Formatage d'un JTextField en temps réel
    Ingénieur de construction de réseaux
    Août 2012
    Activité : Ingénieur de construction de réseaux
    Par défaut Formatage d'un JTextField en temps réel
    Bonjour à tous j'ai effectué des recherches sur le net et j'ai decouvert un code pour formater mon JTextField:
    119
    120
    121
    122
    123
    124
    125
    126
    127
    128
    129
    130
    131
    132
    133
    134
    135
    136
    137
    138
    139
    140
    141
    142
    143
    144
    145
    146
    147
    148
    149
    150
    151
    152
    153
    154
    155
    156
    157
    158
    159
    160
    161
    162
    163
    164
    165
    166
    167
    168
    169
    170
    171
    172
    173
    174
    175
    176
    177
    178
    179
    180
    181
    182
    183
    184
    185
    186
    187
    188
    189
    import java.awt.*;
    import java.awt.event.*;
    import javax.swing.*;
    import javax.swing.event.*;
    import javax.swing.text.*;
    import java.beans.PropertyChangeListener;
    import java.beans.PropertyChangeEvent;
    import java.text.*;
     * FormattedTextFieldDemo.java is a 1.4 example that
     * requires no other files.
     * It implements a mortgage calculator that uses four
     * JFormattedTextFields.
    public class FormattedTextFieldDemo extends JPanel
                                        implements PropertyChangeListener {
        //Values for the fields
        private double amount = 100000;
        private double rate = 7.5;  //7.5%
        private int numPeriods = 30;
        //Labels to identify the fields
        private JLabel amountLabel;
        private JLabel rateLabel;
        private JLabel numPeriodsLabel;
        private JLabel paymentLabel;
        //Strings for the labels
        private static String amountString = "Loan Amount: ";
        private static String rateString = "APR (%): ";
        private static String numPeriodsString = "Years: ";
        private static String paymentString = "Monthly Payment: ";
        //Fields for data entry
        private JFormattedTextField amountField;
        private JFormattedTextField rateField;
        private JFormattedTextField numPeriodsField;
        private JFormattedTextField paymentField;
        //Formats to format and parse numbers
        private NumberFormat amountFormat;
        private NumberFormat percentFormat;
        private NumberFormat paymentFormat;
        public FormattedTextFieldDemo() {
            super(new BorderLayout());
            setUpFormats();
            double payment = computePayment(amount,
                                            rate,
                                            numPeriods);
            //Create the labels.
            amountLabel = new JLabel(amountString);
            rateLabel = new JLabel(rateString);
            numPeriodsLabel = new JLabel(numPeriodsString);
            paymentLabel = new JLabel(paymentString);
            //Create the text fields and set them up.
            amountField = new JFormattedTextField(amountFormat);
            amountField.setValue(new Double(amount));
            amountField.setColumns(10);
            amountField.addPropertyChangeListener("value", this);
            rateField = new JFormattedTextField(percentFormat);
            rateField.setValue(new Double(rate));
            rateField.setColumns(10);
            rateField.addPropertyChangeListener("value", this);
            numPeriodsField = new JFormattedTextField();
            numPeriodsField.setValue(new Integer(numPeriods));
            numPeriodsField.setColumns(10);
            numPeriodsField.addPropertyChangeListener("value", this);
            paymentField = new JFormattedTextField(paymentFormat);
            paymentField.setValue(new Double(payment));
            paymentField.setColumns(10);
            paymentField.setEditable(false);
            paymentField.setForeground(Color.red);
            //Tell accessibility tools about label/textfield pairs.
            amountLabel.setLabelFor(amountField);
            rateLabel.setLabelFor(rateField);
            numPeriodsLabel.setLabelFor(numPeriodsField);
            paymentLabel.setLabelFor(paymentField);
            //Lay out the labels in a panel.
            JPanel labelPane = new JPanel(new GridLayout(0,1));
            labelPane.add(amountLabel);
            labelPane.add(rateLabel);
            labelPane.add(numPeriodsLabel);
            labelPane.add(paymentLabel);
            //Layout the text fields in a panel.
            JPanel fieldPane = new JPanel(new GridLayout(0,1));
            fieldPane.add(amountField);
            fieldPane.add(rateField);
            fieldPane.add(numPeriodsField);
            fieldPane.add(paymentField);
            //Put the panels in this panel, labels on left,
            //text fields on right.
            setBorder(BorderFactory.createEmptyBorder(20, 20, 20, 20));
            add(labelPane, BorderLayout.CENTER);
            add(fieldPane, BorderLayout.LINE_END);
        /** Called when a field's "value" property changes. */
        public void propertyChange(PropertyChangeEvent e) {
            Object source = e.getSource();
            if (source == amountField) {
                amount = ((Number)amountField.getValue()).doubleValue();
            } else if (source == rateField) {
                rate = ((Number)rateField.getValue()).doubleValue();
            } else if (source == numPeriodsField) {
                numPeriods = ((Number)numPeriodsField.getValue()).intValue();
            double payment = computePayment(amount, rate, numPeriods);
         * Create the GUI and show it.  For thread safety,
         * this method should be invoked from the
         * event-dispatching thread.
        private static void createAndShowGUI() {
            //Make sure we have nice window decorations.
            JFrame.setDefaultLookAndFeelDecorated(true);
            //Create and set up the window.
            JFrame frame = new JFrame("FormattedTextFieldDemo");
            frame.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
            //Create and set up the content pane.
            JComponent newContentPane = new FormattedTextFieldDemo();
            newContentPane.setOpaque(true); //content panes must be opaque
            frame.setContentPane(newContentPane);
            //Display the window.
            frame.pack();
            frame.setVisible(true);
            //Schedule a job for the event-dispatching thread:
            //creating and showing this application's GUI.
            javax.swing.SwingUtilities.invokeLater(new Runnable() {
                public void run() {
                    createAndShowGUI();
        //Compute the monthly payment based on the loan amount,
        //APR, and length of loan.
        double computePayment(double loanAmt, double rate, int numPeriods) {
            double I, partial1, denominator, answer;
            numPeriods *= 12;        //get number of months
            if (rate > 0.01) {
                I = rate / 100.0 / 12.0;         //get monthly rate from annual
                partial1 = Math.pow((1 + I), (0.0 - numPeriods));
                denominator = (1 - partial1) / I;
            } else { //rate ~= 0
                denominator = numPeriods;
            answer = (-1 * loanAmt) / denominator;
            return answer;
        //Create and set up number formats. These objects also
        //parse numbers input by user.
        private void setUpFormats() {
            amountFormat = NumberFormat.getNumberInstance();
            percentFormat = NumberFormat.getNumberInstance();
            percentFormat.setMinimumFractionDigits(3);
            paymentFormat = NumberFormat.getCurrencyInstance();
    Le soucis avec ce code c'est qu'il ne formate pas le JTextField en temps réel (à l'instant ou on saisie) mais plutôt lorsqu'on sélectionne un autre composant. Comment puis-je faire si je veux qu'il se formate au moment où on saisie le montant?
    Développeur java, access, sql server
    Octobre 2005
    Activité : Développeur java, access, sql server
    avec un MaskFormatter
    mais je crois que c'est incompatible avec les autres systèmes de format
    Labor improbus omnia vincit un travail acharné vient à bout de tout - Ambroise Paré (1510-1590)
    Consulter sans modération la FAQ ainsi que les bons ouvrages : http://jmdoudoux.developpez.com/cours/developpons/java/
    Avatar de joel.drigo
    Septembre 2009
    Le format d'un JFormattedTextField ne définit absolument aucune règle sur ce qu'on peut saisir ou pas, et comment le saisir : il permet uniquement de dire comment la valeur stockée dans le modèle du JFormattedTextField est formatée pour être affichée.
    Déjà, si tu vas un peu plus loin dans le tutoriel d'Oracle, d'où tu as tiré l'exemple, tu verras 2 choses (avec 2 codes exemples fournis) :
    • Qu'on peut choisir un format spécifique pour l'affichage, l'édition (comprendre l'affichage quand le champ à le focus), ou un format spécial lorsque la valeur dans le modèle est null.
    • Le MaskFormatter qui peut permettre un début de traitement de la saisie : tu peux déterminer certains caractères et leur emplacement, ce qui est pratique pour saisir des codes de carte bleu, numéro de téléphone, des trucs comme ça. Mais tu pourras difficilement définir des règles complexes, comme par exemple, qu'un pourcentage ne doit pas être supérieur à 100, ou que le champs ne permet de saisir que de l'hexadecimal
    Pour contrôler finement la saisie, c'est à dire quels caractères peuvent être saisis, quand, qu'est-ce qu'il se passe quand on entre un point ou une virgule, le plus simple, à mon avis est de passer par un DocumentFilter. Il te permettra de facilement empêcher d'avoir 2 virgules dans un même nombre décimal, de gérer proprement les caractères séparateurs spécifiques (genre les / de date, ou le % pour un pourcentage), de limiter les valeurs (borne inférieure, borne supérieure, nombre de chiffres après la virgule), le - seulement en première position, etc...
    Cependant, attends-toi à pas mal de boulot. Peut-être trouve-t-on des APIs ou des petits sources où le plus gros du travail est fait, et il te reste plus qu'à ajuster à tes besoins.
    Août 2012
    tout ce que j'aimerais faire c'est avoir un champ qui me permet de saisir les montants ex : 1000 deviens 1 000, 10000 deviens 10 000 etc. avez vous des pistes?
    Octobre 2005
    Oui, mais non !!!!
    Junior, ça ne peut pas marcher car pendant la saisie, on ne peut pas savoir si on va avoir
    10000
    il est plus raisonnable d'attendre la fin de la saisie pour mettre en forme
    Septembre 2009
    Bah, c'est ce que fait le code que tu as mis en exemple (l'exemple du tuto d'Oracle), mais tu demandais que cela le fasse en temps réel. Le formateur par défaut d'un JTextFormattedField fait exactement ce que tu demandes : à la validation, il prend la saisie, la formate conformément au format, la rejette éventuellement en cas d'incompatibilité, et donc quand on saisit "1000" avec un format #,##0 on obtient "1 000". Pour avoir une saisie en temps réel, donc si je tape 1, 0, 0, 0, avant même de faire entrée, j'ai '1',' ','0','0' et '0' qui s'affiche, il faut suivre ce que j'ai indiqué dans mon message (toutes les pistes y sont). Comme tu parlais de temps réel, je n'ai pas parlé d'InputVerifier qui permet de tester la valeur saisie à la validation (genre pour la borner par exemple) - à la validation, donc pas en temps réel.
    Août 2012
    Pouvez-vous être plus clair s'il vous plait je commence comment?
    Septembre 2009
    Citation Envoyé par Népomucène Voir le message
    Ça peut se faire en temps réel, mais ça demande un peu de boulot, et ça peut en effet donner des fois résultats un peu étrange. Par exemple si te tapes 1000, donc : 1, 0, 0 et 0, on obtient comme affichage "1", "10", "100" puis "1 000" (au lieu de "1", "1 0", "1 00", "1 000"), parce que justement on ne peut pas connaitre le nombre saisi avec la fin de la saisie, et qu'en plus on pourrait abandonner la saisie en cours, et du coup au aurait une espace qui se déplace (on passerait de "1 0" à "10" par exemple), ce qui serait des plus bizarre.
    Août 2012
    Citation Envoyé par joel.drigo Voir le message
    Ok et si je veux partir sur la base que le formatage se fait à la fin de la saisie qu'est ce que je fais?
    Septembre 2009
    Citation Envoyé par junior222 Voir le message
    Peut-être par regarder les tutoriels et javadoc sur DocumentFilter, pour commencer ? Ensuite, il faut bien réfléchir à ce que signifie saisir un nombre en temps réel en suivant un format. Par exemple, avoir noté l'aspect souliné par Nepomucene, le fait que si on saisit autre chose que du numérique, il faut l'ignorer tout de suite, que se passe-t-il si on supprime tout (on affiche 0, ou rien ?), etc... Après, il ne reste plus qu'à coder le DocumentFilter pour que ces règles soient respectées...
    Ensuite, pour t'éviter de galérer sur un truc, contrairement à l'usage classique, on ne met pas le DocumentFilter sur le Document du JTextFormattedField, mais sur le "formateur" (la classe qui étend AbstractFormatter) : donc regardes le source de javax.swing.text.DefaultFormatter (l'implémentation par défaut de cette abstraction), pour voir son DocumentFilter. Ensuite, il suffira de fournir ta propre JFormattedTextField.AbstractFormatterFactory (voir tutoriel Oracle pour savoir à quoi ça correspond), pour pour intégrer un AbstractFormatter avec un DocumentFilter personnalisé.
    Septembre 2009
    C'est ce que fait le code que tu as mis dans ton premier message Il y a bien une petite erreur dans le code je crois (au niveau du format %), mais c'est ce que ça fait : si tu tapes un nombre dans le premier champ et que tu valides la saisie (tu changes de champ par exemple), le champ se formate en fonction du motif donné en argument. Si tu tapes 1000 dans Loan amount, tu obtiendras bien "1 000".
    A noter que la touche entrée ne valide pas par défaut la saisie, contrairement à ce qu'on pourrait s'attendre : c'est ça qui te gène ? Tu dois pouvoir faire ça en ajoutant un ActionListener et en y appelant commitEdit() sur le champ.
    D'autre part, je t'avais dit de regarder les autres exemples du tutoriel, justement parce qu'ils allaient un peu plus loin.
    Août 2012
    voilà ce que j'ai fais sans succès:
            amountField.addActionListener(new ActionListener() {
            	public void actionPerformed(ActionEvent arg0) {
            		try {
    					amountField.commitEdit();
    				} catch (ParseException e) {
    					// TODO Auto-generated catch block
    					e.printStackTrace();
    Septembre 2009
    Pour que le commitEdit() fonctionne, il faut des conditions particulières en effet (champ + bouton, plus définir le champ en focusRoot).
    Comme ça, ça sera plus simple (mais ça ne fonctionne pas avec un seul champ) :
    public class DemoJTextFormattedField {
    		JFrame frame = new JFrame("Démo");
    		frame.getContentPane().add(createPanel());
    		frame.pack();
    		frame.setLocationRelativeTo(null);
    	private static Component createPanel() {
    		JPanel panel = new JPanel();
    		panel.setLayout(new FlowLayout());
    		panel.add(createField("#,##0"));
    		panel.add(createField("#,##0.00"));
    		return panel;
    	private static Component createField(String pattern) {
    		DecimalFormat format = new DecimalFormat(pattern);
    		NumberFormatter formatter = new NumberFormatter(format);
    		final JFormattedTextField field = new JFormattedTextField(
    				new DefaultFormatterFactory(
    						formatter,
    						formatter,
    						formatter));
    		field.setColumns(10);
    		field.addActionListener(new ActionListener() {
    			@Override
    				field.transferFocus();
    				field.requestFocus();
    		return field;
    Août 2012
    Je viens de le constater y aurait-il pas un moyen de remédier à cela j'ai essayer ceci en vin:
    		//panel.add(createField("#,##0.00"));
    Août 2012
    Bon j'ai trouvé la solution:
    formattedTextField = new JFormattedTextField(NumberFormat.getInstance());
  1. Mise à jour en temps réel de la base de données
    Par Clotilde dans le forum Bases de données
    Dernier message: 11/06/2004, 22h09
  2. [MFC] graphique temps réel
    Par _Thomas_ dans le forum MFC
    Dernier message: 01/06/2004, 11h56
  3. Voir requête éxécuté en temps réel ?
    Par [DreaMs] dans le forum MS SQL Server
    Dernier message: 08/01/2004, 14h52
  4. cubes temps réel en ROLAP
    Par Guizz dans le forum MS SQL Server
    Dernier message: 09/07/2003, 16h36
  5. Durée d'un traitement temps réel
    Par Almex dans le forum C
    Dernier message: 29/03/2003, 14h15
