Probleme de connection au base de données
Servlets/JSP Java
    Nouveau membre du Club
    Janvier 2007
    Par défaut Probleme de connection au base de données
    Une application .jar exécutable est fournie à l’hébergeur, lorsque que je lance le fichier .jnlp via le web pour exécuter l’application .jar ‘ développé par swing ‘ , il apparaître une fenêtre dans laquelle , il demande d’entrer login et mots de passe , on saisie login et mots pass,
    Il donne ce message d’erreur :
    java.sql.SQLException: Invalid authorization specification message from server: "Access denied for user: 'taogolpm' (Using password: YES)"
    at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:1997)
    at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:1906)
    at com.mysql.jdbc.MysqlIO.doHandshake(MysqlIO.java:954)
    at com.mysql.jdbc.Connection.createNewIO(Connection.java:1782)
    at com.mysql.jdbc.Connection.<init>(Connection.java:450)
    atcom.mysql.jdbc.NonRegisteringDriver.connect (NonRegisteringDriver.java:411)
    at java.sql.DriverManager.getConnection(Unknown Source)
    at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
    at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
    at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
    at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
    at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
    at java.awt.Component.processMouseEvent(Unknown Source)
    at javax.swing.JComponent.processMouseEvent(Unknown Source)
    at java.awt.Component.processEvent(Unknown Source)
    at java.awt.Container.processEvent(Unknown Source)
    at java.awt.Component.dispatchEventImpl(Unknown Source)
    at java.awt.Container.dispatchEventImpl(Unknown Source)
    at java.awt.Component.dispatchEvent(Unknown Source)
    at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
    at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
    at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
    at java.awt.Window.dispatchEventImpl(Unknown Source)
    at java.awt.EventQueue.dispatchEvent(Unknown Source)
    at java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknown Source)
    at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
    at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
    at java.awt.EventDispatchThread.run(Unknown Source)
    ya qlq qui tombé sur meme erreur.
    j'attends tes réponses.
    merci à l'avance.
    Membre actif Avatar de a.snaps
    Janvier 2007
    Ta base de données refuse la connection pour l'utilisateur 'taogolpm'
    Vérifie ta config MySQL
    Alex
    Membre éclairé Avatar de LeXo
    Janvier 2004
    fais peter le code de ta connection
    ça aidera a comprendre
    mais c surement ton login/password qui n'est pas bon
    Janvier 2007
    Par défaut pb de connection
    merci pour la réponse, en fait voici le code de connection :
    public void actionPerformed(ActionEvent _e)
    		if(
    				_e.getSource() == btnOkAccueil
    			 || _e.getSource() == iteGen
    			String login = "ctlogin";
    			String password = "ctpass";*/
    			conn = DbConnect.getInstance(login,password,db,"Adrs_IP",port);
    			if (conn.connect())
    				if(controleUtil())
    					numVueFactory = VueFactory.SALARIE_VISUALISATION;
    					loginUtilisateur[0] = tfname.getText();
    					trace = TraceurModele.getInstance();
    					trace.creerEnregTrace(tfname.getText(),"Menu général","E");
    					System.out.println("Fenetre Principale1 : connection ok");
    					initLoginCache();
    					initParametreCache();
    					initMasqueCache();
    					contentPane.removeAll();
    					menuFenetre.removeAll();
    					contentPane.add(vueFactory.createPanel(VueFactory.MENU_GENERAL));
    					evenementAgenda(	calJour.get(Calendar.DAY_OF_MONTH),
    										calJour.get(Calendar.MONTH)+1,
    										calJour.get(Calendar.YEAR)
    					contentPane.revalidate();
    					repaint();
    				else
    					tfname.setText("");
    					tfpass.setText("");
    					tfname.requestFocus();
    					tfname.setCaretPosition(0);
    			}// - if
    			else
    				tfname.setText("");
    				tfpass.setText("");
    			}// - else
  1. Probleme de connection a base de donnée oracle
    Par reportPer dans le forum BIRT
    Réponses: 16
    Dernier message: 17/09/2009, 12h31
  2. Probleme de connection à ma base de donnée
    Par gbegerco dans le forum VB 6 et antérieur
    Dernier message: 21/05/2009, 20h10
  3. Probleme de connection à la base de donnée avec tinyerp
    Par Fredoso dans le forum Odoo (ex-OpenERP)
    Dernier message: 05/07/2008, 11h46
  4. Probleme de connection au base de données
    Par yayamo dans le forum Installation
    Dernier message: 29/01/2007, 18h11
  5. Connection à une base de données
    Par rodri dans le forum Bases de données
    Dernier message: 28/07/2004, 14h03
