Procédure sur 9i : ORA-06550 lors d'un appel externe
    Avril 2008
    Par défaut Procédure sur 9i : ORA-06550 lors d'un appel externe
    Bonjour a tous,
    Voici mon probleme. Une procedure SET_INV dont les tests sous PL/SQL Developer ne revelent aucun probleme :
    119
    120
    121
    122
    123
    124
    125
    126
    127
    128
    129
    130
    131
    132
    PROCEDURE SET_INV (
           V_ROLLOUT_CODE  IN   INTEGER,
           V_PLANNED       IN   VARCHAR2,
           V_PLANNED_YEAR  IN   INTEGER,
           V_PLANNED_MONTH IN   INTEGER,
           V_REMARKS       IN   VARCHAR2,
           V_RESPONSE_ID   OUT  INTEGER,
           V_RESPONSE_DESC OUT  VARCHAR2
    /* Parameters description :
    ** 1. V_ROLLOUT_CODE:  a. record Code in the rollout_inv table
    **                     b. mandatory parameter
    **                     c. MUST already exist ! (No insert allowed into rollout_inv, only updates)
    ** 1bis. V_PLANNED:    a. mandatory !
                           b. (YES, NO) -> (1,0) : 0 = not planned => V_REMARKS mandatory
                                                 1 = planned => V_PLANNED_YEAR mandatory
    ** 2. V_PLANNED_YEAR:  a. if the status of the record (designed by its code) in the rollout table
    **                         is 'PLANNED', then this parameter is mandatory
    **                     b. MUST BE equal or higher than current year
    ** 3. V_PLANNED_MONTH: a. not mandatory
    **                     b. must be in [1..12]
    ** 4. V_REMARKS:       a. remarks on planification : NEEDED IF the status of 2.a is different from 'PLANNED'
    **                     b. must be < 100 characters
    ** 5. V_RESPONSE_ID:   a. 0 = all went OK
                              1 = validation problem : one or more of the previous points are not satisfied
                              2 = DB problem
    ** 6. V_RESPONSE_DESC: a. Description of the response (complementary of above code)
                           b. must be < 200 characters
    ** End of paramters description */
    ) IS
    -- Invalid parameters exception
    V_VALIDATION_ERROR EXCEPTION;
    -- Checking point 1.c we will count the number of records with code=V_ROLLOUT_CODE and put the result into this variable
    V_VALID_CODE INTEGER:=0;
    BEGIN
    /* Validation tests */
       -- 1.b
       IF (V_ROLLOUT_CODE IS NULL) THEN
            V_RESPONSE_ID := 1;
            V_RESPONSE_DESC := 'Parameter RolloutCODE is mandatory !';
            RAISE V_VALIDATION_ERROR;
       END IF;
       -- 1.c
       SELECT COUNT(*) INTO V_VALID_CODE FROM SMART.V_ROLLOUT_INV WHERE V_ROLLOUT_INV.CODE = V_ROLLOUT_CODE;
       IF(V_VALID_CODE<>1) THEN
            V_RESPONSE_ID := 1;
            V_RESPONSE_DESC := 'There is no record with code '||V_ROLLOUT_CODE||' in the Rollout_INV table !';
       END IF;
       -- 1bis.a
       IF (V_PLANNED IS NULL) THEN
            V_RESPONSE_ID := 1;
            V_RESPONSE_DESC := 'Parameters V_PLANNED is mandatory !';
       END IF;
       -- 1bis.b (V_PLANNED other than 'YES' or 'NO')
       IF (V_PLANNED <> 'YES') AND (V_PLANNED <> 'NO') THEN
            V_RESPONSE_ID := 1;
            V_RESPONSE_DESC := 'Parameters V_PLANNED is not recognized : must be YES or NO !';
       END IF;
       -- 2.a
       IF(V_PLANNED = 'YES') AND (V_PLANNED_YEAR IS NULL) THEN
            V_RESPONSE_ID := 1;
            V_RESPONSE_DESC := 'The status of the record with code '||V_ROLLOUT_CODE||' is PLANNED : PLANNED_YEAR argument is mandatory !';
       END IF;
       -- 2.b
       IF(V_PLANNED_YEAR < extract(year from sysdate)) THEN
            V_RESPONSE_ID := 1;
            V_RESPONSE_DESC := 'The input PLANNED_YEAR for the record with code '||V_ROLLOUT_CODE||' must be equal or higher than '||extract(year from sysdate)||'!';
       END IF;
       --3.b
       IF(V_PLANNED_MONTH IS NOT NULL) THEN
            IF (V_PLANNED_MONTH < 1) OR (V_PLANNED_MONTH>12) THEN
               V_RESPONSE_ID := 1;
               V_RESPONSE_DESC := 'The input PLANNED_MONTH for the record with code '||V_ROLLOUT_CODE||' must be in [1..12]!';
            END IF;
       END IF;
       --4.a
        IF(V_PLANNED = 'NO') AND (V_REMARKS IS NULL) THEN
            V_RESPONSE_ID := 1;
            V_RESPONSE_DESC := 'The status of the record with code '||V_ROLLOUT_CODE||' is not PLANNED : REMARKS argument is mandatory !';
       END IF;
       --4.b
       V_VALID_CODE := LENGTH(V_REMARKS);
       IF(V_REMARKS IS NOT NULL) AND (LENGTH(V_REMARKS)>100) THEN
            V_RESPONSE_ID := 1;
            V_RESPONSE_DESC := 'For the record with code '||V_ROLLOUT_CODE||', the argument REMARKS must be < to 100 characters !';
       END IF;
    /* End of validation tests */
       -- Update
       UPDATE V_ROLLOUT_INV
       SET MONTH = V_PLANNED_MONTH, YEAR = V_PLANNED_YEAR, REMARKS = V_REMARKS
       WHERE CODE = V_ROLLOUT_CODE;
       -- Committing updates
       COMMIT;
       -- Output parameters setting
       V_RESPONSE_ID := 0;
       V_RESPONSE_DESC := 'The record with code '||V_ROLLOUT_CODE||' was updated properly.';
       DBMS_OUTPUT.put_line('Successful update ['||V_RESPONSE_ID||'] : '||V_RESPONSE_DESC);
    EXCEPTION
       WHEN V_VALIDATION_ERROR THEN
            DBMS_OUTPUT.put_line('Validation Error ['||V_RESPONSE_ID||'] : '||V_RESPONSE_DESC);
            ROLLBACK;
       WHEN OTHERS THEN
            V_RESPONSE_ID := 2;
            V_RESPONSE_DESC := 'For the record with code '||V_ROLLOUT_CODE||' : '||SUBSTR(SQLERRM, 1, 200);
            DBMS_OUTPUT.put_line('Procedure Error ['||V_RESPONSE_ID||'] : '||V_RESPONSE_DESC);
            ROLLBACK;
            RAISE;
    END SET_INV;
    Lors d'une execution de cette procedure a partir d'une application externe, les utilisateurs obtiennent neanmoins l'erreur suivante :
    XXXXX.XXXXXX.SET_INV
    Exception: ORA-06550: line 1, column 42:
    PLS-00103: Encountered the symbol "=" when expecting one of the following:
       . ( * @ % & = - + ; < / > at in is mod not rem
       <an exponent (**)> <> or != or ~= >= <= <> and or like
       between || indicator
    ORA-06550: line 1, column 216:
    PLS-00103: Encountered the symbol ";" when expecting one of the following:
       . ( , * % & = - + < / > at in is mod not rem
       <an exponent (**)> <> or != or ~= >= <= <> and or like alter
       between || invalidate cascade
    Je ne sais pas encore exactement si l'application externe qui appelle cette procedure est sur plateforme .NET ou J2EE. Sauriez-vous pourquoi un appel de l'exterieur pourrait fausser le fonctionnement de la procedure et renvoyer l'erreur ci-dessus ?
    Merci d'avance !
    Avatar de orafrance
    Janvier 2004
    YEAR et MONTH sont des mots réservés (cf v$reserved_words), tu ne peux pas nommer des colonnes comme ça ou alors il faut les mettre entre guillement.
    NOTEPAD++ et la coloration syntaxique c'est très pratique pour retrouver ces erreurs
    Avril 2008
    Hmn ...
    YEAR et MONTH sont des mots reserves c'est vrai mais ca ne pose aucun probleme de nommer des colonnes avec ces mots. Le probleme ne vient pas de la.
    Je me demande si au niveau de l'entree des parametres via l'application externe, un probleme de cast implicite/format de base d'une chane de caractere peut entrer en jeu et declencher l'erreur ? (par exemple ajout implicite d'un signe de fin de ligne ...)
    Avatar de orafrance
    Janvier 2004
    Citation Envoyé par manpe Voir le message
    Hmn ...
    T'as essayé de les mettre en guillemets avant d'être aussi affirmatif
    A part ça, le forum n'est pas là pour faire le débuggage à ta place... supprime des lignes pour localiser le problème
    Avril 2008
    Je suis affirmatif (sans offense) pke je travaille avec des colonnes year et month depuis longtemps sans jamais avoir rencontre de probleme.
    La procedure fonctionne et n'a pas besoin d'etre debugguee. Comme je l'ai dit au depart , ma question est la suivante : existe-t-il des incompatibilite entre types primitifs par exemple java/oracle qui pourrait poser probleme au niveau de l'execution de la procedure a partir d'une application externe ? Je m'excuse du "flou" de ma question mais je n'ai pas acces ni au code ni a l'architecture de l'application executant la procedure)
    Avatar de orafrance
    Janvier 2004
    l'erreur que tu montres n'a rien à voir avec des types... donc oui, il peut y avoir des incompatibilités mais c'est pas le problème visiblement.
  1. Réponses: 0
    Dernier message: 13/07/2011, 13h57
  2. ORA-06550 lors d'un export Oracle 10g
    Par titi04 dans le forum Import/Export
    Dernier message: 08/10/2009, 13h31
  3. Migration 11g: ora-01000 lors de l'appel à DBMS_STATS
    Par farenheiit dans le forum Administration
    Dernier message: 09/07/2009, 10h34
  4. Question sur la déclaration d'un paramètre lors de l'appel du procédure stockée
    Par th.garcia dans le forum Interfaces de programmation
    Dernier message: 26/06/2009, 13h58
  5. Erreur sur un window.open lors du deuxième appel
    Par Mike_69 dans le forum Général JavaScript
    Dernier message: 02/04/2007, 09h40
