PIVOT INCLUDE NULLS
    Nouveau membre du Club
    Mai 2011
    Par défaut PIVOT INCLUDE NULLS
    la requête suivante ne recense pas les valeurs nulles (voir colonne COMPTE_NULL correspondant aux valeurs NULL de COL03)
    WITH TABLE_1 AS (
              SELECT '01' AS COL01 ,'11' AS COL02,'8011551' AS COL03,'002' AS COL04 FROM DUAL
    UNION ALL SELECT '01' AS COL01 ,'11' AS COL02,'8011551' AS COL03,'100' AS COL04 FROM DUAL
    UNION ALL SELECT '01' AS COL01 ,'11' AS COL02,'8011552' AS COL03,'100' AS COL04 FROM DUAL
    UNION ALL SELECT '01' AS COL01 ,'13' AS COL02,'8011553' AS COL03,'103' AS COL04 FROM DUAL
    UNION ALL SELECT '01' AS COL01 ,'13' AS COL02,'8011553' AS COL03,'104' AS COL04 FROM DUAL
    UNION ALL SELECT '02' AS COL01 ,'11' AS COL02,NULL AS COL03,'002' AS COL04 FROM DUAL
    UNION ALL SELECT '02' AS COL01 ,'11' AS COL02,NULL AS COL03,'100' AS COL04 FROM DUAL
    UNION ALL SELECT '02' AS COL01 ,'11' AS COL02,'7011551' AS COL03,'100' AS COL04 FROM DUAL
    UNION ALL SELECT '02' AS COL01 ,'11' AS COL02,'7011552' AS COL03,'100' AS COL04 FROM DUAL
    UNION ALL SELECT '02' AS COL01 ,'13' AS COL02,'7011553' AS COL03,'103' AS COL04 FROM DUAL
    UNION ALL SELECT '02' AS COL01 ,'13' AS COL02,'7011553' AS COL03,'104' AS COL04 FROM DUAL
    UNION ALL SELECT '03' AS COL01 ,'11' AS COL02,'9011551' AS COL03,'002' AS COL04 FROM DUAL
    UNION ALL SELECT '03' AS COL01 ,'11' AS COL02,'9011551' AS COL03,'100' AS COL04 FROM DUAL
    UNION ALL SELECT '03' AS COL01 ,'12' AS COL02,'9011551' AS COL03,'100' AS COL04 FROM DUAL
    UNION ALL SELECT '03' AS COL01 ,'12' AS COL02,'9011552' AS COL03,'100' AS COL04 FROM DUAL
    UNION ALL SELECT '03' AS COL01 ,'11' AS COL02,'9011552' AS COL03,'100' AS COL04 FROM DUAL
    UNION ALL SELECT '03' AS COL01 ,'15' AS COL02,'9011553' AS COL03,'103' AS COL04 FROM DUAL
    UNION ALL SELECT '03' AS COL01 ,'15' AS COL02,'9011553' AS COL03,'104' AS COL04 FROM DUAL
    SELECT
    FROM TABLE_1
    PIVOT (
      COUNT(COL04) FOR COL03  IN ('8011551' AS COMPTE_8011551,'7011551' AS COMPTE_7011551,'9011551' AS COMPE_9011551,NULL AS COMPTE_NULL)
    COL01 COL02 COMPTE_8011551 COMPTE_7011551 COMPE_9011551 COMPTE_NULL
    02    11                 0              1             0           0
    03    12                 0              0             1           0
    01    13                 0              0             0           0
    01    11                 3              0             0           0
    02    13                 0              0             0           0
    03    11                 0              0             2           0
    03    15                 0              0             0           0
     7 lignes sélectionnées
    Afin de résoudre ce problème ,j'ai converti les valeurs nulles de COL03,de la manière suivante:
    WITH TABLE_1 AS (
    ,TABLE_2 AS (
    SELECT
    COL01,COL02,NVL(COL03,'NULL') AS COL03,COL04
    FROM TABLE_1
    SELECT * FROM TABLE_2
    PIVOT (
      COUNT(COL04) FOR COL03  IN ('8011551' AS COMPTE_8011551,'7011551' AS COMPTE_7011551,'9011551' AS COMPE_9011551,'NULL' AS COMPTE_NULL)
    02    11                 0              1             0           2
    03    12                 0              0             1           0
    01    13                 0              0             0           0
    01    11                 3              0             0           0
    02    13                 0              0             0           0
    03    11                 0              0             2           0
    03    15                 0              0             0           0
    N'y avait-il pas une meilleure méthode?
    Membre averti Avatar de awalter1
    Août 2004
    avec la fonction DECODE ?
    DECODE(monchamp,null,'la valeur que tu veux signifier pour le null',monchamp)
    dba
    Janvier 2010
    Activité : dba
    Normal, le NULL sont éliminés par des opérations d'agrégat.
    Vous pouvez faire votre PIVOT "à l'ancienne" pour gérer vos NULL :
    SELECT
    		COL01,
    		COL02,
    		SUM(CASE WHEN COL03 = '8011551' THEN 1 ELSE 0 END) AS COMPTE_8011551,
    		SUM(CASE WHEN COL03 = '7011551' THEN 1 ELSE 0 END) AS COMPTE_7011551,
    		SUM(CASE WHEN COL03 = '9011551' THEN 1 ELSE 0 END) AS COMPTE_9011551,
    		SUM(CASE WHEN COL03 IS NULL THEN 1 ELSE 0 END) AS COMPTE_NULL
    FROM TABLE_1
    GROUP BY
    		COL01,
    		COL02
    Mai 2011
  1. Table pivoté - enlever les NULL
    Par markham dans le forum MySQL
    Dernier message: 22/02/2015, 10h17
  2. @FXML + include = null
    Par le y@m's dans le forum JavaFX
    Réponses: 12
    Dernier message: 06/07/2012, 09h05
  3. Problème de NULL sur un Pivot basé sur une Table Dynamique
    Par guilld dans le forum Développement
    Dernier message: 01/08/2011, 16h05
  4. [VB6] [BDD] Recordset et champ égal à Null
    Par Gr|ppen dans le forum VB 6 et antérieur
    Dernier message: 07/03/2003, 11h00
  5. "ALTERER" une col. NULL en NOT NULL - Int
    Par Gandalf24 dans le forum SQL
    Dernier message: 28/12/2002, 01h07
