");
this.panelDuDessus.add(boutonDuPanelDuDessus, BorderLayout.EAST);
return this.panelDuDessus;
private JPanel createPanel(final Dimension size, final Color bg) {
JPanel panel = new JPanel();
panel.setLayout(new BorderLayout());
panel.setOpaque(true);
panel.setBackground(bg);
panel.setSize(size);
panel.setBorder(BorderFactory.createLineBorder(Color.BLACK, 2));
return panel;
