DBeaver - Variable
    Membre Expert Avatar de QuestVba
    Enseignant
    Juillet 2012
    Activité : Enseignant
    Secteur : Service public
    Par défaut DBeaver - Variable
    Bonjour au Forum,
    J'utilise ce sql avec sqldeveloper. Et il fonctionne très bien. Comme vous le voyez j'ai deux variables pour tirer mes données. my_period qui prend le mois en cours et qui retranche my_shift pour trouver le mois que je désire.
    DEFINE my_shift = 1
    DEFINE my_period = TO_NUMBER(TO_CHAR(ADD_MONTHS(TO_DATE(CURRENT_DATE), - &&my_shift),'yyyymm'))
    SELECT
        COUNT(CHILD_INSS)
    FROM
        SELECT
            p.first_name ||' '|| p.name AS CHILD_NAME,
            p.inss AS CHILD_INSS,
            benef_201912 AS BENEFICIARY_INSS_201912,
            benef_2020 AS BENEFICIARY_INSS_2020,
            CASE
                WHEN benef_201912 = benef_2020 THEN 1
                WHEN benef_201912 <> benef_2020 THEN 0
            END AS Identical_Beneficiary
        FROM
            outgoing_documents od
            INNER JOIN document_conversations dc ON od.document_conversation_id = dc.document_conversation_id
            INNER JOIN actors a ON a.actor_id = dc.concerned_actor_id
            INNER JOIN persons p ON p.person_id = a.person_id
            INNER JOIN
            SELECT DISTINCT
                per.inss AS child_201912
                ,per_al.inss AS benef_201912
            FROM
                files fil
                INNER JOIN children chi ON chi.file_number = fil.file_number
                INNER JOIN legal_situation leg ON leg.child_id = chi.actor_id
                    AND (201912 BETWEEN (leg.start_year * 100 + leg.start_month) AND NVL(leg.end_year * 100 + leg.end_month,999999))
                    AND leg.status = 'ACTIVE'
                INNER JOIN childbeneficiarylinks cbl ON cbl.child_id = chi.actor_id
                    AND (201912 BETWEEN (cbl.start_year * 100 + cbl.start_month) AND NVL(cbl.end_year * 100 + cbl.end_month,999999))
                INNER JOIN actors ac ON ac.actor_id = chi.actor_id
                INNER JOIN persons per ON ac.person_id = per.person_id
                INNER JOIN actors ac_al ON ac_al.actor_id = cbl.beneficiary_id
                INNER JOIN persons per_al ON ac_al.person_id = per_al.person_id
            ) ON p.inss = child_201912
            INNER JOIN
            SELECT DISTINCT
                per.inss AS child_2020
                ,per_al.inss AS benef_2020
            FROM
                files fil
                    AND (leg.start_year * 100 + leg.start_month) BETWEEN 202001 AND &&my_period
                    AND (cbl.start_year * 100 + cbl.start_month) BETWEEN 202001 AND &&my_period
            ) ON p.inss = child_2020
        WHERE od.ad_hoc_type = 'NonDomiciledChild_1'
    Ma question : j'utilise DBeaver depuis quelques semaines car il est plus stable chez moi mais je n'ai toujours pas réussi à adapter ce sql au niveau des variables. Et surtout éviter qu'il m'envoie un popup de remplissage des variables. Si vous avez des pistes... car j'ai déjà pas mal chercher sur la toile.
    McM
    McM est déconnecté
    Développeur Oracle
    Juillet 2003
    Activité : Développeur Oracle
    TO_DATE(CURRENT_DATE) ? Aïe, ça me pique les yeux.. jamais de to_date sur une date
    Sinon, ça te sert à quoi cette requête ? Tu ne peux pas passer par du plsql ?
    DECLARE
    v NUMBER;
    v_shift NUMBER := 1;
    v_my_period NUMBER := TO_NUMBER(TO_CHAR(ADD_MONTHS(CURRENT_DATE, - v_shift ),'yyyymm'));
    begin
    SELECT
        COUNT(CHILD_INSS) INTO v
    FROM
        SELECT
            CASE
        FROM
            INNER JOIN
            SELECT DISTINCT per.inss AS child_201912, per_al.inss AS benef_201912
            FROM
                files fil
            INNER JOIN
            SELECT DISTINCT        per.inss AS child_2020      ,per_al.inss AS benef_2020
            FROM
                files fil
                    AND (leg.start_year * 100 + leg.start_month) BETWEEN 202001 AND v_my_period
                    AND (cbl.start_year * 100 + cbl.start_month) BETWEEN 202001 AND v_my_period
    dbms_putput.put_line('resultat:'|| v);
    END;
    Membre émérite Avatar de 13thFloor
    DBA Oracle freelance
    Janvier 2005
    Activité : DBA Oracle freelance
    Hello,
    le 1er lien de google te donne la réponse.
    Window -> Preferences -> Database -> Editors -> SQL Editor -> SQL Processing. There is a block on Parameters with settings you can change. See the Dynamic Parameter binding section on the wiki.
    Il faut cocher Anonymous sql parameters.
    J'ai fais un test avec :
    @set days = 1
    select to_char(sysdate-:days,'dd/mm/rr hh24:mi:ss') from dual;
    Et ça marche.
    Enseignant
    Juillet 2012
    @McM
    Pourquoi ce sql ? Cela concerne les enfants bénéficiaires sans domicile. Quand on applique la nouvelle législation en 01/2020, certains enfants ont perdu leur droit mais, dans certaines conditions, le droit a été rouvert après 01/2020. C'est donc ce nombre d'enfants que je cherche et trouve.
    PL/SQL n'est malheureusement pas une option.
    Enseignant
    Juillet 2012
    @13thFloor
    Effectivement, j'ai bien coché cette option.
    mon but était d'utiliser une variable dans une autre variable. Comme ceci (qui ne fonctionne évidemment pas):
    @set days = 125
    @set my_period = to_char(sysdate-:days,'dd/mm/rr hh24:mi:ss')
    select
    	:days
    	,:my_period
    FROM dual
  1. Réponses: 4
    Dernier message: 18/07/2002, 13h32
  2. variables locales ou globales ???
    Par elvivo dans le forum C
    Réponses: 13
    Dernier message: 03/07/2002, 08h22
  3. Procédure avec un nombre variable d'arguments
    Par charly dans le forum Langage
    Réponses: 15
    Dernier message: 21/06/2002, 11h08
  4. Réponses: 4
    Dernier message: 05/06/2002, 14h35
  5. les variables globales static
    Par gRRosminet dans le forum C
    Dernier message: 27/04/2002, 08h34
