1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
| #ifdef __cplusplus
#include <cstdlib>
#else
#include <stdlib.h>
#endif
#include <SDL/SDL.h>
int main ( int argc, char** argv )
// initialize SDL video
if ( SDL_Init( SDL_INIT_VIDEO ) < 0 )
printf( "Unable to init SDL: %s\n", SDL_GetError() );
return 1;
// make sure SDL cleans up before exit
atexit(SDL_Quit);
// create a new window
SDL_Surface* screen = SDL_SetVideoMode(640, 480, 16,
SDL_HWSURFACE|SDL_DOUBLEBUF);
if ( !screen )
printf("Unable to set 640x480 video: %s\n", SDL_GetError());
return 1;
// load an image
SDL_Surface* bmp = SDL_LoadBMP("cb.bmp");
if (!bmp)
printf("Unable to load bitmap: %s\n", SDL_GetError());
return 1;
// centre the bitmap on screen
SDL_Rect dstrect;
dstrect.x = (screen->w - bmp->w) / 2;
dstrect.y = (screen->h - bmp->h) / 2;
// program main loop
bool done = false;
while (!done)
// message processing loop
SDL_Event event;
while (SDL_PollEvent(&event))
// check for messages
switch (event.type)
// exit if the window is closed
case SDL_QUIT:
done = true;
break;
// check for keypresses
case SDL_KEYDOWN:
// exit if ESCAPE is pressed
if (event.key.keysym.sym == SDLK_ESCAPE)
done = true;
break;
} // end switch
} // end of message processing
// DRAWING STARTS HERE
// clear screen
SDL_FillRect(screen, 0, SDL_MapRGB(screen->format, 0, 0, 0));
// draw bitmap
SDL_BlitSurface(bmp, 0, screen, &dstrect);
// DRAWING ENDS HERE
// finally, update the screen :)
SDL_Flip(screen);
} // end main loop
// free loaded bitmap
SDL_FreeSurface(bmp);
// all is well ;)
printf("Exited cleanly\n");
return 0;
