Y a t il possibilité de stocker dans une liste déroulante la liste des imprimantes disponibles ?
Regarde à cette adresse
http://www.developpez.net/forums/viewtopic.php?t=434470
Si ça ne va pas, tu dis
A+
le code dans le lien ci-dessu est très imcomplet et mal fichu :
Je vous livre un mixage de 2 exemples de AllAPI.net :
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171 Private Const CCHDEVICENAME = 32 Private Const CCHFORMNAME = 32 Private Type DEVMODE dmDeviceName As String * CCHDEVICENAME dmSpecVersion As Integer dmDriverVersion As Integer dmSize As Integer dmDriverExtra As Integer dmFields As Long dmOrientation As Integer dmPaperSize As Integer dmPaperLength As Integer dmPaperWidth As Integer dmScale As Integer dmCopies As Integer dmDefaultSource As Integer dmPrintQuality As Integer dmColor As Integer dmDuplex As Integer dmYResolution As Integer dmTTOption As Integer dmCollate As Integer dmFormName As String * CCHFORMNAME dmUnusedPadding As Integer dmBitsPerPel As Integer dmPelsWidth As Long dmPelsHeight As Long dmDisplayFlags As Long dmDisplayFrequency As Long End Type Private Type PRINTER_INFO_1 flags As Long pDescription As String pName As String pComment As String End Type Private Type PRINTER_INFO_2 pServerName As String pPrinterName As String pShareName As String pPortName As String pDriverName As String pComment As String pLocation As String pDevMode As Long pSepFile As String pPrintProcessor As String pDatatype As String pParameters As String pSecurityDescriptor As Long Attributes As Long Priority As Long DefaultPriority As Long StartTime As Long UntilTime As Long Status As Long JobsCount As Long AveragePPM As Long End Type Private Type PRINTER_DEFAULTS pDatatype As String pDevMode As DEVMODE DesiredAccess As Long End Type Private Declare Function lstrcpy Lib "kernel32.dll" Alias "lstrcpyA" (ByVal lpString1 As String, ByVal lpString2 As Long) As Long Private Declare Function lstrlen Lib "kernel32.dll" Alias "lstrlenA" (ByVal lpString As Long) As Long Private Declare Function EnumPrinters Lib "winspool.drv" Alias "EnumPrintersA" (ByVal flags As Long, ByVal name As String, ByVal Level As Long, pPrinterEnum As Long, ByVal cdBuf As Long, pcbNeeded As Long, pcReturned As Long) As Long Const PRINTER_ENUM_LOCAL = &H2 Private Declare Function OpenPrinter Lib "winspool.drv" Alias "OpenPrinterA" (ByVal pPrinterName As String, phPrinter As Long, pDefault As PRINTER_DEFAULTS) As Long Private Declare Function GetPrinter Lib "winspool.drv" Alias "GetPrinterA" (ByVal hPrinter As Long, ByVal Level As Long, buffer As Long, ByVal pbSize As Long, pbSizeNeeded As Long) As Long Private Declare Function ClosePrinter Lib "winspool.drv" (ByVal hPrinter As Long) As Long Private Declare Sub CopyMemory Lib "kernel32" Alias "RtlMoveMemory" (Destination As Any, Source As Any, ByVal Length As Long) Private Declare Function IsBadStringPtrByLong Lib "kernel32" Alias "IsBadStringPtrA" (ByVal lpsz As Long, ByVal ucchMax As Long) As Long Public Function StringFromPointer(lpString As Long, lMaxLength As Long) As String Dim sRet As String Dim lret As Long If lpString = 0 Then StringFromPointer = "" Exit Function End If If IsBadStringPtrByLong(lpString, lMaxLength) Then ' An error has occured - do not attempt to use this pointer StringFromPointer = "" Exit Function End If ' Pre-initialise the return string... sRet = Space$(lMaxLength) CopyMemory ByVal sRet, ByVal lpString, ByVal Len(sRet) If Err.LastDllError = 0 Then If InStr(sRet, Chr$(0)) > 0 Then sRet = Left$(sRet, InStr(sRet, Chr$(0)) - 1) End If End If StringFromPointer = sRet End Function Private Sub Form_Load() Dim longbuffer() As Long ' resizable array receives information from the function Dim printinfo() As PRINTER_INFO_1 ' values inside longbuffer() will be put into here Dim numbytes As Long ' size in bytes of longbuffer() Dim numneeded As Long ' receives number of bytes necessary if longbuffer() is too small Dim numprinters As Long ' receives number of printers found Dim c As Integer, retval As Long ' counter variable & return value Me.AutoRedraw = True 'Set current graphic mode to persistent ' Get information about the local printers numbytes = 3076 ' should be sufficiently big, but it may not be ReDim longbuffer(0 To numbytes / 4) As Long ' resize array -- note how 1 Long = 4 bytes retval = EnumPrinters(PRINTER_ENUM_LOCAL, "", 1, longbuffer(0), numbytes, numneeded, numprinters) If retval = 0 Then ' try enlarging longbuffer() to receive all necessary information numbytes = numneeded ReDim longbuffer(0 To numbytes / 4) As Long ' make it large enough retval = EnumPrinters(PRINTER_ENUM_LOCAL, "", 1, longbuffer(0), numbytes, numneeded, numprinters) If retval = 0 Then ' failed again! Debug.Print "Could not successfully enumerate the printes." End ' abort program End If End If ' Convert longbuffer() data into printinfo() If numprinters <> 0 Then ReDim printinfo(0 To numprinters - 1) As PRINTER_INFO_1 ' room for each printer For c = 0 To numprinters - 1 ' loop, putting each set of information into each element ' longbuffer(4 * c) = .flags, longbuffer(4 * c + 1) = .pDescription, etc. ' For each string, the string is first buffered to provide enough room, and then the string is copied. printinfo(c).flags = longbuffer(4 * c) printinfo(c).pDescription = Space(lstrlen(longbuffer(4 * c + 1))) retval = lstrcpy(printinfo(c).pDescription, longbuffer(4 * c + 1)) printinfo(c).pName = Space(lstrlen(longbuffer(4 * c + 2))) retval = lstrcpy(printinfo(c).pName, longbuffer(4 * c + 2)) printinfo(c).pComment = Space(lstrlen(longbuffer(4 * c + 3))) retval = lstrcpy(printinfo(c).pComment, longbuffer(4 * c + 3)) Next c ' Display name of each printer For c = 0 To numprinters - 1 GetPrinterInfos (printinfo(c).pName) Next c End Sub Sub PrintData(name As String, Data As String) If LenB(Data) > 0 Then Debug.Print name + ": " + Data End If End Sub Private Function GetPrinterInfos(ByVal PrinterName As String) As Long Dim SizeNeeded As Long, buffer() As Long Dim pDef As PRINTER_DEFAULTS 'Get a handle to the printer lret = OpenPrinter(PrinterName, mhPrinter, pDef) 'Initialize the buffer ReDim Preserve buffer(0 To 0) As Long 'Retrieve the required size (in bytes) lret = GetPrinter(mhPrinter, 2, buffer(0), UBound(buffer), SizeNeeded) 'Resize the buffer... Note that a Long is four bytes ReDim Preserve buffer(0 To (SizeNeeded / 4) + 3) As Long 'Retrieve the Printer information lret = GetPrinter(mhPrinter, 2, buffer(0), UBound(buffer) * 4, SizeNeeded) 'The data stored in 'buffer' corresponds with the data of a PRINTER_INFO_2 structure ClosePrinter mhPrinter 'Show the data PrintData "Server name", StringFromPointer(buffer(0), 255) PrintData "Printer name", StringFromPointer(buffer(1), 255) PrintData "Share name", StringFromPointer(buffer(2), 255) PrintData "Port name", StringFromPointer(buffer(3), 255) PrintData "Driver name", StringFromPointer(buffer(4), 255) PrintData "Comment", StringFromPointer(buffer(5), 255) PrintData "Location", StringFromPointer(buffer(6), 255) End Function
