1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67
set serverout on size 1000000 head off feedback off
alter session set nls_date_format='YYYY-MM-DD';
declare
str varchar2(4000);
first boolean;
curid number;
desctab dbms_sql.desc_tab;
colcnt number;
namevar varchar2(4000);
tmp clob;
begin
str := 'select ';
first := true;
for f in (
select column_name
from user_tab_columns
where table_name='EMP'
and column_name!='EMPNO'
order by column_id)
loop
if first then
first:=false;
else
str:=str||',';
end if;
str:=str||f.column_name;
end loop;
str:=str||' from EMP';
curid := dbms_sql.open_cursor;
dbms_sql.parse(curid, str, dbms_sql.NATIVE);
DBMS_SQL.DESCRIBE_COLUMNS(curid, colcnt, desctab);
FOR i IN 1 .. colcnt LOOP
DBMS_SQL.DEFINE_COLUMN(curid, i, namevar,4000);
END LOOP;
if DBMS_SQL.execute(curid) = 0 THEN
dbms_lob.createtemporary(tmp, true);
if (i>1) then
dbms_lob.writeappend(tmp, 1, ';');
end if;
length(desctab(i).col_name),
desctab(i).col_name);
END LOOP;
dbms_output.put_line(tmp);
dbms_lob.freetemporary(tmp);
WHILE DBMS_SQL.FETCH_ROWS(curid) > 0 LOOP
if (i>1) then
end if;
DBMS_SQL.COLUMN_VALUE(curid, i, namevar);
if (namevar is not null)
then
dbms_lob.writeappend(tmp, length(namevar),
namevar);
end if;
END LOOP;
END LOOP;
END IF;
DBMS_SQL.CLOSE_CURSOR(curid);
end;
