1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197
| create or replace
PACKAGE BODY "EPSS_ARCHIVING" AS
PROCEDURE import_call (call_id IN number) IS
h1 NUMBER;
call_id_import NUMBER := call_id ;
import_job_name varchar2(20) := 'CALL_' ||call_id_import ;
ind NUMBER;
percent_done NUMBER;
job_state VARCHAR2(30);
le ku$_LogEntry;
js ku$_JobStatus;
jd ku$_JobDesc;
sts ku$_Status;
begin
epss_archiving.create_db_link;
epss_archiving.update_sequences;
epss_archiving.disable_constraints;
begin
h1 := dbms_datapump.open (operation => 'IMPORT', job_mode => 'FULL', job_name => 'IMPORT_'||call_id_import||'', version => 'COMPATIBLE');
end;
begin
dbms_datapump.set_parallel(handle => h1, degree => 1);
end;
begin
dbms_datapump.add_file(handle => h1, filename => 'IMPORT_'||call_id_import||'.LOG', directory => 'IMPDP_DIR', filetype => 3);
end;
begin
dbms_datapump.set_parameter(handle => h1, name => 'KEEP_MASTER', value => 0);
end;
begin
dbms_datapump.add_file(handle => h1, filename => 'EXPDAT_'||call_id_import||'_%U.DMP', directory => 'IMPDP_DIR', filetype => 1);
end;
begin
dbms_datapump.set_parameter(handle => h1, name => 'DATA_ACCESS_METHOD', value => 'AUTOMATIC');
end;
begin
dbms_datapump.set_parameter(handle => h1, name => 'INCLUDE_METADATA', value => 1);
end;
begin
dbms_datapump.set_parameter(handle => h1, name => 'REUSE_DATAFILES', value => 0);
end;
begin
dbms_datapump.set_parameter(handle => h1, name => 'SKIP_UNUSABLE_INDEXES', value => 0);
end;
begin
dbms_datapump.start_job(handle => h1, skip_current => 0, abort_step => 0);
end;
percent_done := 0;
job_state := 'UNDEFINED';
while (job_state != 'COMPLETED') and (job_state != 'STOPPED') loop
dbms_datapump.get_status(h1,
dbms_datapump.ku$_status_job_error +
dbms_datapump.ku$_status_job_status +
dbms_datapump.ku$_status_wip,-1,job_state,sts);
js := sts.job_status;
if js.percent_done != percent_done
then
dbms_output.put_line('*** Job percent done = ' ||
to_char(js.percent_done));
percent_done := js.percent_done;
end if;
if (bitand(sts.mask,dbms_datapump.ku$_status_wip) != 0)
then
le := sts.wip;
else
if (bitand(sts.mask,dbms_datapump.ku$_status_job_error) != 0)
then
le := sts.error;
else
le := null;
end if;
end if;
if le is not null
then
ind := le.FIRST;
while ind is not null loop
dbms_output.put_line(le(ind).LogText);
ind := le.NEXT(ind);
end loop;
end if;
end loop;
dbms_output.put_line('Job has completed');
dbms_output.put_line('Final job state = ' || job_state);
begin
dbms_datapump.detach(handle => h1);
end;
epss_archiving.enable_constraints;
epss_archiving.drop_db_link;
end import_call;
/*PROCEDURE TO DISABLE CONSTRINATS*/
procedure disable_constraints is
cursor user_constraints_cur is select table_name, constraint_name from user_constraints where constraint_type <> 'O';
v_table_name varchar2(100);
v_constraint_name varchar2(100);
begin
for rec_user_constraints in user_constraints_cur loop
v_table_name := rec_user_constraints.table_name;
v_constraint_name := rec_user_constraints.constraint_name;
execute immediate 'alter table ' ||v_table_name|| ' disable constraint ' || v_constraint_name || '';
end loop;
end disable_constraints;
/*PROCEDURE TO ENABLE CONSTRINATS*/
procedure enable_constraints is
begin
execute immediate 'alter table ' ||v_table_name|| ' enable constraint ' || v_constraint_name || '';
end loop;
end enable_constraints;
procedure update_sequences is
v_sequence_name_epss varchar(100);
v_sequence_value_epss number;
v_sequence_value_epsslnx number;
v_epss_query varchar2(300);
v_epsslnx_query varchar2(300);
v_epsslnx_update_sequence varchar2(300);
v_increase_sequence_number number;
v_epss_seq_cur varchar2(300);
cursor epss_seq_cur is
select sequence_name from all_sequences@EPSSLNX_TO_EPSSDEV.REGRESS.RDBMS.DEV.US.ORACLE.COM
where sequence_owner='EPSS' ;
begin
for rec_epss_sequences in epss_seq_cur loop
v_sequence_name_epss := rec_epss_sequences.sequence_name;
v_epss_query := 'select '||v_sequence_name_epss ||'.nextval from dual@EPSSLNX_TO_EPSSDEV.REGRESS.RDBMS.DEV.US.ORACLE.COM';
v_epsslnx_query := 'select '||v_sequence_name_epss ||'.nextval from dual';
execute immediate v_epss_query into v_sequence_value_epss;
execute immediate v_epsslnx_query into v_sequence_value_epsslnx;
if v_sequence_value_epsslnx < v_sequence_value_epss
then
v_increase_sequence_number := v_sequence_value_epss - v_sequence_value_epsslnx;
v_epsslnx_update_sequence := 'alter sequence '||v_sequence_name_epss||' increment by '||v_increase_sequence_number;
execute immediate v_epsslnx_update_sequence;
v_epsslnx_update_sequence := 'select '||v_sequence_name_epss ||'.nextval from dual';
v_epsslnx_update_sequence := 'alter sequence '||v_sequence_name_epss||' increment by 1';
end if;
end loop;
end update_sequences;
procedure create_db_link is
begin
execute immediate 'CREATE DATABASE LINK EPSSLNX_TO_EPSSDEV.REGRESS.RDBMS.DEV.US.ORACLE.COM CONNECT TO EPSS IDENTIFIED by intrasoft08 USING ''''EPSSDEV''';
end create_db_link;
procedure drop_db_link is
begin
execute immediate 'DROP DATABASE LINK EPSSLNX_TO_EPSSDEV.REGRESS.RDBMS.DEV.US.ORACLE.COM';
end drop_db_link;
end epss_archiving; |
