1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76
| create table Livre (
numero_b char not null,
title char not null,
price char not null CHECK (price > 0),
type ENUM ( 'dict', 'poe', 'novel', 'tb' ) not null,
year char not null DEFAULT '(SELECT add_months(SYSDATE, 12) FROM DUAL;)',
Editor char not null,
constraint ID_Livre primary key (numero_b));
create table Abonne (
numero_abo char not null,
name char not null,
surname char not null,
status char ,
street char not null,
town char not null,
constraint ID_abo primary key (numero_abo));
create table Auteur (
numero char not null,
writer char,
CONSTRAINT book FOREIGN KEY ( numero ) REFERENCES Livre ( numero_b),
constraint ID_writer primary key (numero, writer));
create table Emprunt (
numero_ex char not null,
numero_book char not null,
numero_abo char,
return_date char DEFAULT ( CASE Abonne.statut
WHEN 'VIP' THEN ( UPDATE Emprunt SET return_date=(SELECT add_months(SYSDATE, 24) FROM DUAL ;) WHERE Abonne.Numero=Emprunt.Numeroabo )
WHEN 'TEACHER' THEN ( UPDATE Emprunt SET return_date=(SELECT add_months(SYSDATE, 12) FROM DUAL ;) WHERE Abonne.Numero=Emprunt.Numeroabo )
WHEN 'STUDENT' THEN ( UPDATE Emprunt SET return_date=(SELECT add_months(SYSDATE, 6) FROM DUAL ;) WHERE Abonne.Numero=Emprunt.Numeroabo )
WHEN 'RETURNING' THEN ( UPDATE Emprunt SET return_date=(SELECT add_months(SYSDATE, 3) FROM DUAL ;) WHERE Abonne.Numero=Emprunt.Numeroabo )
Else ( UPDATE Emprunt SET return_date=(SELECT add_months(SYSDATE,1) FROM DUAL ;) WHERE Abonne.Numero=Emprunt.Numeroabo )
END ),
CONSTRAINT ID_emprunt PRIMARY KEY ( numero_ex, numero_b, numero_abo ),
CONSTRAINT exemplaire FOREIGN KEY ( numero_ex ) REFERENCES Exemplaire ( numero_ex);
CONSTRAINT abonne FOREIGN KEY ( numero_abo ) REFERENCES Abonne ( numero_abo);
create table Exemplaire (
CONSTRAINT ID_Exemplaire PRIMARY KEY (Num_Ex, Numero));
CREATE SEQUENCE seq_book;
CREATE SEQUENCE seq_abo;
CREATE SEQUENCE seq_ex ;
CREATE OR REPLACE TRIGGER trig_book
BEFORE INSERT ON Livre FOR EACH ROW
BEGIN
SELECT seq_book.NEXTVAL
INTO :NEW.numero_b
FROM DUAL;
END;
CREATE OR REPLACE TRIGGER trig_abo
BEFORE INSERT ON Abonne FOR EACH ROW
BEGIN
SELECT seq_abo.NEXTVAL
INTO :NEW.numero_abo
FROM DUAL;
END;
CREATE OR REPLACE TRIGGER trig_ex
BEFORE INSERT ON Exemplaire FOR EACH ROW
BEGIN
SELECT seq_ex.NEXTVAL
INTO :NEW.numero_ex
FROM DUAL;
END; |
