1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106
import java.awt.Color;
import java.awt.Graphics;
import java.awt.Graphics2D;
import java.awt.GraphicsConfiguration;
import java.awt.GraphicsEnvironment;
import java.awt.RenderingHints;
import java.awt.Transparency;
import java.awt.image.BufferedImage;
import java.awt.image.ColorModel;
import java.awt.image.ComponentSampleModel;
import java.awt.image.DataBuffer;
import java.awt.image.DataBufferByte;
import java.awt.image.DataBufferInt;
import java.awt.image.SampleModel;
import java.awt.image.SinglePixelPackedSampleModel;
import java.awt.image.WritableRaster;
import java.io.IOException;
import java.net.URL;
import javax.imageio.ImageIO;
public class GraphicsUtil {
private static GraphicsConfiguration configuration = GraphicsEnvironment.getLocalGraphicsEnvironment().getDefaultScreenDevice().getDefaultConfiguration();
private GraphicsUtil() {
public static BufferedImage createCompatibleImage(int width, int height) {
return configuration.createCompatibleImage(width, height);
public static BufferedImage createTranslucentCompatibleImage(int width, int height) {
return configuration.createCompatibleImage(width, height, Transparency.TRANSLUCENT);
public static BufferedImage loadCompatibleImage(URL resource) throws IOException {
BufferedImage image = ImageIO.read(resource);
return toCompatibleImage(image);
public static BufferedImage toCompatibleImage(BufferedImage image) {
BufferedImage compatibleImage = configuration.createCompatibleImage(image.getWidth(),
image.getHeight(), Transparency.TRANSLUCENT);
Graphics g = compatibleImage.getGraphics();
g.drawImage(image, 0, 0, null);
g.dispose();
return compatibleImage;
public static BufferedImage createThumbnail(BufferedImage image, int requestedThumbSize) {
float ratio = (float) image.getWidth() / (float) image.getHeight();
int width = image.getWidth();
BufferedImage thumb = image;
do {
width /= 2;
if (width < requestedThumbSize) {
width = requestedThumbSize;
BufferedImage temp = new BufferedImage(width, (int) (width / ratio), BufferedImage.TYPE_INT_ARGB);
Graphics2D g2 = temp.createGraphics();
g2.setRenderingHint(RenderingHints.KEY_INTERPOLATION,
RenderingHints.VALUE_INTERPOLATION_BILINEAR);
g2.drawImage(thumb, 0, 0, temp.getWidth(), temp.getHeight(), null);
g2.dispose();
thumb = temp;
} while (width != requestedThumbSize);
return thumb;
public static BufferedImage createThumbnail(BufferedImage image, int newWidth, int newHeight) {
int height = image.getHeight();
do {
if (width > newWidth) {
width /= 2;
if (width < newWidth) {
width = newWidth;
if (height > newHeight) {
height /= 2;
if (height < newHeight) {
height = newHeight;
BufferedImage temp = new BufferedImage(width, height, BufferedImage.TYPE_INT_ARGB);
g2.dispose();
thumb = temp;
} while (width != newWidth || height != newHeight);
return thumb;
