ORA-00933: la commande SQL ne se termine pas correctement
    Candidat au Club
    Ressources humaines
    Février 2017
    Par défaut ORA-00933: la commande SQL ne se termine pas correctement
    J'ai un petit problème et je n'arrive pas à trouver la solution.
    Oracle m'affiche ceci
    00933. 00000 - "SQL command not properly ended"
    *Cause:
    *Action:
    Erreur à la ligne 33, colonne 16
    Voici mon programme :
    select numr_pers, dcd
    from
      (select  tbase.numr_pers, dcd,  nvl(tcorrection.correction_manu,0) as correction_manu, nvl(tdeja.deja_dcd,0) as deja_dcd
      from
      (select distinct numr_pers, first_value(valr_aprs_evnm) over (partition by numr_pers order by date_oprt desc ,heur_oprt desc) dcd
      from daud_cre_admin
      where code_evnm='DC02016'
      and perd_arrt_info>=to_char((select date_debt_semn -7 from rdwh.periode_rest_bo),'YYYYMM')
      and date_oprt>=(select date_debt_semn -7  from rdwh.periode_rest_bo)
      and date_oprt<=(select date_fin_semn -7  from rdwh.periode_rest_bo)
      and add_months(date_nais,216)<=date_oprt -- exclusion mineur
      and valr_aprs_evnm is not null) tbase
      left join
        -- on exclut les clients pour lesquels il y a une correction
          (select numr_pers, 1 as correction_manu
            from
              (select distinct numr_pers , first_value(valr_aprs_evnm) over(partition by numr_pers order by date_oprt desc, heur_oprt desc) as etat_dcd
                from daud_cre_admin
              and perd_arrt_info<=to_char((select date_debt_semn  from rdwh.periode_rest_bo),'YYYYMM')
              and date_oprt<=(select date_fin_semn from rdwh.periode_rest_bo))
           where etat_dcd is null) tcorrection on tbase.numr_pers = tcorrection .numr_pers
      left join
      -- on exclut les clients pour lesquels un deces a deja ete saisi 2 semaine avant
          (select distinct numr_pers, 1 as deja_dcd
            from daud_cre_admin
          and perd_arrt_info<=to_char((select date_debt_semn -7 from rdwh.periode_rest_bo),'YYYYMM')
          and date_oprt<(select date_debt_semn -7 from rdwh.periode_rest_bo)
          and valr_aprs_evnm is not null) tdeja   on tbase.numr_pers = tdeja .numr_pers
    where correction_manu = 0 -- exclusion détenteurs de credit immo
    and deja_dcd =0)cible
    Est-ce quelqu'un peut m'aider à résoudre mon problème ?
    Cordialement,
    Avatar de Sunchaser
    OPNI (Objet Programmant Non Identifié)
    Décembre 2004
    Activité : OPNI (Objet Programmant Non Identifié)
    Secteur : Industrie Pharmaceutique
    En regardant les parenthéses et "qui ferme quoi", on dirait que ")cible" ne corresponds a rien.
    Cette parenthése m'a l'air de trop ...
    Software engineer
    Juin 2007
    Activité : Software engineer
    Effectivement, parenthèse fermente de trop
    "L'homme ne devient Homme que par éducation."
    "Des pensées sans contenu sont vides, des intuitions sans concepts, aveugles."
    "Une proposition incorrecte est forcément fausse, mais une proposition correcte n'est pas forcément vraie."
    Emmanuel Kant
    Mon guide du débutant pour apprendre à programmer en Java - N'oubliez pas de consulter les FAQ Java et les cours et tutoriels Java
  1. Réponses: 3
    Dernier message: 08/07/2016, 14h59
  2. Réponses: 7
    Dernier message: 19/05/2011, 19h13
  3. ORA-00933: la commande SQL ne se termine pas correctement
    Par DeveloppeurWeb dans le forum ASP
    Dernier message: 12/04/2010, 12h56
  4. Réponses: 5
    Dernier message: 21/08/2007, 13h47
  5. ORA-00933 la commande SQL ne se termine pas correctement
    Par habasque dans le forum Sql*Plus
    Dernier message: 09/12/2006, 14h41
