Pourquoi Oracle ne prend pas en compte mon HINT ?
    Avatar de StringBuilder
    Chef de projets
    Février 2010
    Activité : Chef de projets
    Par défaut Pourquoi Oracle ne prend pas en compte mon HINT ?
    * Bonjour, *
    J'ai la vue suivante :
    CREATE OR REPLACE FORCE VIEW WV_QIFM30_BIS (CODSOC, LIB1, LIB2, LIB3, LIB4, LIB5, LIB6, LIB7, LIB8, LIB9, LIB10, LIB11, LIB12, LIB13, LIB14, LIB15, LIB16, LIB17, LIB18, LIB19, LIB20, DAT1, DAT2, DAT3, DAT4, DAT5, NUM01, NUM02, NUM03, NUM04, NUM05, NUM06, NUM07, NUM08, NUM09, NUM10, VAL01, VAL02, VAL03, VAL04, VAL05, VAL06, VAL07, VAL08, VAL09, VAL10, VAL11, VAL12, VAL13, VAL14, VAL15, VAL16, VAL17, VAL18, VAL19, VAL20)
    AS
      SELECT /*+ index(tie TIE_IDX1) */ cde.codsoc,
        cde.achvte,
        cde.typeve,
        DECODE( UPPER(SUBSTR(tie.codzn16,1,1)),'P',upper(tie.codzn16), '000'
        ||SUBSTR(tie.sigtie,2,5)),
        cde.codeta,
        tie.codett,
        SUBSTR(DECODE(NVL(p2.coduni, ' '), ' ', pro.codzn15, 'PI', pro.codzn15, DECODE(SUBSTR(p2.coduni, 1, 1), 'P', prc.codzn2, 'D', prc.codzn2, 'B', prc.codzn2, pro.codzn15)),2,8),
        /*liv.datliv*/
        (SELECT MAX(liv.datliv)
        FROM eve liv
        WHERE liv.codsoc = cde.codsoc
        AND liv.achvto   = cde.achvte
        AND liv.typevo   = cde.typeve
        AND liv.numevo   = cde.numeve
        cdp.codpro,
        pro.codzn10,
        cde.codctg,
        'XXX',
        /*liv.datliv*/
        FROM eve liv
        cde.numeve,
        NVL(to_number(trim(evt.codzn5)), cdp.qtecde),
        0,0,0,
        0,0,0,0,0,
        pru.coefuv,
        0,0,0,0,
        0,0,0,0,0,
        0,0,0,0,0,
        0,0,0,0,0
      FROM eve cde
      INNER JOIN tie
      ON tie.codsoc  = cde.codsoc
      AND tie.typtie = 'CLI'
      AND tie.sigtie = cde.sigtie
      INNER JOIN evp cdp
      ON cdp.codsoc  = cde.codsoc
      AND cdp.achvte = cde.achvte
      AND cdp.typeve = cde.typeve
      AND cdp.numeve = cde.numeve
      INNER JOIN pro
      ON pro.codsoc  = cdp.codsoc
      AND pro.codpro = cdp.codpro
      INNER JOIN prl
      ON prl.codsoc  = pro.codsoc
      AND prl.codpro = pro.codpro
      AND prl.typtie = ' '
      AND prl.sigtie = ' '
      AND prl.codva1 = '00'
      AND prl.codva2 = SUBSTR(pro.codpro,8,2)
      AND prl.cntcod = ' '
      INNER JOIN pru
      ON pru.codsoc  = prl.codsoc
      AND pru.codpro = prl.codpro
      AND pru.coduni = prl.coduni1
      INNER JOIN evt
      ON evt.codsoc  = cdp.codsoc
      AND evt.achvte = cdp.achvte
      AND evt.typeve = cdp.typeve
      AND evt.numeve = cdp.numeve
      AND evt.numpos = cdp.numpos
      AND evt.numlig = 0
      AND evt.numspo = 0
      AND evt.numblo = 0
      LEFT OUTER JOIN prc
      ON prc.codsoc  = cde.codsoc
      AND prc.typtie = 'CLI'
      AND prc.sigfou = tie.sigtie
      AND prc.codpro = pro.codpro
      LEFT OUTER JOIN pro p2
      ON p2.codsoc          = prc.codsoc
      AND p2.codpro         = prc.codzn2
      WHERE cde.codctg NOT IN ('DE','GR','EC');
    J'ai mis un HINT sur la table TIE, afin de forcer l'utilisation de l'index unique (CODSOC, TYPTIE, SIGTIE)
    Logique, puisque c'est ça que j'utilise pour faire la jointure avec la table EVE...
    Seulement, lorsque j'exécute la requête suivante :
    select lib1 ,lib2 ,lib3 ,lib4 ,lib5 ,lib6 ,lib7 ,lib8 ,lib9 ,lib10 ,lib11 ,lib12 ,lib13 ,lib14 ,lib15 ,lib16 ,lib17 ,lib18 ,lib19 ,lib20 ,dat1 ,dat2 ,dat3 ,dat4 ,dat5 ,num01 ,num02 ,num03 ,num04 ,num05 ,num06 ,num07 ,num08 ,num09 ,num10 ,val01 ,val02 ,val03 ,val04 ,val05 ,val06 ,val07 ,val08 ,val09 ,val10 ,val11 ,val12 ,val13 ,val14 ,val15 ,val16 ,val17 ,val18 ,val19 ,val20 ,codsoc
    from wv_qifm30_bis
    where codsoc = 100
    and lib1 = 'V'
    and lib2 = 'CDE'
    and dat1 BETWEEN '20111221' and '20120103'
    and lib8 LIKE '2%'
    and (lib4 = 'V' or lib4 = 'S')
    and (lib5 = 'ME1' or lib5 = 'ME2')
    order by lib6 ASC ,lib3 ASC ,dat1 ASC
    Si je demande le plan d'exécution à SQL Developper (F10) alors je vois qu'il désire utilise l'index TIE_IDX6 (CODSOC, P_TIEINTGR, TYPTIE) alors que je n'utilise même pas P_TIEINTGR).
    Du coup, cette requête déjà particulièrement barbare dure plus de 30 minutes... Alors je désirerais qu'il utilise au moins les bons index, même si c'est loin d'être à cet endroit qu'il passe le plus de temps, ce serait toujours ça de pris...
    * Merci *
    Avatar de Waldar
    J'ai un doute sur l'hint placé directement dans la vue, c'est pas impossible du tout qu'Oracle l'ignore totalement.
    Est-ce que l'index est utilisé avec cette syntaxe ?
      SELECT /*+ index(wv_qifm30_bi.tie TIE_IDX1) */
             lib1 , lib2 , lib3 , lib4 , lib5 , lib6 , lib7 , lib8 , lib9 , lib10
           , lib11, lib12, lib13, lib14, lib15, lib16, lib17, lib18, lib19, lib20
           , dat1 , dat2 , dat3 , dat4 , dat5
           , num01, num02, num03, num04, num05, num06, num07, num08, num09, num10
           , val01, val02, val03, val04, val05, val06, val07, val08, val09, val10
           , val11, val12, val13, val14, val15, val16, val17, val18, val19, val20
           , codsoc
        FROM wv_qifm30_bis
       WHERE codsoc = 100
         AND lib1 = 'V'
         AND lib2 = 'CDE'
         AND dat1 BETWEEN date '2011-12-21' AND date '2012-01-03'
         AND lib8 LIKE '2%'
         AND lib4 IN ('S', 'V')
         AND lib5 IN ('ME1', 'ME2')
    ORDER BY lib6 ASC ,lib3 ASC ,dat1 ASC;
    Cela dit si Oracle ne l'utilise pas, c'est qu'il le juge moins pertinent que l'autre index.
    Août 2008
    Chef de projets
    Février 2010
    Hmpf
    C'est mort, la requête est générée par un ERP, je ne peux pas aller mettre un HINT dans la requête, je n'ai accès qu'à la vue...
    Vivement qu'on change de version, on aura une version plus récente d'Oracle, avec peut-être moins de bugs dans l'optimiseur...
    Parce que là, le coup du TIE_IDX6, faudra m'expliquer quelques années avant que je comprenne...
    Chef de projets
    Février 2010
    La méthode utilisée par Oracle pour choisir un index, c'est Random() non ?
    Parce que là, sur les 10 index présents sur TIE, il a clairement choisi LE SEUL qui n'a aucune chance d'être intéressant.
    En effet, je n'utilise pas P_TIEINTGR dans la vue.
    Alors que l'ensemble des autres indexes portent sur un plus grand nombre de champs utilisés dans la vue.
    A noter que le IDX1, qui est la clé, est de toute façon mon critère de jointure :
    INNER JOIN tie
    Vu que ces champs qui composent la clé primaire sont :
    - UNIQUE
    - Organisés en cluster
    - Immuables
    Les stats pour de l'ensemble des index sont recalculées en même temps.
    Il n'y a donc aucune chance qu'un autre index soit plus pertinent... A part si Oracle utilise Random() pour choisir...
    Août 2008
    Quel est l'intérêt d'avoir 2 fois :
    /*liv.datliv*/
        FROM eve liv
    N'est il pas possible de remplacer la sous requête par un max analytique ?
    max(cde.datliv) over (partition by cde.codsoc,cde.achvte,cde.typeve,cde.numeve) as max_datliv
    Avatar de Waldar
    Citation Envoyé par StringBuilder Voir le message
    Oracle s'appuie sur les statistiques récoltées pour définir ses méthodes d'accès.
    Si vous êtes en 10g+, le CBO est excellent : les requêtes à aiguiller avec un HINT sont rares.
    Ce n'est pas parce que vous avez un index qu'il va être utilisé, un exemple simple :
    create table t1 (c1  int primary key, c2 int not null);
    -- Table created.
    insert /*+ append */ into t1 (c1, c2)
    select level, 1
      from dual
    connect by level <= 1e5;
    -- 100000 rows created.
    commit;
    -- Commit complete.
    create index i_t1 on t1 (c2);
    -- Index created.
    begin
      dbms_stats.gather_table_stats
      ( ownname          => user
      , tabname          => 'T1'
      , estimate_percent => 100
      , cascade          => true);
    end;
    -- PL/SQL procedure successfully completed.
    Voila pour les données.
    Une première requête :
    select /*+ gather_plan_statistics */ count(*)
      from t1
     where c2 = 1;
    set linesize 125;
    select * from table(dbms_xplan.display_cursor(null,null,'ALLSTATS LAST'));
    | Id  | Operation          | Name | Starts | E-Rows | A-Rows |   A-Time   | Buffers |
    |   0 | SELECT STATEMENT   |      |      1 |        |      1 |00:00:00.01 |      94 |
    |   1 |  SORT AGGREGATE    |      |      1 |      1 |      1 |00:00:00.01 |      94 |
    |*  2 |   TABLE ACCESS FULL| T1   |      1 |    100K|    100K|00:00:00.01 |      94 |
    Predicate Information (identified by operation id):
       2 - filter("C2"=1)
    La requête n'utilise pas l'index alors que pourtant je filtre pile sur la bonne colonne.
    Avec une autre valeur :
      from t1
     where c2 = 2;
    set linesize 125;
    |   0 | SELECT STATEMENT  |      |      1 |        |      1 |00:00:00.01 |       2 |
    |   1 |  SORT AGGREGATE   |      |      1 |      1 |      1 |00:00:00.01 |       2 |
    |*  2 |   INDEX RANGE SCAN| I_T1 |      1 |      1 |      0 |00:00:00.01 |       2 |
       2 - access("C2"=2)
    Membre émérite Avatar de pacmann
    Consulté Oracle
    Juin 2004
    Activité : Consulté Oracle
    Secteur : Distribution
    Non, ce sont les statistiques qu'il a sur tes données, ainsi que ces heuristiques de calcul des coûts...
    ... qui donc ne sont peut-être pas pertinentes dans ton cas.
    Et ça, ça peut s'expliquer de plein de manières.
    Il faut regarder le plan et les cardinalités qu'il estime, les comparer à ce qu'il y a en vrai, comprendre pourquoi il y a un écart...
    Chef de projets
    Février 2010
    Citation Envoyé par skuatamad Voir le message
    Quel est l'intérêt d'avoir 2 fois la même sous-requête ?
    Aucun, c'est juste que le format de la vue est imposé par l'ERP, et qu'il a besoin d'avoir cette information dans deux champs différents.
    Eventuellement, un sous-select global aurait permi d'utiliser un unique sous-select, et reprendre le même résultat dans deux alias. Ceci dit, je pense que quand Oracle voit deux fois le même sous-select, il ne l'exécute qu'une seule fois (j'espère pour lui tout du moins)
    Nope, si tu fais attention, lorsque je recherche le MAX, je ne cherche pas sur la même ligne, je fais une auto-jointure de sur codsoc, achvte, typeve, numeve vers codsoc, achvto, typevo, numevo
    => J'avais tenté de faire une jointure dans le FROM et un group by, mais je me suis heurté à d'autres problèmes qui m'ont obligés à utiliser une sous-requête.
    Chef de projets
    Février 2010
    Je suis d'accord sur le principe, mais dans ce cas précis (plus de 400 000 lignes retournées par la vue) un index est bel et bien nécessaire.
    Aussi, si je simplifie la requête (par exemple) :
    select *
    from eve
    inner join tie on tie.codsoc = eve.codsoc and tie.typtie = 'CLI' and tie.sigtie = eve.sigtie
    where eve.codsoc = 100
    and eve.achvte = 'V'
    and eve.typeve = 'LIV'
    J'ai bien mon index TIE_IDX1 qui est utilisé.
    Je ne vois absolument pas, dans la vue, ce qui peut le pousser à tenter d'utiliser un autre index, surtout sur index qui porte sur des champs absents de la requête !
    Enfin bon, de toute façon, le problème est clos, dans la mesure où je n'ai pas de moyen pour le forcer à utiliser un autre index (et que, comme je l'espère, on va migrer d'ici quelques mois, et donc laisser tomber le serveur actuel qui me semble particulièrement étrangement configuré -jamais vu des requêtes aussi lentes qu'ici, ni de plans d'exécution aussi tordus-)
    Membre expérimenté
    Mars 2010
    Il peut y avoir plusieurs raisons qui font en sorte que l'index ne soit pas utilisé malgré l'avoir mis explicitement dans le hint. Au lieu de m'étaler la dessus, je vous invite à lire le lien suivant (ainsi que tous les liens qui y sont référencés)
    http://hoopercharles.wordpress.com/2...an-index-hint/
  1. Apache ne prend pas en compte mon /etc/host
    Par AstonMartin dans le forum Apache
    Réponses: 12
    Dernier message: 11/07/2013, 03h35
  2. [Info]Eclipse ne prend pas en compte mes modifs...
    Par Baptiste Wicht dans le forum Eclipse Java
    Dernier message: 20/01/2006, 17h50
  3. Visual Basic ne prend pas en compte mon chgt de variable
    Par Crazy_Gun dans le forum VB 6 et antérieur
    Dernier message: 09/12/2005, 14h40
  4. ne prend pas en compte le "0" ? comprend pas !!!
    Par pierre987321 dans le forum Général JavaScript
    Dernier message: 17/10/2005, 19h39
  5. [JAR] Archive qui ne prend pas en compte librairie externe
    Par Shiryu44 dans le forum Général Java
    Dernier message: 22/04/2005, 13h59
