probléme avec la sdl et c++
    Janvier 2004
    Par défaut probléme avec la sdl et c++
    Bonjour ,
    Je code un petit programme dons voici les sources
    119
    120
    121
    122
    123
    124
    125
    126
    127
    128
    129
    130
    131
    132
    133
    134
    135
    136
    137
    138
    139
    140
    141
    142
    #include <windows.h>
    #include "sdl/sdl.h"
    #include "stdlib.h"
    #include "gl/gl.h"
    #include "gl/glu.h"
     int width , height , bpp ;
     static void setup_opengl(int , int);
     static void dessin(void);
     static void On_key_press(SDL_keysym* keysym);
     static void evenement(void);
    int STDCALL
    WinMain (HINSTANCE hInst, HINSTANCE hPrev, LPSTR lpCmd, int nShow)
      if (SDL_Init(SDL_INIT_VIDEO) < 0)
       fprintf( stderr, "Video initialization failed: %s\n",
                 SDL_GetError( ) );
      width = 800 ;
      height = 600;
      bpp = 32;
          SDL_GL_SetAttribute( SDL_GL_RED_SIZE, 5 );
        SDL_GL_SetAttribute( SDL_GL_GREEN_SIZE, 5 );
        SDL_GL_SetAttribute( SDL_GL_BLUE_SIZE, 5 );
        SDL_GL_SetAttribute( SDL_GL_DEPTH_SIZE, 16 );
        SDL_GL_SetAttribute( SDL_GL_DOUBLEBUFFER, 1 );
        if (SDL_SetVideoMode(width , height , bpp , SDL_OPENGL)==0)       // | SDL_FULLSCREEN
         fprintf( stderr, "Video mode set failed: %s\n",
                 SDL_GetError( ) );
    setup_opengl(width , height );
     while(1)
     dessin();
      evenement();
        //system("pause");
      return 0;
    static void setup_opengl( int width, int height )
        float ratio = (float) width / (float) height;
        glShadeModel( GL_SMOOTH );
        glCullFace( GL_BACK );
        glFrontFace( GL_CCW );
        glEnable( GL_CULL_FACE );
        glClearColor( 0, 0, 0, 0 );
        glViewport( 0, 0, width, height );
        glMatrixMode( GL_PROJECTION );
        glLoadIdentity( );
           gluPerspective( 60.0, ratio, 1.0, 1024.0 );
           glFlush();
           glClear( GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT );
      glMatrixMode( GL_MODELVIEW );
        glLoadIdentity( );
              glBegin(GL_TRIANGLES);
    glColor3f( 0.0f, 0.0f, 1.0f );
       glVertex3f(-0.5, 0.0, 0.5);
       glVertex3f( 0.5, 0.0, 0.5);
       glVertex3f( 0.0, 1.0, 0.0);
    glColor3f( 1.0f, 1.0f, 0.0f );
       glVertex3f(-0.5, 0.0,-0.5);
       glVertex3f( 0.5, 0.0,-0.5);
    glColor3f( 0.0f, 1.0f, 0.0f );
    glColor3f( 1.0f, 0.0f, 0.0f );
       glVertex3f(0.5, 0.0, 0.5);
       glVertex3f(0.5, 0.0,-0.5);
       glVertex3f(0.0, 1.0, 0.0);
    glEnd();
         SDL_GL_SwapBuffers( );
    static void on_key_press(SDL_keysym* keysym)
     switch (keysym -> sym){
       case SDLK_ESCAPE:
       SDL_Quit();
       break;
    SDL_Event event;
    while (SDL_PollEvent(&event))
    switch (event.type)
     case SDL_KEYDOWN:
                on_key_press( &event.key.keysym );
                break;
    Le probléme c'est que je ne vois rien dans la fenêtre !! Pourquoi ? merci de votre aide !
    il faut préciser au moteur ou tu te trouves et ou tu regardes (il ne me semble pas avoir vu cette fonction chez toi)
    gluLookAt(
    0,0,-10.0 //d'ou
    0,0,0 //vers ou
    0,1,0 //verticale
  1. Problème avec la SDL
    Par l'hachemi dans le forum SDL
    Dernier message: 24/09/2007, 10h57
  2. Problème avec la SDL
    Par kaled1209 dans le forum SDL
    Dernier message: 11/08/2007, 16h00
  3. Problème avec la SDL
    Par mjfcolas dans le forum SDL
    Dernier message: 24/06/2007, 20h17
  4. Réponses: 10
    Dernier message: 03/03/2007, 14h46
  5. Problème avec la sdl sur devc++
    Par cuicuicui dans le forum SDL
    Dernier message: 07/08/2006, 14h04
