1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199
import java.awt.BorderLayout;
import java.awt.event.ActionEvent;
import java.awt.event.ActionListener;
import java.io.CharArrayWriter;
import java.io.PrintWriter;
import java.lang.Thread.UncaughtExceptionHandler;
import java.lang.reflect.InvocationTargetException;
import java.util.HashMap;
import java.util.Map;
import java.util.concurrent.ExecutionException;
import java.util.concurrent.ExecutorService;
import java.util.concurrent.Executors;
import java.util.concurrent.Future;
import java.util.concurrent.ThreadFactory;
import java.util.concurrent.TimeUnit;
import java.util.concurrent.TimeoutException;
import java.util.concurrent.atomic.AtomicInteger;
import javax.swing.JButton;
import javax.swing.JFrame;
import javax.swing.JOptionPane;
import javax.swing.JProgressBar;
import javax.swing.JTextArea;
import javax.swing.SwingUtilities;
import javax.swing.WindowConstants;
class ReportPrinterTask implements Runnable {
public void run() {
String threadName = Thread.currentThread().getName();
Thread.currentThread().setName(threadName + " [print]");
try
JasperPrint printfile = JasperFillManager.fillReport(reportfile, parametres,connect);
finally
Thread.currentThread().setName(threadName);
class GenericThreadFactory implements ThreadFactory {
private static final Map<String, AtomicInteger> staticCounters = new HashMap<String, AtomicInteger>();
public AtomicInteger getStaticCounter(String base) {
AtomicInteger staticCounter = null;
synchronized (staticCounters)
staticCounter = staticCounters.get(base);
if (staticCounter == null) {
staticCounter = new AtomicInteger(1);
staticCounters.put(base, staticCounter);
return staticCounter;
private final AtomicInteger counter = new AtomicInteger(1);
private final boolean daemon;
private final ThreadGroup threadGroup;
public GenericThreadFactory() {
this("threadpool");
public GenericThreadFactory(String base) {
this(base, false);
public GenericThreadFactory(String base, boolean isDaemon) {
threadGroup = new ThreadGroup(base + "-" + getStaticCounter(base).getAndIncrement());
daemon = isDaemon;
@Override
public Thread newThread(Runnable r)
Thread newThread = new Thread(threadGroup, r, threadGroup.getName() + "-" + counter.getAndIncrement());
newThread.setDaemon(daemon);
newThread.setPriority(Thread.NORM_PRIORITY);
return newThread;
class ReportManager {
ExecutorService threadPool = Executors.newCachedThreadPool(new GenericThreadFactory("ReportManager"));
public void print() throws ExecutionException, TimeoutException {
Future<?> future = threadPool.submit(new ReportPrinterTask());
try
future.get(120, TimeUnit.SECONDS);
catch (InterruptedException e)
throw new RuntimeException("Wait of printing task has been interrupted", e);
class ReportGui implements UncaughtExceptionHandler {
ExecutorService threadPool = Executors.newCachedThreadPool(new GenericThreadFactory("ReportGuiAction"));
ReportManager manager = new ReportManager();
public void invokeOnThreadPool(Runnable task) {
try
Future<?> future = threadPool.submit(task);
future.get();
throw new RuntimeException(e);
catch (ExecutionException e)
e.printStackTrace();
public void invokeOnEdt(Runnable task) {
try
SwingUtilities.invokeAndWait(task);
catch (InvocationTargetException e)
@Override
public void uncaughtException(Thread t, Throwable e)
CharArrayWriter writer = new CharArrayWriter();
PrintWriter printWriter = new PrintWriter(writer);
e.printStackTrace(printWriter);
JTextArea text = new JTextArea(writer.toString(), 0, 120);
JOptionPane.showMessageDialog(null, text, "Error", JOptionPane.ERROR_MESSAGE);
public void displayMain() {
final JFrame frame = new JFrame("Report");
frame.setDefaultCloseOperation(WindowConstants.DISPOSE_ON_CLOSE);
final JButton button = new JButton("print");
button.addActionListener(new ActionListener()
@Override
public void actionPerformed(ActionEvent e)
JProgressBar progressBar = null;
try
button.setEnabled(false);
progressBar = new JProgressBar();
progressBar.setIndeterminate(true);
progressBar.setString("Printing in progress ...");
progressBar.setStringPainted(true);
frame.getContentPane().add(progressBar, BorderLayout.SOUTH);
launchPrint();
finally
button.setEnabled(true);
frame.getContentPane().remove(progressBar);
frame.getContentPane().add(button, BorderLayout.CENTER);
frame.pack();
frame.setLocationRelativeTo(null);
frame.setVisible(true);
public void launchPrint() {
invokeOnThreadPool(new Runnable()
@Override
public void run()
try
manager.print();
uncaughtException(Thread.currentThread(), e);
catch (TimeoutException e)
