Requètes XML, utilisation du ORDER BY
    Membre averti Avatar de awalter1
    Août 2004
    Par défaut Requètes XML, utilisation du ORDER BY
    Je m'aperçois que l'utilisation de la clause ORDER BY n'est pas possible dans les requètes XML. Je ne sais pas trop comment m'en passer. Voici un exemple :
    CREATE TABLE AIRWAY_TMP
    AIRWAY_NAME VARCHAR2(20) NOT NULL
    REM
    REM Index : AIRWAY_TMP_I1
    REM
    execute dropindex('AIRWAY_TMP')
    CREATE UNIQUE INDEX AIRWAY_TMP_I1
    ON AIRWAY_TMP
    AIRWAY_NAME ASC
    INSERT INTO AIRWAY_TMP (select 'A1' from dual);
    INSERT INTO AIRWAY_TMP (select 'A2' from dual);
    execute droptable ('AIRWAY_SECT_TMP')
    CREATE TABLE AIRWAY_SECT_TMP
    AIRWAY_NAME VARCHAR2(20) NOT NULL,
    POINT_NAME VARCHAR2(5) NOT NULL
    REM
    REM Index : AIRWAY_SECT_TMP_I1
    REM
    execute dropindex('AIRWAY_SECT_TMP')
    CREATE UNIQUE INDEX AIRWAY_SECT_TMP_I1
    ON AIRWAY_SECT_TMP
    AIRWAY_NAME ASC,
    POINT_NAME ASC
    INSERT INTO AIRWAY_SECT_TMP (select 'A1','PT1_1' from dual);
    INSERT INTO AIRWAY_SECT_TMP (select 'A1','PT1_2' from dual);
    INSERT INTO AIRWAY_SECT_TMP (select 'A2','PT2_1' from dual);
    INSERT INTO AIRWAY_SECT_TMP (select 'A2','PT2_2' from dual);
    INSERT INTO AIRWAY_SECT_TMP (select 'A2','PT2_3' from dual);
    SELECT XMLPARSE(document XMLSERIALIZE(document(
    SELECT
    XMLELEMENT("GraphicalLineList",
    (SELECT XMLAgg(
       XMLELEMENT("GraphicalLine",
          XMLELEMENT("PointList",a.AIRWAY_NAME),
    	(SELECT XMLAgg(
                 XMLELEMENT("GeographicalPoint",p.POINT_NAME))
    	  FROM AIRWAY_SECT_TMP p
    	  WHERE p.AIRWAY_NAME=a.AIRWAY_NAME))))
    FROM AIRWAY_TMP a)
    ) FROM dual
    ))) FROM dual;
    La requète me renvoie les lignes attendues :
    XMLPARSE(DOCUMENTXMLSERIALIZE(DOCUMENT(SELECTXMLELEMENT("GRAPHICALLINELIST",(SEL
    <GraphicalLineList>
      <GraphicalLine>
        <PointList>A1</PointList>
        <PointList>
          <GeographicalPoint>PT1_1</GeographicalPoint>
          <GeographicalPoint>PT1_2</GeographicalPoint>
        </PointList>
      </GraphicalLine>
      <GraphicalLine>
        <PointList>A2</PointList>
        <PointList>
          <GeographicalPoint>PT2_1</GeographicalPoint>
          <GeographicalPoint>PT2_2</GeographicalPoint>
          <GeographicalPoint>PT2_3</GeographicalPoint>
        </PointList>
      </GraphicalLine>
    </GraphicalLineList>
    Mais si j'ajoute un ORDER BY dans le sous select, j'ai :
    SQL> SELECT XMLPARSE(document XMLSERIALIZE(document(
    SELECT
      2    3  XMLELEMENT("GraphicalLineList",
      4  (SELECT XMLAgg(
      5     XMLELEMENT("GraphicalLine",
      6        XMLELEMENT("PointList",a.AIRWAY_NAME),
      7        XMLELEMENT("PointList",
      8     (SELECT XMLAgg(
      9               XMLELEMENT("GeographicalPoint",p.POINT_NAME))
     10       FROM AIRWAY_SECT_TMP p
     11       WHERE p.AIRWAY_NAME=a.AIRWAY_NAME ORDER BY p.POINT_NAME))))
     12  FROM AIRWAY_TMP a)
     13  ) FROM dual
     14  ))) FROM dual;
    ERROR at line 11:
    ORA-00907: missing right parenthesis
    Je ne vois pas ce qui empêche de trier. Comment puis je ordonner mes résultats ?
    Avatar de Waldar
    La fonction XMLAgg peut contenir un ORDER BY, je pense que c'est ce que vous cherchez.
    Oracle® Database SQL Language Reference - XMLAGG
  1. Probléme d'utilisation du order-by (XSLT/XML)
    Par lastico21000 dans le forum XSL/XSLT/XPATH
    Dernier message: 21/11/2011, 11h28
  2. Réponses: 2
    Dernier message: 10/04/2007, 11h46
  3. [SimpleXML] Comment exploiter le résultat d'une requête XML-RPC
    Par tiboel dans le forum Bibliothèques et frameworks
    Dernier message: 28/02/2006, 19h57
  4. Réponses: 6
    Dernier message: 21/07/2005, 16h56
  5. Problème requête avec UNION et ORDER BY
    Par Yann21 dans le forum Langage SQL
    Réponses: 12
    Dernier message: 12/12/2003, 11h02
