1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213
| // AutoCollimationV1_00Dlg.cpp : implementation file
#include "stdafx.h"
#include "AutoCollimationV1_00.h"
#include "AutoCollimationV1_00Dlg.h"
#ifdef _DEBUG
#define new DEBUG_NEW
#undef THIS_FILE
static char THIS_FILE[] = __FILE__;
#endif
// link image manger lib's (LIB file directories must be set properly)
#pragma comment (lib, "cvcimg.lib")
#pragma comment (lib, "cvcutilities.lib")
#pragma comment (lib, "cvcdriver.lib")
// CAutoCollimationV1_00Dlg dialog
CAutoCollimationV1_00Dlg::CAutoCollimationV1_00Dlg(CWnd* pParent /*=NULL*/)
: CDialog(CAutoCollimationV1_00Dlg::IDD, pParent)
//{{AFX_DATA_INIT(CAutoCollimationV1_00Dlg)
m_bGrab = FALSE;
m_Pas = 1;
m_X_Debut = 0;
m_X_Fin = 0;
m_Resultat = _T("");
//}}AFX_DATA_INIT
// Note that LoadIcon does not require a subsequent DestroyIcon in Win32
m_hIcon = AfxGetApp()->LoadIcon(IDR_MAINFRAME);
void CAutoCollimationV1_00Dlg::DoDataExchange(CDataExchange* pDX)
CDialog::DoDataExchange(pDX);
//{{AFX_DATA_MAP(CAutoCollimationV1_00Dlg)
// DDX_Control(pDX, IDC_P_HISTOGRAMME, m_Histogramme);
DDX_Check(pDX, IDC_C_GRAB, m_bGrab);
DDX_Control(pDX, IDC_CV_DISP, m_cvDisp);
DDX_Control(pDX, IDC_CV_IMG, m_cvImg);
DDX_Text(pDX, IDC_E_PAS, m_Pas);
DDX_Text(pDX, IDC_E_X_DEBUT, m_X_Debut);
DDX_Text(pDX, IDC_E_RESULTAT, m_Resultat);
DDX_Text(pDX, IDC_E_X_FIN, m_X_Fin);
//}}AFX_DATA_MAP
BEGIN_MESSAGE_MAP(CAutoCollimationV1_00Dlg, CDialog)
//{{AFX_MSG_MAP(CAutoCollimationV1_00Dlg)
ON_WM_SYSCOMMAND()
ON_WM_PAINT()
ON_WM_QUERYDRAGICON()
ON_BN_CLICKED(IDC_B_OPEN, OnBOpen)
ON_BN_CLICKED(IDC_B_SAVE, OnBSave)
ON_BN_CLICKED(IDC_C_GRAB, OnCGrab)
ON_WM_CLOSE()
//}}AFX_MSG_MAP
END_MESSAGE_MAP()
// CAutoCollimationV1_00Dlg message handlers
BOOL CAutoCollimationV1_00Dlg::OnInitDialog()
CDialog::OnInitDialog();
Beep(1000,100);
// Add "About..." menu item to system menu.
// IDM_ABOUTBOX must be in the system command range.
ASSERT((IDM_ABOUTBOX & 0xFFF0) == IDM_ABOUTBOX);
ASSERT(IDM_ABOUTBOX < 0xF000);
CMenu* pSysMenu = GetSystemMenu(FALSE);
if (pSysMenu != NULL)
CString strAboutMenu;
strAboutMenu.LoadString(IDS_ABOUTBOX);
if (!strAboutMenu.IsEmpty())
pSysMenu->AppendMenu(MF_SEPARATOR);
pSysMenu->AppendMenu(MF_STRING, IDM_ABOUTBOX, strAboutMenu);
// Set the icon for this dialog. The framework does this automatically
// when the application's main window is not a dialog
SetIcon(m_hIcon, TRUE); // Set big icon
SetIcon(m_hIcon, FALSE); // Set small icon
// Create the ToolTip control.
m_tooltip.Create(this);
m_tooltip.Activate(TRUE);
// assign tools to controls
m_tooltip.AddTool(GetDlgItem(IDC_B_OPEN), "Open an Image or Driver");
m_tooltip.AddTool(GetDlgItem(IDC_B_SAVE), "Save the Image");
m_tooltip.AddTool(GetDlgItem(IDC_C_GRAB), "Turn grab on and off");
// TODO: Use one of the following forms to add controls:
// m_tooltip.AddTool(GetDlgItem(IDC_<name>), <string-table-id>);
// m_tooltip.AddTool(GetDlgItem(IDC_<name>), "<text>");
// Common Vision Blox initialization
m_Img = NULL;
// UI initialization
SetupUI ();
// enable DirectDraw
m_cvDisp.SetDirectDrawEnabled (TRUE);
// enable scrollbars
m_cvDisp.SetScrollBars (TRUE);
// TODO: Add extra initialization here
return TRUE; // return TRUE unless you set the focus to a control
void CAutoCollimationV1_00Dlg::OnSysCommand(UINT nID, LPARAM lParam)
if ((nID & 0xFFF0) == IDM_ABOUTBOX)
CAboutDlg dlgAbout;
dlgAbout.DoModal();
else
CDialog::OnSysCommand(nID, lParam);
// If you add a minimize button to your dialog, you will need the code below
// to draw the icon. For MFC applications using the document/view model,
// this is automatically done for you by the framework.
void CAutoCollimationV1_00Dlg::OnPaint()
CString st;
if (IsIconic())
CPaintDC dc(this); // device context for painting
SendMessage(WM_ICONERASEBKGND, (WPARAM) dc.GetSafeHdc(), 0);
// Center icon in client rectangle
int cxIcon = GetSystemMetrics(SM_CXICON);
int cyIcon = GetSystemMetrics(SM_CYICON);
CRect rect;
GetClientRect(&rect);
int x = (rect.Width() - cxIcon + 1) / 2;
int y = (rect.Height() - cyIcon + 1) / 2;
// Draw the icon
dc.DrawIcon(x, y, m_hIcon);
else
CDialog::OnPaint();
st.Format("",XDebut);
SetDlgItemText(IDC_E_X_DEBUT,st);
st.Format("",XFin);
SetDlgItemText(IDC_E_X_FIN,st);
st.Format("%ld",m_Pas);
SetDlgItemText(IDC_E_PAS,st);
// The system calls this to obtain the cursor to display while the user drags
// the minimized window.
HCURSOR CAutoCollimationV1_00Dlg::OnQueryDragIcon()
return (HCURSOR) m_hIcon;
BOOL CAutoCollimationV1_00Dlg::PreTranslateMessage(MSG* pMsg)
// CG: The following block was added by the ToolTips component.
// Let the ToolTip process this message.
m_tooltip.RelayEvent(pMsg);
return CDialog::PreTranslateMessage(pMsg); // CG: This was added by the ToolTips component.
BEGIN_EVENTSINK_MAP(CAutoCollimationV1_00Dlg, CDialog)
//{{AFX_EVENTSINK_MAP(CAutoCollimationV1_00Dlg)
ON_EVENT(CAutoCollimationV1_00Dlg, IDC_CV_IMG, 5 /* ImageSnaped */, OnImageSnapedCvImg, VTS_NONE)
//}}AFX_EVENTSINK_MAP
END_EVENTSINK_MAP()
void CAutoCollimationV1_00Dlg::SetupUI (void)
CWnd *pWnd;
// save image handle
m_Img = (IMG) m_cvImg.GetImage();
// set display image
m_cvDisp.SetImage ((long) m_Img);
// TODO: Add your extra control notification handler code here
void CAutoCollimationV1_00Dlg::OnClose()
// TODO: Add your message handler code here and/or call default
CDialog::OnClose();
