Tuning Advisor : Erreur avec l'utilisation de Order by
    Membre confirmé Avatar de Arvulis
    Septembre 2003
    Par défaut Tuning Advisor : Erreur avec l'utilisation de Order by
    je suis en 10.2.0.3 sur du solaris 64bits et en faisant du tuning sur une requete, j'obtiens ceci :
    - The optimizer could not merge the view at line ID 6 of the execution plan.
      The optimizer cannot merge a view that contains an "ORDER BY" clause unless
      the statement is a "DELETE" or an "UPDATE" and the parent query is the top
      most query in the statement.
    - The optimizer could not merge the view at line ID 4 of the execution plan.
      The optimizer cannot merge a view that contains "ROWNUM" pseudo column
    Avec une requete du style :
    SELECT numberofnewsbydomain (10, 'france', '1,2,3,4,5,6,7,8,9,11') AS ID,
           NULL AS title, NULL AS summary, NULL AS published_on, 0 AS weight,
           0 AS id_language, NULL AS code_language, 0 AS id_provider,
           NULL AS code_provider, NULL AS updated_on
      FROM DUAL
    UNION --ALL
    SELECT selectednews.ID AS ID, nn1.title AS title, nn1.summary AS summary,
           nn1.published_on AS published_on, nn1.weight AS weight,
           nn1.id_language AS id_language,
           (SELECT ll.code
              FROM mm_language ll
             WHERE ll.ID = nn1.id_language) AS code_language,
           nn1.id_provider AS id_provider,
           (SELECT pp.code
              FROM mm_newsprovider pp
             WHERE pp.ID = nn1.id_provider) AS code_provider,
           nn1.updated_on AS updated_on
      FROM mm_newsitem nn1
           JOIN
           (SELECT a.*
              FROM (SELECT /*+ FIRST_ROWS +*/
                           ROWNUM rnum, a.*
                      FROM (SELECT   /*+ INDEX_COMBINE(NN) */
                                     nn.ID AS ID
                                FROM mm_newsitem nn
                               WHERE contains (nn.text_concat, '(usa)') > 0
                                 AND nn.id_provider IN (1, 2, 3, 4, 5, 6, 7, 8, 9, 11)
                            ORDER BY nn.published_on DESC) a
                     WHERE ROWNUM <= 1124) a
             WHERE rnum >= 15 OR rnum <= 4) selectednews ON selectednews.ID = nn1.ID;
    Quelqu'un aurais t'il un avis ?
    Octobre 2007
    Bref, il dit qui lui est impossible de faire le "view merging" à cause de la clause Order By or due à l’utilisation de la pseudo colonne RowNum
    13.4.1.1.1 View Merging
    Each view referenced in a query is expanded by the parser into a separate query block. The query block essentially represents the view definition, and therefore the result of a view. One option for the optimizer is to analyze the view query block separately and generate a view subplan. The optimizer then processes the rest of the query by using the view subplan in the generation of an overall query plan. This technique usually leads to a suboptimal query plan, because the view is optimized separately from rest of the query.
    The query transformer then removes the potentially suboptimal plan by merging the view query block into the query block that contains the view. Most types of views are merged. When a view is merged, the query block representing the view is merged into the containing query block. Generating a subplan is no longer necessary, because the view query block is eliminated.
  1. Réponses: 13
    Dernier message: 05/08/2008, 17h31
  2. Réponses: 3
    Dernier message: 26/06/2007, 13h50
  3. Erreur: avec l'utilisation de template<int N>
    Par vincho dans le forum C++
    Dernier message: 22/02/2007, 20h07
  4. Erreur avec GetImageSize : utilisation d'une URL
    Par Are-no dans le forum Langage
    Dernier message: 15/02/2007, 00h41
  5. Retour d'erreur avec l'utilisation de la commande For en VBS
    Par genialk2000 dans le forum VBScript
    Dernier message: 30/03/2005, 19h45
