1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83
| package fr.foox.launchercreator;
import java.io.File;
import java.io.IOException;
import java.io.InputStream;
import java.io.OutputStream;
import java.io.PrintStream;
import java.util.HashMap;
import java.util.Map;
import java.util.Scanner;
import org.apache.commons.io.FileUtils;
import org.newdawn.slick.Image;
import org.newdawn.slick.SlickException;
public class ConfigManager
private static Map<String, String> config = new HashMap();
private static Map<String, Image> imgs = new HashMap();
public void readConfig()
System.out.println("Lecture du fichier config en cours...");
InputStream is = this.getClass().getResourceAsStream("/fr/foox/launcherCreator/ressources/config.txt");
Scanner scan = new Scanner(is);
do{
String line = scan.nextLine();
if(line.contains("="))
config.put(line.split("=")[0], line.split("=")[1]);
while(scan.hasNextLine());
scan.close();
System.out.println("Lecture du fichier config terminé !");
System.out.println("Lancement du Launcher...");
public static String get(String option)
return config.get(option);
public static void DeleteOldInstallation() throws Exception{
String dir = Util.getWorkingDirectory().getCanonicalPath().replace(config.get("emplacement"), config.get("123unknownwindowsdir"));
File f = new File(dir);
if(f.exists() && f.isDirectory())
FileUtils.deleteQuietly(f);
public static Image select(String key){
return imgs.get(key);
public static void put(String key, String img_name)
try {
Image img = new Image("fr/foox/launchercreator/ressources/" + img_name);
imgs.put(key, img);
System.out.println("Image " + key + " chargée ! ("+img_name+")");
} catch (SlickException e) {
System.err.println("Impossible de charger l'image '"+key+"' ("+img_name+")");
private void ObfuscateStandartLogging()
System.setOut(new PrintStream(new OutputStream() {
@Override
public void write(int arg0) throws IOException {
String l = Long.toHexString(Double.doubleToLongBits(Math.random()));
System.err.println(l+l+l+l+l+l);
