VBO autre chose que des GLfloats
    Membre confirmé Avatar de lXT95l
    Novembre 2006
    Par défaut VBO autre chose que des GLfloats
    Bonjour a tous,
    j'ai un ptit pb, j'aimerais passer autre chose que des GLfloats a mes VBO.
    Mon prog de test :
    119
    120
    121
    122
    123
    124
    125
    126
    127
    128
    129
    130
    131
    132
    133
    134
    135
    136
    137
    138
    139
    140
    141
    142
    143
    144
    145
    146
    147
    148
    149
    150
    151
    152
    153
    154
    155
    156
    157
    158
    159
    160
    161
    #include <XT/xtEngine.h>
    XT_CameraFPS cam;
    XT_Sky sky;
    void Draw();
    using namespace std;
    Uint32 last_time,current_time,elapsed_time; //for time animation
    const GLsizeiptr PositionSize = 6 * 2 * sizeof(GLfloat);
    /*static const GLfloat PositionData[] =
    	-1.0f,-1.0f,
    	 1.0f,-1.0f,
    	 1.0f, 1.0f,
    	 1.0f, 1.0f,
    	-1.0f, 1.0f,
    	-1.0f,-1.0f,
    vec2 Vertex[6];
    const int BufferSize = 2;
    GLuint BufferName[BufferSize];
    GLsizei VertexCount = 6;
    enum
        POSITION_OBJECT = 0,
        COLOR_OBJECT = 1
    int main(int argc, char *argv[])
    	//Init
    	XT_Init("VBO test",800,600,false);
    	SDL_Event event;
    	//VBO
        glGenBuffers(BufferSize, BufferName);
    	Vertex[0]=vec2(-1.0f,-1.0f);
    	Vertex[1]=vec2( 1.0f,-1.0f);
    	Vertex[2]=vec2( 1.0f, 1.0f);
    	Vertex[3]=vec2( 1.0f, 1.0f);
    	Vertex[4]=vec2(-1.0f, 1.0f);
    	Vertex[5]=vec2(-1.0f,-1.0f);
    	//Sky
    	sky.SetSize(1000000);
        sky.SetBack("Data/sky/01/Back.jpg");
        sky.SetFront("Data/sky/01/Front.jpg");
        sky.SetBottom("Data/sky/01/Bottom.jpg");
        sky.SetTop("Data/sky/01/Top.jpg");
        sky.SetLeft("Data/sky/01/Left.jpg");
        sky.SetRight("Data/sky/01/Right.jpg");
    	//Cam
    	cam.speed=200;
    	//Boucle principal
    	while(1)
            SDL_PollEvent(&event);
            switch(event.type)
                case SDL_QUIT:
    			XT_Quit();
    			exit(0);
                break;
                case SDL_KEYDOWN:
                switch (event.key.keysym.sym)
                    case SDLK_ESCAPE:
    					XT_Quit();
    					exit(0);
                        break;
                   case SDLK_p:
                        XT_Screenshot("screen.bmp");
                        break;
                break;
        current_time = SDL_GetTicks();
        elapsed_time = current_time - last_time;
        last_time = current_time;
    	//Action
        cam.GetEvent(&event,elapsed_time);
        //DRAW
        Draw();
        glFlush();
        SDL_GL_SwapBuffers();
        return 0;
    void Draw()
    	XT_ClearBuffer();
    	XT_BeginScene();
    	//Cam
    	cam.Look();
    	//Sky
    	sky.Look();
    	//VBO
        glBindBuffer(GL_ARRAY_BUFFER, BufferName[COLOR_OBJECT]);
        glColorPointer(3, GL_UNSIGNED_BYTE, 0, 0);
        glBindBuffer(GL_ARRAY_BUFFER, BufferName[POSITION_OBJECT]);
        glBufferData(GL_ARRAY_BUFFER, PositionSize, Vertex, GL_STREAM_DRAW);
        glVertexPointer(2, GL_FLOAT, 0, 0);
        glEnableClientState(GL_VERTEX_ARRAY);
        glDrawArrays(GL_TRIANGLES, 0, VertexCount);
        glDisableClientState(GL_VERTEX_ARRAY);
    	XT_EndScene();
    Ma classe vec3 :
    class vec3
    public:
        float x,y,z;
        vec3();
        vec3(float xx,float yy,float zz);
        vec3(const vec3 & v);
        vec3(const vec3 & from,const vec3 & to);
        vec3 & operator= (const vec3 & v);
        vec3 & operator+= (const vec3 & v);
        vec3 operator+ (const vec3 & v) const;
        vec3 & operator-= (const vec3 & v);
        vec3 operator- (const vec3 & v) const;
        vec3 & operator*= (const float a);
        vec3 operator* (const float a)const;
        friend vec3 operator* (const float a,const vec3 & v);
        vec3 & operator/= (const float a);
        vec3 operator/ (const float a)const;
        vec3 crossProduct(const vec3 & v)const;
        float length()const;
        vec3 & normalize();
        ~vec3();
    Evidemment ca marche pas sa m'affiche juste un trai bleu !
    Quelqu'un a t il une idée ?
    Merci d'avance !
    Avatar de Laurent Gomila
    Avril 2003
    (ce ne serait pas plutôt la classe vec2 qu'il faudrait montrer ?)
    Normalement ça devrait être compatible, sauf cas à la con où le compilo aligne par défaut les données sur 8 octets avec des float qui en font 4. Mais je ne pense pas que ce soit le cas.
    D'ailleurs tu peux récupérer les données qui se trouvent dans ton vertex buffer pour t'assurer qu'elles ont bien été transmises, là tu seras fixé.
    Novembre 2006
    Effectivement je me suis trompé, vec2 c'est la meme class que vec3 mais sans le z de tte facon.
    Donc :
    M'affiche juste un trai bleu
    glBufferData(GL_ARRAY_BUFFER, PositionSize, PositionData, GL_STREAM_DRAW);
    M'affiche le rectangle normal
    Comment récupérer les données qui se trouvent dans le vertex buffer ?
    Avril 2003
    glMapBuffer
    float* Data = (float*)glMapBuffer(GL_ARRAY_BUFFER, GL_READ_ONLY);
    if (Data)
        for (int i = 0; i < 6; ++i)
            std::cout << Data[i] << " " << Data[i + 1] << std::endl;
    glUnmapBuffer(GL_ARRAY_BUFFER);
    Novembre 2006
    Ah, yavait une erreur dans ma class vec2 ><
    Ca marche !
    Merci beaucoup =)
  1. Réponses: 0
    Dernier message: 01/05/2015, 20h57
  2. [classpath] autre chose que des jars
    Par eatherquake dans le forum Débuter avec Java
    Dernier message: 09/12/2008, 10h22
  3. Réponses: 11
    Dernier message: 13/05/2006, 15h17
  4. Arrive plus a installer autre chose que debian
    Par kosmic dans le forum Debian
    Dernier message: 12/12/2005, 11h50
  5. [langage] connaissez-vous autre chose que -d
    Par Sébastien dans le forum Langage
    Dernier message: 05/08/2002, 20h13
