[SQL QUERY] Problème avec les servlet plutôt qu'avec SQL
Servlets/JSP Java
    Battosaiii
    Par défaut [SQL QUERY] Problème avec les servlet plutôt qu'avec SQL
     public void Accountdetails(HttpServletResponse res,String login) throws IOException
        	//connection to DCU
        	Connection con=null;
        	con=Connect();
        	//initialization
        	Statement stmt = null;
            ResultSet rs = null;
            try{
            	 PrintWriter out = res.getWriter();
            	stmt = con.createStatement();
            	out.println("login into accountdetails ="+login);
        	    rs = stmt.executeQuery("SELECT A.NAME,A.BALANCE,A.OVERDRAFT " +
        	    		"FROM ACCOUNTS123 A,USERS123 U "+
        	    		"WHERE A.USER_ID=U.ID "+
        	    		"AND U.LOGIN='"+login+"'");
        	     //out.println("<script language='Javascript1.2'>");
        	    //out.println("function submit() {var form = document.AccountForm;");
        	    //out.println("form.submit();}");
        	    //out.println("</script>}");
        	    out.println("<TR><TD><FORM name ='AccountForm' action=http://localhost:8080/OnlineBankingSystem/servlet/account_2 method='POST' >");
        	    while (rs.next())
    		           // out.println("<TR><TD><A HREF='http://localhost:8080/OnlineBankingSystem/servlet/account_2'>"+rs.getString("NAME")+"</A>");
        	    	out.println("<input type='hidden' name='NUMBER' value='"+rs.getString("ACCOUNT_NUMBER")+"'>");
        	    	out.println("<input type='hidden' name='NAME' value='"+rs.getString("NAME")+"'>");
        	    	out.println("<input type='submit' value='"+rs.getString("NAME")+"'></TD>");
        	    		//<TR><TD>Your accounts</TD><TD>balance</TD><TD>overdraft limit</TD></TR>
    		          //  out.println("<TR><TD><A HREF=http://localhost:8080/OnlineBankingSystem/servlet/account_2?var="+rs.getString("NAME")+">"+rs.getString("NAME")+"</A></TD>");
    		            out.println("<TD>"+rs.getString("BALANCE")+"</TD>");
    		            out.println("<TD>"+rs.getString("OVERDRAFT")+"</TD></TR>");
        	    	deconnect(stmt,rs,con);
                catch (SQLException e) {
        	     System.out.println("\nAn error has occurred during the Statement/ResultSet phase.  Please check the syntax and study the Exception details!");
                    while (e != null) {
        	         System.out.println(e.getMessage());
                        e = e.getNextException();
                    //System.exit(0);
    une SQL Exception e survient lorsque j'execute mon programme alors qu'il y 20 minutes ce SQL query marcahait parfaitement . Ce SQL query s'executait bien jusqu'a mainteant. J'ai change quelaues balises html dans le while c'est tout. Donc je coince ...
    [quote]
    Connecting to the SSD Database......
    Connection Successful..... creating statement....
    Invalid column name
    [quote]
    j'ai verifier ma database et rien n'a ete modifier, j'ai reexcute le query
    avec SQL tool et ma requete marche donc ?????
    Membre éclairé Avatar de BizuR
    Mai 2005
    hum j'ai toujours eu des problemes avec les requetes SQL et leur récupérations avec les noms de champs lorsque l'on utilise les alias dans le select ... es tu sur qu'en faisant :
    SELECT A.NOM, A.PRENOM FROM ETUDIANT A
    tu puisses récupérer les attributs ainsi :
    rs.getString("NOM");rs.getString("PRENOM");
    n'est ce pas plutot ainsi :
    rs.getString("A.NOM");rs.getString("A.PRENOM");
    Si tu es sur de toi, tant mieux et alors je ne vois pas encore d'ou vient l'erreur, si non, bah verifie si ca vient de la alors
    Membre régulier
    Décembre 2003
    Ca ne résoudra pas ton problème mais ça pourrait t'aider lorsque tu devras maintenir ton code : tu devrais éviter de générer la présentation de ta page html et d'accéder à tes données dans une même classe.
    Même sans parler de MVC, il est important en POO d'avoir des objets qui ont des responsabilités bien distinctes.
    Imagine que tu aies une liste qui contient des objets de classe Account.
    Ton code ne serait-il pas plus lisible si tu faisais un truc du genre :
    Iterator it = list.iterator();
    while ( it.hasNext() ) {
        Account account = (Account) it.next();
        //Génération de HTML....
        out.println(account.getName());
        out.println(account.getNumber());
    et que tu ailles récupérer tes données dans une autre classe qui te renvoie une liste ?
    Après, c'est toi qui vois mais je pense que ça pourrait t'aider
  1. Problème session avec les servlet
    Par Didiplouf dans le forum Java EE
    Dernier message: 19/05/2011, 12h50
  2. Problème avec les servlets
    Par jdev23 dans le forum Servlets/JSP
    Dernier message: 03/06/2008, 18h04
  3. Réponses: 1
    Dernier message: 09/10/2007, 06h44
  4. Problème avec les servlets sous eclipse
    Par supertoms dans le forum Tomcat et TomEE
    Dernier message: 03/03/2007, 19h07
  5. Interroger les valeur d1 [ javabean ] avec une [ servlet ]
    Par jmeclipse dans le forum Servlets/JSP
    Réponses: 21
    Dernier message: 07/06/2005, 12h14
