Persistance des données Java Discussion :
Problème pour setter une Foreign Key avec TopLink(ValueHolderInterface)
    Juin 2002
    Par défaut Problème pour setter une Foreign Key avec TopLink(ValueHolderInterface)
    J'ai deux tables en relation 1-n
    T_User & T_Service
    Càd un id de T_Service peut se retrouver plusieurs fois dans T_User
    T_Service <1 -- n> T_User
    Voici mes classes mapper par Toplink :
    import java.util.ArrayList;
    import java.util.List;
    import oracle.toplink.indirection.ValueHolder;
    import oracle.toplink.indirection.ValueHolderInterface;
    public class TUser {
    /**Map tService <-> ......bo.TService
    * @associates <{......bo.TService}>
    private ValueHolderInterface tService;
    private Double id;
    private String firstname;
    private String lastname;
    public TUser() {
    super();
    this.tService = new ValueHolder();
    public String getFirstname() {
    return this.firstname;
    public Double getId() {
    return this.id;
    public String getLastname() {
    return this.lastname;
    public TService getTService() {
    return (TService)this.tService.getValue();
    public void setFirstname(String firstname) {
    this.firstname = firstname;
    public void setId(Double id) {
    this.id = id;
    public void setTService(TService tService) {
    this.tService.setValue(tService);
    package .........bo;
    public class TService {
    /**Map tUserCollection <-> .........bo.TUser
    * @associates <{.........bo.TUser}>
    private List tUserCollection;
    private Double id;
    private String name;
    private String code;
    public TService() {
    super();
    this.tUserCollection = new ArrayList();
    public void addTUser(int index, TUser aTUser) {
    this.tUserCollection.add(index, aTUser);
    aTUser.setTService(this);
    public void addTUser(TUser aTUser) {
    this.tUserCollection.add(aTUser);
    public String getCode() {
    return this.code;
    return this.id;
    public String getName() {
    return this.name;
    public List getTUserCollection() {
    return this.tUserCollection;
    public void removeTUser(TUser aTUser) {
    this.tUserCollection.remove(aTUser);
    aTUser.setTService(null);
    public void setCode(String code) {
    this.code = code;
    this.id = id;
    public void setName(String name) {
    this.name = name;
    public void setTUserCollection(List tUserCollection) {
    this.tUserCollection = tUserCollection;
    Je n'arrive pas à attribuer un id du Service à un User ....
    Juin 2002
    J'ai trouvé la solution,
    Il faut seter une instance de l'objet enfant, ensuite lire avec cet objet les données au niv DB et ensuite seter l'objet parent avec cet objet .
    Kcintim
  1. [XL-2010] Problème pour renseigner une liste déroulante avec 5 colonnes
    Par juguy dans le forum Excel
    Dernier message: 19/05/2015, 12h25
  2. Asscociation d'une foreign key avec une autre table
    Par ROUGE87 dans le forum Général Java
    Dernier message: 13/04/2011, 10h36
  3. Réponses: 1
    Dernier message: 20/12/2010, 22h43
  4. [AJAX] Afficher une image GD avec ajax
    Par darkvodka dans le forum Général JavaScript
    Dernier message: 05/06/2007, 00h43
  5. [débutant] Aide pour mettre une FOREIGN KEY sur une table
    Par cauldron dans le forum Langage SQL
    Dernier message: 14/11/2004, 17h16
