avec Java Discussion :
Probleme de débutant avec une class
avec Java
    Membre éclairé Avatar de hugoclo
    Décembre 2007
    Par défaut Probleme de débutant avec une class
    J'ai une petite appli qui contient plusieurs class dont celle ci
    import java.awt.BasicStroke;
    import java.awt.Color;
    import java.awt.Graphics2D;
    import java.awt.Rectangle;
    import java.awt.RenderingHints;
    import java.awt.geom.Point2D;
    import java.util.ArrayList;
    import java.util.List;
    import javax.swing.JFrame;
    import org.jdesktop.swingx.JXMapKit;
    import org.jdesktop.swingx.JXMapKit.DefaultProviders;
    import org.jdesktop.swingx.JXMapViewer;
    import org.jdesktop.swingx.mapviewer.GeoPosition;
    import org.jdesktop.swingx.painter.*;
    public class Starter {
        public static void main(final String[] args) {
            final JFrame f = new JFrame();
            f.setSize(500, 300);
            f.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
            final JXMapKit jXMapKit1 = new JXMapKit();
            jXMapKit1.setDefaultProvider(DefaultProviders.OpenStreetMaps);
            jXMapKit1.setCenterPosition(new GeoPosition(5.41984, 100.33924));
            jXMapKit1.setZoom(3);
            final List<GeoPosition> region = new ArrayList<GeoPosition>();
            region.add(new GeoPosition(5.42031, 100.34389));
            region.add(new GeoPosition(5.41984, 100.33924));
            region.add(new GeoPosition(5.42300, 100.33456));
            final Painter<JXMapViewer> lineOverlay = new Painter<JXMapViewer>() {
                            public void paint(Graphics2D g, final JXMapViewer map, final int w, final int h) {
                    g = (Graphics2D) g.create();
                    // convert from viewport to world bitmap
                    final Rectangle rect = jXMapKit1.getMainMap().getViewportBounds();
                    g.translate(-rect.x, -rect.y);
                    // do the drawing
                    g.setColor(Color.RED);
                    g.setRenderingHint(RenderingHints.KEY_ANTIALIASING, RenderingHints.VALUE_ANTIALIAS_ON);
                    g.setStroke(new BasicStroke(2));
                    int lastX = -1;
                    int lastY = -1;
                    for (final GeoPosition gp : region) {
                        // convert geo to world bitmap pixel
                        final Point2D pt = jXMapKit1.getMainMap().getTileFactory().geoToPixel(gp, jXMapKit1.getMainMap().getZoom());
                        if (lastX != -1 && lastY != -1) {
                            g.drawLine(lastX, lastY, (int) pt.getX(), (int) pt.getY());
                        lastX = (int) pt.getX();
                        lastY = (int) pt.getY();
                    g.dispose();
            jXMapKit1.getMainMap().setOverlayPainter(lineOverlay);
            f.setContentPane(jXMapKit1);
            f.setVisible(true);
    Comment faire pour "lancer" cette class en cliquant sur un bouton d'une autre class en lui envoyant le contenu d"un Jtextarea.
    Mai 2011
    euh...
    monBouton.addActionListener(new ActionListener() {
            String T[] = {monTextArea.getText()};
            Starter.main(T);
    Mais je sais pas si c'est ça que tu cherches.
    Décembre 2007
    Oui bien pris mais je me suis mal exprimé.
    import java.awt.BorderLayout;
    import java.util.HashSet;
    import javax.swing.JComponent;
    import javax.swing.JPanel;
    import javax.swing.SwingUtilities;
    import org.jdesktop.swingx.mapviewer.DefaultTileFactory;
    import org.jdesktop.swingx.mapviewer.DefaultWaypoint;
    import org.jdesktop.swingx.mapviewer.TileFactoryInfo;
    import org.jdesktop.swingx.mapviewer.Waypoint;
    import org.jdesktop.swingx.mapviewer.WaypointPainter;
    public class WSDemo {
        double lat,longi;
        class CustomPainter extends WaypointPainter<JXMapViewer> {
        public void setWaypoints(List<? extends Waypoint> waypoints) {
            super.setWaypoints(new HashSet<Waypoint>(waypoints));
        private JComponent createContent() {
            JComponent content = new JPanel();
            content.setLayout(new BorderLayout());
            content.add(createMapKit());
            return content;
        protected JComponent createMapKit() {
            final int max = 17;
            TileFactoryInfo info = new TileFactoryInfo(1, max - 2, max, 256, true,
                    true, // tile size is 256 and x/y orientation is normal
                    "file:/D:/Tiles",// 5/15/10.png",
                    "x", "y", "z") {
                public String getTileUrl(int x, int y, int zoom) {
                    zoom = max - zoom;
                    String url = this.baseURL + "/" + zoom + "/" + x + "/" + y
                            + ".png";
                    System.out.print(url + "\n");
                    return url;
            DefaultTileFactory tf = new DefaultTileFactory(info);
            tf.setThreadPoolSize(1);
            final JXMapKit kit = new JXMapKit();
            kit.setTileFactory(tf);
            kit.setZoom(12);
            kit.setAddressLocation(new GeoPosition(48, -3));
            kit.getMainMap().setDrawTileBorders(true);
            List<DefaultWaypoint> waypoints = new ArrayList<DefaultWaypoint>();
            waypoints.add(new DefaultWaypoint(51.5, -3));
            waypoints.add(new DefaultWaypoint(48, -5));
            CustomPainter painter = new CustomPainter();
            painter.setWaypoints(waypoints);
            kit.getMainMap().setOverlayPainter(painter);
            return kit;
            SwingUtilities.invokeLater(new Runnable() {
                public void run() {
                    JFrame frame = new JFrame("");
                    frame.setDefaultCloseOperation(JFrame.DISPOSE_ON_CLOSE);
                    frame.add(new WSDemo().createContent());
                    frame.setLocationByPlatform(true);
                    frame.setSize(900, 900);
                    frame.setVisible(true);
    mon args est un tableau contenant des coordonnée.
    Et j'ai besoin de ces coordonnées ici
            final int max = 17;
                    "x", "y", "z") {
                    zoom = max - zoom;
                            + ".png";
                    return url;
            kit.setZoom(12);
           //boucle ici
            return kit;
    Comme ca je fait une petite boucle sur mon tableau est je crée des Waypoints. Comment faire pour accéder au items de args.
    Septembre 2004
    Le plus simple est de le garder (sous forme de String[] par exemple) dans un champ de la classe WSDemo, et de le renseigner dans son constructeur.
        double lat,longi;
        String[] args;
        public WSDemo(String[] args) {
          this.args = args;
    Décembre 2007
    Merci pour la rapidité
    J'ai fait comme indiqué
    package modif.posit;
        double lat,longi;
        String[] args;
            return content;
            final int max = 17;
                    "x", "y", "z") {
                    zoom = max - zoom;
                            + ".png";
                    return url;
            kit.setZoom(12);
            return kit;
          this.args = args;
                public void run() {
    Et cela me crée une erreur sur cette ligne
  1. [Compilation] probleme de linking avec une classe
    Par deubelte dans le forum C++
    Dernier message: 17/02/2015, 23h19
  2. [2.x] probleme de syntaxe avec une classe
    Par adel25 dans le forum Symfony
    Dernier message: 01/09/2013, 22h39
  3. problem de vector avec une classe
    Par potterthekiller dans le forum SL & STL
    Dernier message: 19/03/2007, 11h11
  4. [débutant] probleme avec une classe arbre
    Par go_all_in dans le forum C++
    Réponses: 17
    Dernier message: 08/06/2006, 10h33
  5. Probleme avec une class template
    Par lenectar dans le forum Langage
    Dernier message: 01/03/2006, 10h49
