[ 9%] Building CXX object CMakeFiles/YesEngine.dir/YesEngine/Core/Renderer.cpp.obj
In file included from C:/workdir/awesome/poc1/lib/YesEngine/YesEngine/Maths/Vector3.inl:25:0,
from C:/workdir/awesome/poc1/lib/YesEngine/YesEngine/Maths/Vector3.h:132,
from C:/workdir/awesome/poc1/lib/YesEngine/YesEngine/Core/Renderer.h:38,
from C:\workdir\awesome\poc1\lib\YesEngine\YesEngine\Core\Renderer.cpp:29:
c:\qt\qt5.1.0\tools\mingw48_32\lib\gcc\i686-w64-mingw32\4.8.0\include\c++\cmath:97:37: error: '__is_integer' was not declared in this scope
typename __gnu_cxx::__enable_if<__is_integer<_Tp>::__value,
c:\qt\qt5.1.0\tools\mingw48_32\lib\gcc\i686-w64-mingw32\4.8.0\include\c++\cmath:97:37: note: suggested alternative:
In file included from c:\qt\qt5.1.0\tools\mingw48_32\lib\gcc\i686-w64-mingw32\4.8.0\include\c++\bits\stl_algobase.h:61:0,
from c:\qt\qt5.1.0\tools\mingw48_32\lib\gcc\i686-w64-mingw32\4.8.0\include\c++\bits\char_traits.h:39,
from c:\qt\qt5.1.0\tools\mingw48_32\lib\gcc\i686-w64-mingw32\4.8.0\include\c++\ios:40,
from c:\qt\qt5.1.0\tools\mingw48_32\lib\gcc\i686-w64-mingw32\4.8.0\include\c++\ostream:38,
from c:\qt\qt5.1.0\tools\mingw48_32\lib\gcc\i686-w64-mingw32\4.8.0\include\c++\iostream:39,
from C:/workdir/awesome/poc1/lib/YesEngine/YesEngine/Utilities/Color.h:32,
from C:/workdir/awesome/poc1/lib/YesEngine/YesEngine/Core/Renderer.h:31,
c:\qt\qt5.1.0\tools\mingw48_32\lib\gcc\i686-w64-mingw32\4.8.0\include\c++\bits\cpp_type_traits.h:136:12: note: 'std::__is_integer'
struct __is_integer
c:\qt\qt5.1.0\tools\mingw48_32\lib\gcc\i686-w64-mingw32\4.8.0\include\c++\cmath:97:53: error: wrong number of template arguments (1, should be 2)
In file included from c:\qt\qt5.1.0\tools\mingw48_32\lib\gcc\i686-w64-mingw32\4.8.0\include\c++\bits\stl_algobase.h:62:0,
c:\qt\qt5.1.0\tools\mingw48_32\lib\gcc\i686-w64-mingw32\4.8.0\include\c++\ext\type_traits.h:43:12: error: provided for 'template<bool <anonymous>, class> struct __gnu_cxx::__enable_if'
struct __enable_if
c:\qt\qt5.1.0\tools\mingw48_32\lib\gcc\i686-w64-mingw32\4.8.0\include\c++\cmath:97:54: error: expected identifier before '::' token
c:\qt\qt5.1.0\tools\mingw48_32\lib\gcc\i686-w64-mingw32\4.8.0\include\c++\cmath:97:63: error: invalid type in declaration before ',' token
c:\qt\qt5.1.0\tools\mingw48_32\lib\gcc\i686-w64-mingw32\4.8.0\include\c++\cmath:97:63: error: declaration of '__value' not in a namespace surrounding '::'
c:\qt\qt5.1.0\tools\mingw48_32\lib\gcc\i686-w64-mingw32\4.8.0\include\c++\cmath:97:63: error: '__value' should have been declared inside '::'
c:\qt\qt5.1.0\tools\mingw48_32\lib\gcc\i686-w64-mingw32\4.8.0\include\c++\cmath:97:63: error: '__value' declared as an 'inline' variable
c:\qt\qt5.1.0\tools\mingw48_32\lib\gcc\i686-w64-mingw32\4.8.0\include\c++\cmath:97:63: error: template declaration of 'int __value'
c:\qt\qt5.1.0\tools\mingw48_32\lib\gcc\i686-w64-mingw32\4.8.0\include\c++\cmath:102:11: error: '::acos' has not been declared
using ::acos;
c:\qt\qt5.1.0\tools\mingw48_32\lib\gcc\i686-w64-mingw32\4.8.0\include\c++\cmath:116:37: error: '__is_integer' was not declared in this scope
c:\qt\qt5.1.0\tools\mingw48_32\lib\gcc\i686-w64-mingw32\4.8.0\include\c++\cmath:116:37: note: suggested alternative:
struct __is_integer
c:\qt\qt5.1.0\tools\mingw48_32\lib\gcc\i686-w64-mingw32\4.8.0\include\c++\cmath:116:53: error: wrong number of template arguments (1, should be 2)
