| 12
 119
 120
 121
 122
 123
 124
 125
 126
 127
 128
 129
 130
 131
 132
 133
 134
 135
 136
 137
 138
 139
 140
 141
 142
 143
 144
 145
 146
 147
 148
typedef struct
    float	x, y;
} Point2D;
typedef struct
    Point2D p1, p2, p3;
} Triangle2D;
Triangle2D* Terrain::Process( int nb_points, Point2D *points, int& nb_triangles )
    /* allocate and initialize list of Vertices in polygon */
    Triangle2D *triangles = new Triangle2D[nb_points-2];
    nb_triangles = 0;
    int n = nb_points;
    if ( n < 3 ) return false;
    int *V = new int[n];
    /* we want a counter-clockwise polygon in V */
    if ( 0.0f < Area(nb_points, points) )
        for (int v=0; v<n; v++) V[v] = v;
    else
        for(int v=0; v<n; v++) V[v] = (n-1)-v;
    int nv = n;
    /*  remove nv-2 Vertices, creating 1 triangle every time */
    int count = 2*nv;   /* error detection */
    for(int m=0, v=nv-1; nv>2; )
        /* if we loop, it is probably a non-simple polygon */
        if (0 >= (count--))
            //** Triangulate: ERROR - probable bad polygon!
            //	delete[] triangles;
            printf( "Degenerate polygon\n" );
            return triangles;
        /* three consecutive vertices in current polygon, <u,v,w> */
        int u = v  ; if (nv <= u) u = 0;     /* previous */
        v = u+1; if (nv <= v) v = 0;     /* new v    */
        int w = v+1; if (nv <= w) w = 0;     /* next     */
        if ( Snip(nb_points, points,u,v,w,nv,V) )
            int a,b,c,s,t;
            /* true names of the vertices */
            a = V[u]; b = V[v]; c = V[w];
            /* output Triangle */
            /*   result.push_back( points[a] );
      result.push_back( points[b] );
      result.push_back( points[c] );*/
            triangles[nb_triangles].p1 = points[a];
            triangles[nb_triangles].p2 = points[b];
            triangles[nb_triangles].p3 = points[c];
            nb_triangles++;
            m++;
            /* remove v from remaining polygon */
            for(s=v,t=v+1;t<nv;s++,t++) V[s] = V[t]; nv--;
            /* resest error detection counter */
            count = 2*nv;
    delete V;
    return triangles;
float Terrain::Area( int nb_points, Point2D *points )
    int n = nb_points;
    float A=0.0f;
    for(int p=n-1,q=0; q<n; p=q++)
        A+= points[p].x*points[q].y - points[q].x*points[p].y;
    return A*0.5f;
bool Terrain::Snip( int nb_points, Point2D *points,int u,int v,int w,int n,int *V )
    int p;
    float Ax, Ay, Bx, By, Cx, Cy, Px, Py;
    Ax = points[V[u]].x;
    Ay = points[V[u]].y;
    Bx = points[V[v]].x;
    By = points[V[v]].y;
    Cx = points[V[w]].x;
    Cy = points[V[w]].y;
    if ( EPSILON > (((Bx-Ax)*(Cy-Ay)) - ((By-Ay)*(Cx-Ax))) ) return false;
    for (p=0;p<n;p++)
        if( (p == u) || (p == v) || (p == w) ) continue;
        Px = points[V[p]].x;
        Py = points[V[p]].y;
        if (InsideTriangle(Ax,Ay,Bx,By,Cx,Cy,Px,Py)) return false;
    return true;
bool Terrain::InsideTriangle(float Ax, float Ay,
                             float Bx, float By,
                             float Cx, float Cy,
                             float Px, float Py)
    float ax, ay, bx, by, cx, cy, apx, apy, bpx, bpy, cpx, cpy;
    float cCROSSap, bCROSScp, aCROSSbp;
    ax = Cx - Bx;  ay = Cy - By;
    bx = Ax - Cx;  by = Ay - Cy;
    cx = Bx - Ax;  cy = By - Ay;
    apx= Px - Ax;  apy= Py - Ay;
    bpx= Px - Bx;  bpy= Py - By;
    cpx= Px - Cx;  cpy= Py - Cy;
    aCROSSbp = ax*bpy - ay*bpx;
    cCROSSap = cx*apy - cy*apx;
    bCROSScp = bx*cpy - by*cpx;
    return ((aCROSSbp >= 0.0f) && (bCROSScp >= 0.0f) && (cCROSSap >= 0.0f));
