SQL*Loader Oracle Discussion :
SQL loader probleme oracle 9i
SQL*Loader Oracle
    Mai 2007
    Par défaut SQL loader probleme oracle 9i
    Mon Probleme est le suivamt :
    je veux charger un fichier texte ds une base de donnee oracle 9i mais j ai tjrs la meme erreur Commit point reached. aucune ligne n est charge. voila la table que je ve remplir :
    create table TRC_ADM (
    ID int not null ,
    TIME date not null ,
    RES int not null ,
    RPL int not null ,
    NE char(16) not null
    Mon fichier control :
    LOAD DATA
    INFILE './TRC_DATA_nn.txt'
    APPEND
    INTO TABLE TRC_ADM
    FIELDS TERMINATED BY ';' OPTIONALLY ENCLOSED BY '"'
    TRAILING NULLCOLS
    ID INTEGER EXTERNAL,
    TIME CHAR,
    RES INTEGER EXTERNAL,
    RPL INTEGER EXTERNAL,
    NE CHAR
    mon fichier bat :
    sqlldr SYSTEM/system@grantest errors=3000 control=test log=logdata data=TRC_DATA_nn.txt
    pause
    un extrait de mon fichier de donnee :
    68442441;Feb 1 2007 12:00AM;1;60;BSCAGA2
    68442442;Feb 1 2007 1:00AM;1;60;BSCAGA2
    68442443;Feb 1 2007 2:00AM;1;60;BSCAGA2
    68442444;Feb 1 2007 3:00AM;1;60;BSCAGA2
    68442445;Feb 1 2007 4:00AM;1;60;BSCAGA2
    68442446;Feb 1 2007 5:00AM;1;60;BSCAGA2
    68442447;Feb 1 2007 6:00AM;1;60;BSCAGA2
    68442448;Feb 1 2007 7:00AM;1;60;BSCAGA2
    68442449;Feb 1 2007 8:00AM;1;60;BSCAGA2
    68442450;Feb 1 2007 9:00AM;1;60;BSCAGA2
    Mon log file :
    Control File: test.ctl
    Data File: TRC_DATA_nn.txt
    Bad File: TRC_DATA_nn.bad
    Discard File: none specified
    (Allow all discards)
    Number to load: ALL
    Number to skip: 0
    Errors allowed: 3000
    Bind array: 64 rows, maximum of 256000 bytes
    Continuation: none specified
    Path used: Conventional
    Table TRC_ADM, loaded from every logical record.
    Insert option in effect for this table: APPEND
    TRAILING NULLCOLS option in effect
    Column Name Position Len Term Encl Datatype
    ID FIRST * ; O(") CHARACTER
    TIME NEXT * ; O(") CHARACTER
    RES NEXT * ; O(") CHARACTER
    RPL NEXT * ; O(") CHARACTER
    NE NEXT * ; O(") CHARACTER
    Record 1: Rejected - Error on table TRC_ADM, column TIME.
    ORA-01858: a non-numeric character was found where a numeric was expected
    Record 2: Rejected - Error on table TRC_ADM, column TIME.
    Record 3: Rejected - Error on table TRC_ADM, column TIME.
    Record 4: Rejected - Error on table TRC_ADM, column TIME.
    Record 5: Rejected - Error on table TRC_ADM, column TIME.
    Record 6: Rejected - Error on table TRC_ADM, column TIME.
    Record 7: Rejected - Error on table TRC_ADM, column TIME.
    Record 8: Rejected - Error on table TRC_ADM, column TIME.
    Record 9: Rejected - Error on table TRC_ADM, column TIME.
    Record 10: Rejected - Error on table TRC_ADM, column TIME.
    Table TRC_ADM:
    0 Rows successfully loaded.
    10 Rows not loaded due to data errors.
    0 Rows not loaded because all WHEN clauses were failed.
    0 Rows not loaded because all fields were null.
    Space allocated for bind array: 82560 bytes(64 rows)
    Read buffer bytes: 1048576
    Total logical records skipped: 0
    Total logical records read: 10
    Total logical records rejected: 10
    Total logical records discarded: 0
    j attend vos reponses avec impatience.
    Février 2006
    Probablement un problème de format pour la colonne de type DATE.
    Mai 2007
    oui c le champ DATE, aucune solution a proposer ???
    Février 2006
    Avez-vous essayé:
    LOAD DATA
    APPEND
    INTO TABLE TRC_ADM
    TRAILING NULLCOLS
    TIME DATE LOAD DATA
    APPEND
    INTO TABLE TRC_ADM
    TRAILING NULLCOLS
    TIME DATE "MON DD YYYY HH:MMPM"
    NE CHAR
    Voir les formats de date.
    Avril 2007
    essaye cette commande pour résoudre le pbm de la date :
    TO_DATE('Feb 1 2007 12:00AM', 'MON DD YYYY HH24')
    Mai 2007
    un tres grand merci a pifor , vs etes un genie !!
    j ai fait une ptite modifcation a ta solution et ca marche :
    TIME DATE "MON DD YYYY HH:MIPM"
  1. sql loader et oracle/php
    Par arezki76 dans le forum Langage
    Dernier message: 09/01/2015, 09h58
  2. Utilitaire SQL*Loader sous Oracle
    Par mo9rissat dans le forum Import/Export
    Dernier message: 22/03/2012, 16h52
  3. Sql Loader et Oracle spatial
    Par Macao35 dans le forum Import/Export
    Dernier message: 26/08/2011, 11h05
  4. SQL*LOADER probleme condition WHEN
    Par l4r3nZu dans le forum PL/SQL
    Dernier message: 28/05/2011, 14h03
  5. Réponses: 19
    Dernier message: 18/12/2007, 16h07
