J'ai une erreur sur ce script avec le message
File "D:\Utilisateurs\Genius\Documents\Programmation\database_parser_IL2_Great_Battles.py", line 521, in <module>
SET bombs_kg = payload_bombs(Planes.aircraft_name, Planes.payload_id);''')
sqlite3.OperationalError: no such function: payload_bombspourtant j'importe bien toutes mes fonctions au préalable:
3 cur.execute('''UPDATE Planes SET bombs_kg = payload_bombs(Planes.aircraft_name, Planes.payload_id);''')
Code : Sélectionner tout - Visualiser dans une fenêtre à part from aircraft_payloads import *
Voici un extrait de mes fonctions dans le fichier aircraft_payloads:
45 def payload_name (aircraft_name, payload_id): """Extraction of the payload name""" try: b = aircraft_payload[aircraft_name] except: print("unknow plane") else: try: c = (b[payload_id]) except: print("unknow payload") else: print (c[1]) return (c[1]) def payload_bombs (aircraft_name, payload_id): """Extraction of the bombs Weight""" try: b = aircraft_payload[aircraft_name] except: print("unknow plane") else: try: c = (b[payload_id]) except: print("unknow payload") else: print (c[2]) return (c[2]) def payload_rockets (aircraft_name, payload_id): """Extraction of the rockets Weight""" try: b = aircraft_payload[aircraft_name] except: print("unknow plane") else: try: c = (b[payload_id]) except: print("unknow payload") else: print (c[3]) return (c[3])
Auriez-vous un conseil ?
