j'ai un probleme de communication de web-service uniquement sur glassfish (sous tomcat ca passe).
Lorsque je configure mon web-service en soap 1.1, mon client envoie du soap 1.2, et vice-versa.
Voila l'erreur que j'obtiens coté serveur :
Coté serveur, mon wsdl est bien configuré en soap 1.2 :
43 GRAVE: Unsupported Content-Type: text/xml; charset="utf-8" Supported ones are: [application/soap+xml] com.sun.xml.ws.server.UnsupportedMediaException: Unsupported Content-Type: text/xml; charset="utf-8" Supported ones are: [application/soap+xml] at com.sun.xml.ws.encoding.StreamSOAPCodec.decode(StreamSOAPCodec.java:291) at com.sun.xml.ws.encoding.StreamSOAPCodec.decode(StreamSOAPCodec.java:128) at com.sun.xml.ws.encoding.SOAPBindingCodec.decode(SOAPBindingCodec.java:287) at com.sun.xml.ws.transport.http.HttpAdapter.decodePacket(HttpAdapter.java:276) at com.sun.xml.ws.transport.http.HttpAdapter.access$500(HttpAdapter.java:93) at com.sun.xml.ws.transport.http.HttpAdapter$HttpToolkit.handle(HttpAdapter.java:432) at com.sun.xml.ws.transport.http.HttpAdapter.handle(HttpAdapter.java:244) at com.sun.xml.ws.transport.http.servlet.ServletAdapter.handle(ServletAdapter.java:135) at com.sun.xml.ws.transport.http.servlet.WSServletDelegate.doGet(WSServletDelegate.java:129) at com.sun.xml.ws.transport.http.servlet.WSServletDelegate.doPost(WSServletDelegate.java:160) at com.sun.xml.ws.transport.http.servlet.WSServlet.doPost(WSServlet.java:75) at javax.servlet.http.HttpServlet.service(HttpServlet.java:754) at javax.servlet.http.HttpServlet.service(HttpServlet.java:847) at org.apache.catalina.core.ApplicationFilterChain.servletService(ApplicationFilterChain.java:427) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:315) at org.apache.catalina.core.StandardContextValve.invokeInternal(StandardContextValve.java:287) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:218) at org.apache.catalina.core.StandardPipeline.doInvoke(StandardPipeline.java:648) at org.apache.catalina.core.StandardPipeline.doInvoke(StandardPipeline.java:593) at com.sun.enterprise.web.WebPipeline.invoke(WebPipeline.java:94) at com.sun.enterprise.web.PESessionLockingStandardPipeline.invoke(PESessionLockingStandardPipeline.java:98) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:222) at org.apache.catalina.core.StandardPipeline.doInvoke(StandardPipeline.java:648) at org.apache.catalina.core.StandardPipeline.doInvoke(StandardPipeline.java:593) at org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:587) at org.apache.catalina.core.ContainerBase.invoke(ContainerBase.java:1096) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:166) at org.apache.catalina.core.StandardPipeline.doInvoke(StandardPipeline.java:648) at org.apache.catalina.core.StandardPipeline.doInvoke(StandardPipeline.java:593) at org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:587) at org.apache.catalina.core.ContainerBase.invoke(ContainerBase.java:1096) at org.apache.coyote.tomcat5.CoyoteAdapter.service(CoyoteAdapter.java:288) at com.sun.enterprise.web.connector.grizzly.DefaultProcessorTask.invokeAdapter(DefaultProcessorTask.java:647) at com.sun.enterprise.web.connector.grizzly.DefaultProcessorTask.doProcess(DefaultProcessorTask.java:579) at com.sun.enterprise.web.connector.grizzly.DefaultProcessorTask.process(DefaultProcessorTask.java:831) at com.sun.enterprise.web.connector.grizzly.DefaultReadTask.executeProcessorTask(DefaultReadTask.java:341) at com.sun.enterprise.web.connector.grizzly.DefaultReadTask.doTask(DefaultReadTask.java:263) at com.sun.enterprise.web.connector.grizzly.DefaultReadTask.doTask(DefaultReadTask.java:214) at com.sun.enterprise.web.portunif.PortUnificationPipeline$PUTask.doTask(PortUnificationPipeline.java:380) at com.sun.enterprise.web.connector.grizzly.TaskBase.run(TaskBase.java:265) at com.sun.enterprise.web.connector.grizzly.ssl.SSLWorkerThread.run(SSLWorkerThread.java:106)
Et dans l'implémentation du web-service coté serveur :
58 <?xml version="1.0" encoding="UTF-8" standalone="yes"?> <!-- Generated by JAX-WS RI at http://jax-ws.dev.java.net. RI's version is JAX-WS RI 2.1.7-b01-. --> <definitions targetNamespace="http://impl.webservice..../" name="WSQTLicensingImplService" xmlns="http://schemas.xmlsoap.org/wsdl/" xmlns:tns="http://impl.webservice..../" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:soap12="http://schemas.xmlsoap.org/wsdl/soap12/"> <import namespace="http://webservice..../" location="WSQTLicensing.wsdl"/> <binding name="WSQTLicensingImplPortBinding" type="ns1:WSQTLicensing" xmlns:ns1="http://webservice..../"> <soap12:binding transport="http://www.w3.org/2003/05/soap/bindings/HTTP/" style="document"/> <operation name="removeEntite"> <soap12:operation soapAction=""/> <input> <soap12:body use="literal"/> </input> <output> <soap12:body use="literal"/> </output> </operation> <operation name="addEntite"> <soap12:operation soapAction=""/> <input> <soap12:body use="literal"/> </input> <output> <soap12:body use="literal"/> </output> </operation> <operation name="getAllEntites"> <soap12:operation soapAction=""/> <input> <soap12:body use="literal"/> </input> <output> <soap12:body use="literal"/> </output> </operation> <operation name="getEntite"> <soap12:operation soapAction=""/> <input> <soap12:body use="literal"/> </input> <output> <soap12:body use="literal"/> </output> </operation> <operation name="updateEntite"> <soap12:operation soapAction=""/> <input> <soap12:body use="literal"/> </input> <output> <soap12:body use="literal"/> </output> </operation> </binding> <service name="WSQTLicensingImplService"> <port name="WSQTLicensingImplPort" binding="tns:WSQTLicensingImplPortBinding"> <soap12:address location="REPLACE_WITH_ACTUAL_URL"/> </port> </service> </definitions>
4 @WebService(endpointInterface = "...WSQTLicensing") @BindingType(value = "http://java.sun.com/xml/ns/jaxws/2003/05/soap/bindings/HTTP/") @Transactional public class WSQTLicensingImpl implements WSQTLicensing {
Tout le code coté client est généré via jaxws-maven-plugin via wsimport :
J'ai déjà effectué pas mal de recherches, mais sans trouver de solutions.
70 <build> <plugins> <plugin> <groupId>org.jvnet.jax-ws-commons</groupId> <artifactId>jaxws-maven-plugin</artifactId> <version>2.1</version> <dependencies> <dependency> <groupId>org.andromda.thirdparty.jaxb2_commons</groupId> <artifactId>collection-setter-injector</artifactId> <version>1.0</version> </dependency> </dependencies> <executions> <execution> <goals> <goal>wsimport</goal> </goals> <configuration> <wsdlDirectory>${basedir}/src/wsdl</wsdlDirectory> <wsdlLocation>http://localhost:8080/web-service-1.0.2/WSQTLicensingImplService?wsdl</wsdlLocation> <genWsdl>true</genWsdl> <keep>true</keep> <packageName>monpackage</packageName> <xjcArgs> <xjcArg>-Xcollection-setter-injector</xjcArg> </xjcArgs> <extension>true</extension> </configuration> </execution> </executions> </plugin> </plugins> <pluginManagement> <plugins> <plugin> <groupId>org.eclipse.m2e</groupId> <artifactId>lifecycle-mapping</artifactId> <version>1.0.0</version> <configuration> <lifecycleMappingMetadata> <pluginExecutions> <pluginExecution> <pluginExecutionFilter> <groupId> org.jvnet.jax-ws-commons </groupId> <artifactId> jaxws-maven-plugin </artifactId> <versionRange> [2.1,) </versionRange> <goals> <goal>wsimport</goal> </goals> </pluginExecutionFilter> <action> <ignore></ignore> </action> </pluginExecution> </pluginExecutions> </lifecycleMappingMetadata> </configuration> </plugin> </plugins> </pluginManagement> </build>
C'est assez incompréhensible comme erreur, pourquoi ça passe sous tomcat ? Et pourquoi le protocole soap est inversé coté client ?
Toute aide serait la bienvenue.
Merci.
