1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
#include <windows.h>
#include <stdio.h>
#define ID_CHECKBOX_1 113
#define WMAP_KEYBDHOOKMSG WM_APP + 1
HINSTANCE instance;
typedef void (*TInitFunc) (HWND);
typedef void (*TEndFunc) ();
bool bHook;
int nbEntree;
TInitFunc InitHooks; // fonction d'initialisation des hooks
TEndFunc EndHooks; // fonction de suppression des hooks
HINSTANCE hinstDLL; // instance de la DLL
/* Declare Windows procedure */
LRESULT CALLBACK procedureFenetrePrincipale (HWND, UINT, WPARAM, LPARAM);
VOID RemplieFenetrePrincipale(HWND fenetrePrincipale);
VOID NotificationControle(HWND fenetrePrincipale,UINT message, WPARAM wParam, LPARAM lParam);
VOID ActionCheckBox(int index,HWND hCtl,HWND fenetrePrincipale);
void dessineTexte (HWND fenetreCiblee, char *chaine, int left, int top);
int WINAPI WinMain (HINSTANCE cetteInstance, HINSTANCE precedenteInstance, LPSTR lignesDeCommande, int modeDAffichage) {
HWND fenetrePrincipale; /* This is the handle for our window */
MSG messages; /* Here messages to the application are saved */
WNDCLASS classeFenetre; /* Data structure for the windowclass */
/* The Window structure */
classeFenetre.style = 0; /* None */
classeFenetre.lpfnWndProc = procedureFenetrePrincipale; /* This function is called by windows */
classeFenetre.cbClsExtra = 0; /* No extra bytes after the window class */
classeFenetre.cbWndExtra = 0; /* No extra bytes after the window class */
classeFenetre.hInstance = NULL;
classeFenetre.hIcon = LoadIcon (NULL, IDI_APPLICATION);
classeFenetre.hCursor = LoadCursor (NULL, IDC_ARROW);
classeFenetre.hbrBackground = (HBRUSH)(1 + COLOR_BTNFACE);
classeFenetre.lpszMenuName = NULL; /* No menu */
classeFenetre.lpszClassName = "classeF";
/* Register the window class, and if it fails quit the program */
if (!RegisterClass(&classeFenetre)) return FALSE;
/* The class is registered, let's create the program*/
fenetrePrincipale = CreateWindow(
"classeF",
"Première fenêtre en winAPI !",
WS_OVERLAPPEDWINDOW, /*Style qui permet d'avoir une fenêtre tout ce qu'il y a de plus normale : barre de titre, menu système (réduire, maximiser, fermer), bordure etc...*/
CW_USEDEFAULT, // Permet à l'OS de déterminer dynamiquement la position de la fenêtre
CW_USEDEFAULT, //Idem
450,
320,
NULL, // Pas de fenêtre parent, puisque c'est la principale
NULL, //Aucun menu ne lui est associé
cetteInstance,
NULL); // Aucun paramètre à lui envoyer en plus
if (!fenetrePrincipale) return FALSE;
/* Make the window visible on the screen */
ShowWindow(fenetrePrincipale, modeDAffichage);
UpdateWindow(fenetrePrincipale);
/* Run the message loop. It will run until GetMessage() returns 0 */
while (GetMessage(&messages, NULL, 0, 0)) {
/* Translate virtual-key messages into character messages */
TranslateMessage(&messages);
/* Send message to WindowProcedure */
DispatchMessage(&messages);
/* The program return-value is 0 - The value that PostQuitMessage() gave */
return messages.wParam;
/* This function is called by the Windows function DispatchMessage() */
LRESULT CALLBACK procedureFenetrePrincipale(HWND fenetrePrincipale, UINT message, WPARAM wParam, LPARAM lParam) {
char texte[] = "Pressions de ENTREE : 0";
switch (message) {
case WM_CREATE:
RemplieFenetrePrincipale(fenetrePrincipale);
return 0;
case WM_PAINT:
sprintf(texte, "Pressions de ENTREE : %d",nbEntree);
dessineTexte(fenetrePrincipale, texte, 20, 80);
return 0;
case WM_COMMAND:
NotificationControle(fenetrePrincipale,message,wParam,lParam);
return 0;
case WM_DESTROY:
if (bHook) EndHooks();
PostQuitMessage(0);
return 0;
default:
return DefWindowProc(fenetrePrincipale, message, wParam, lParam);
VOID RemplieFenetrePrincipale(HWND fenetrePrincipale) {
HWND hGroup = CreateWindow(
"BUTTON",
"La check box",
WS_CHILD|WS_VISIBLE|BS_GROUPBOX,
10,10,
200,50,
fenetrePrincipale,
NULL,
instance,
NULL);
HWND hControle;
// une check box automatique deux états
hControle=CreateWindow(
"BUTTON",
"Hook (ON/OFF)",
WS_CHILD|WS_VISIBLE|BS_AUTOCHECKBOX,
10+10,10+20,
180,20,
fenetrePrincipale,
(HMENU)ID_CHECKBOX_1,
instance,
NULL);
bHook = false;
hinstDLL = LoadLibrary("hook.dll");
if (!hinstDLL) // Erreur lors du chargement de la librairie ?
MessageBox(fenetrePrincipale,"Impossible de charger la librairie.","gloups",MB_OK);
else {
// On récupère les adresses des fonctions
InitHooks = (TInitFunc)GetProcAddress(hinstDLL, "InitHook");
EndHooks = (TEndFunc)GetProcAddress(hinstDLL, "EndHook");
VOID NotificationControle(HWND fenetrePrincipale,UINT message, WPARAM wParam, LPARAM lParam) {
UINT iId=LOWORD(wParam);
HWND hCtl=(HWND)lParam;
switch(iId) {
case ID_CHECKBOX_1:
ActionCheckBox(iId-ID_CHECKBOX_1,hCtl,fenetrePrincipale);
break;
VOID ActionCheckBox(int index,HWND hCtl,HWND fenetrePrincipale) {
// test si la check box est cochée, non cochée ou inderterminée.
LRESULT lRes=SendMessage(hCtl,BM_GETCHECK,0,0);
CHAR lpMessage[128];
sprintf(lpMessage,"La check box n°%d est maintenant %s",index,
(lRes==BST_CHECKED)?"cochée":
(lRes==BST_UNCHECKED)?"décochée":"inderterminée");
MessageBox(fenetrePrincipale,lpMessage,"Vous avez modifié une check box",
MB_ICONINFORMATION|MB_OK);
if (hinstDLL) { // Vérifie que la librairie est chargée, sinon, inutile de continuer
if (lRes==BST_CHECKED) { // Activer les hooks
nbEntree = 0; // On réinitialise le compteur
InitHooks(fenetrePrincipale); // On initialise les hooks
} else { // Désactiver les hooks
EndHooks(); // On supprime les hooks
void dessineTexte(HWND fenetreCiblee, char *chaine, int left, int top) {
//Déclarations préalables
PAINTSTRUCT ps;
HDC dc;
//Récupération de la surface de dessin dans dc
dc = BeginPaint(fenetreCiblee, &ps);
//Permet au texte d'avoir un fond transparent
SetBkMode(dc, TRANSPARENT);
//Applique la couleur de texte au dc
SetTextColor(dc, 0x00000000);
//Affichage du texte
TextOut(dc, left, top, chaine, strlen(chaine));
//TextOut(dc, 40, 50, "Toto", 4);
//Libération de la surface et du dc
EndPaint(fenetreCiblee, &ps);
return;
