1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
| // set alpha map as TEXTURE UNIT 0
glActiveTextureARB(GL_TEXTURE0);
glTexEnvf(GL_TEXTURE_ENV, GL_TEXTURE_ENV_MODE, GL_REPLACE);
glTexEnvi(GL_TEXTURE_ENV, GL_SOURCE0_ALPHA_ARB, GL_TEXTURE0);
glTexEnvi(GL_TEXTURE_ENV, GL_OPERAND0_ALPHA_ARB, GL_SRC_ALPHA);
alphamap->bind();
// set image map as TEXTURE UNIT 1
glActiveTextureARB(GL_TEXTURE1);
glTexEnvi(GL_TEXTURE_ENV, GL_TEXTURE_ENV_MODE, GL_COMBINE_ARB);
glTexEnvi(GL_TEXTURE_ENV, GL_COMBINE_RGB_ARB, GL_MODULATE);
glTexEnvf(GL_TEXTURE_ENV, GL_SOURCE0_RGB_ARB, GL_PRIMARY_COLOR);
glTexEnvf(GL_TEXTURE_ENV, GL_OPERAND0_RGB_ARB, GL_SRC_COLOR);
glTexEnvf(GL_TEXTURE_ENV, GL_SOURCE1_RGB_ARB, GL_TEXTURE1);
glTexEnvf(GL_TEXTURE_ENV, GL_OPERAND1_RGB_ARB, GL_SRC_COLOR);
glTexEnvi(GL_TEXTURE_ENV, GL_SOURCE1_ALPHA_ARB, GL_TEXTURE0);
glTexEnvi(GL_TEXTURE_ENV, GL_OPERAND1_ALPHA_ARB, GL_SRC_ALPHA);
imagemap->bind();
glEnable(GL_BLEND);
glBlendFunc(GL_SRC_ALPHA, GL_ONE_MINUS_SRC_ALPHA);
// Dessin du terrain |
