Rebuild Index
    Mai 2005
    Par défaut Rebuild Index
    Oracle 9i, AIX 5
    Après un move d'une table, lorsque je regarde dans les vues user_indexes et user_objects, je n'ai pas les même résultats :
    select index_name, tablespace_name, status from user_indexes where index_name='CUST_INDEX'
    INDEX_NAME,TABLESPACE_NAME,STATUS
    CUST_INDEX,TOOLS,UNUSABLE
    select object_name, object_type, status from user_objects where object_name='CUST_INDEX'
    OBJECT_NAME,OBJECT_TYPE,STATUS
    CUST_INDEX,INDEX,VALID
    L'objet 'index' semble valide alors que l'index est unusable
    Ais-je fait une boulette où est-ce quelque chose de connu ou est-ce bien anormal ?
    Merci pour votre réponse.
    PS : je sais que l'objet passe bien en unusable, mais c'est la valeur dans user_objects qui m'interroge ...
    Avatar de bouyao
    Janvier 2005
    Sur metalink
    The information in this article applies to:
    Oracle Server - Enterprise Edition - Version: 8.1.7.4 to 10.1.0.2
    Information in this document applies to any platform.
    Goal
    An index rebuilt either Online or Offline.
    Online Index Rebuild Features:
    + ALTER INDEX REBUILD ONLINE;
    + DMLs are allowed on the base table
    + It is comparatively Slow
    + Base table is referred for the new index
    + Base table is locked in shared mode and DDLs are not possible
    + Intermediate table stores the data changes in the base table, during the index rebuild to update the new index later
    Offline Index Rebuild Features:
    + ALTER INDEX REBUILD; (Default)
    + Does not refer the base table and the base table is exclusively locked
    + New index is created from the old index
    + No DML and DDL possible on the base table
    + Comparatively faster
    So, the base table is not referred for data when the index is rebuilt offline.
    This article describes this behavior with test cases and depicts a few scenarios when this is violated.
    Fix
    The test cases considers BTree index being rebuilt online/offline. The results are also same for Bitmap index. For analysis 10046 trace is generated to see if the statement refers the base table for data access. Trace Analyzer is also used to get a clear picture (Note: 224270.1).
    Base Table: T5
    Index Name: IND5
    Test - 1:
    Index is rebuilt OFFLINE
    alter session set events '10046 trace name context forever, level 12';
    alter index ind5 rebuild;
    alter session set events '10046 trace name context off';
    The trace analyzer output has the following WAIT details:
    + There is no block access from T5
    + IND5 blocks are accessed
    Test - 2:
    Index is rebuilt ONLINE:
    alter index ind5 rebuild online;
    + T5 blocks are accessed
    CONCLUSION
    When an index is rebuilt offline there is no FTS on the base table. When index is rebuilt online all the blocks from the base table are accessed.
    These conclusions are when we donot make an scenario when the index is unusable and then there
    is data load to the base table, and finally the index is rebuilt. Lets see test results from different scenarios when index is unusable.
    Test - 3
    Index is made unusable. Nodata is load to the base table.Index is rebuilt.
    SQL> ALTER INDEX ind5 UNUSABLE;
    Index altered.
    SQL> select index_name,status from user_indexes where index_name = 'IND5';
    INDEX_NAME STATUS
    IND5 UNUSABLE
    ALTER INDEX ind5 REBUILD;
    INDEX_NAME STATUS
    IND5 VALID
    Test - 4:
    Index is made unusable. Data is load to the base table.Then Index is rebuilt OFFLINE.
    Index altered.
    SQL> insert into t5 values(55555,'EEEEE');
    ERROR at line 1:
    ORA-01502: index 'BH.IND5' or partition of such index is in unusable state
    Test - 5:
    Now lets do some dataload using sqlldr.
    Index made unusable / sqlldr dataload to table / rebuild index
    load data
    infile *
    append
    into table t5(
    a position(1:5),
    b position(6:10))
    BEGINDATA
    55555EEEEE
    44444DDDDD
    66666FFFFF
    sqlldr userid=bh/sh control=test.ctl log=test.log bad=test.bad discard=test.discard skip=0
    (skip_unusable_indexes = false -- DEFAULT)
    all the three rows are listed in test.bad. NO DATA LOADED
    Test - 6:
    Index made unusable / sqlldr dataload to table with skip_unusable_indexes=true / rebuild index
    SQL> select count(*) from t5;
    COUNT(*)
    0
    SQL> create index ind5 on t5(b) storage(initial 1K next 1K maxextents unlimited pctincrease 0);
    Index created.
    SQL> select block_id,blocks from dba_extents where segment_name = 'T5';
    BLOCK_ID BLOCKS
    5897 130
    SQL> select block_id,blocks from dba_extents where segment_name = 'IND5';
    BLOCK_ID BLOCKS
    4682 2
    SQL> alter index ind5 unusable;
    Index altered.
    sqlldr userid=bh/sh control=test.ctl log=test.log bad=test.bad discard=test.discard skip_unusable_indexes=true
    COUNT(*)
    154400
    DATA GETS LOADED to table. Data doesnot go to index.
    BLOCK_ID BLOCKS
    5897 130
    4684 130
    4814 195
    BLOCK_ID BLOCKS
    4682 2
    No new blocks gets added to index.
    SQL> select status,index_type from user_indexes where index_name = 'IND5';
    STATUS
    UNUSABLE
    SQL> select count(*) from dba_extents where segment_name = 'IND5';
    COUNT(*)
    STATUS
    VALID
    From trace analyzer o/p, there is trace that T5 has been referred.
    + < The base table blocks are accessed >
    CONCLUSION
    As documentation says, while REBUILDing an index OFFLINE, the base table is not referred. But there are situations where the base table is accessed similar to an index create, they are:
    + index is made "unusable"
    + data is loaded with sql loader with skip_unusable_indexes = TRUE
    + index is REBUILD OFFLINE
    Documentation is not in agreement in this particular case.
    There could be one more scenarion I guess:
    + move a table to a different tablespace
    + index becomes unusable
    + we rebuild the index
    Basically, when an index is made "unusable", it is normally meant that it will not be used at all (that is drop later) or it has to be drop/create. Here the index being unusable takes more priority than the Offline rebuild of it. An unusable index has to refer the base table while rebuilding.
    Expert Oracle confirmé
    Consultant Big Data
    Mars 2003
    Activité : Consultant Big Data
    Si tu déplaces une table via la commande ALTER TABLE ... MOVE, il est normal que les index soient UNUSABLE.
    Car en déplaçant la table, le ROWID de chaque ligne de la table change, et comme l'index contient le ROWID, l'index n'est alors plus utilisable.
    Pour remédirer à cela, tu dois reconstruire l'index, via un ALTER INDEX ... REBUILD.
    Avatar de LeoAnderson
    Septembre 2004
    La question du monsieur est "pourquoi dans user_indexes il apparait INVALID alors que dans user_objects il apparait VALID ?" pas "pourquoi mon index est invalide" ! ;-)
    A mon avis, dans user_objects, l'index est valide dans le sens où sa définition n'est pas incohérente (la table et les colonnes existent toujours)
    Dans user_index, le move a perturbé l'organisation "interne" de l'index (cf note de bouyao) et n'est plus utilisable.
    j'espère avoir été clair ...
    Avatar de orafrance
    Janvier 2004
    Je suis d'accord avec Leo, l'index est correct, pas de violation d'unicité ou de colonne "bizarreé", en revanche comme le dit rouarg, les ROWID on changeait donc l'index est inutilisable.
    Elémentaire mon cher Watson
    Avatar de bouyao
    Janvier 2005
    Tout simplement la table est vide.
    Avatar de orafrance
    Janvier 2004
    donc les ROWID on changeait... il n'y en a plus dans la table
    Mai 2005
    Merci pour vos réponses
    La table n'est pas vide.
    Donc si je résume :
    user_indexes ==> l'index est-il fonctionnellement viable ?
    user_objects ==> l'index est-il structurellement viable ?
    C'est çà ?
    Avatar de bouyao
    Janvier 2005
    Est ce que la table est partitionné ?
    Mai 2005
    Elle n'est pas non plus partitionnée.
    C'est une table tout ce qu'il y a de plus basique avec 3 champs et un index, avec 3 enregistrements.
  1. rebuild index ou pas :(
    Par adetag dans le forum Administration
    Dernier message: 09/03/2009, 16h27
  2. Rebuild index automatiquement
    Par scolopendra dans le forum Administration
    Dernier message: 22/10/2008, 14h46
  3. Pb rebuild index par procedure
    Par couse1 dans le forum Administration
    Dernier message: 01/08/2007, 09h53
  4. [Oracle 10G]Rebuild index
    Par seal dans le forum Administration
    Dernier message: 04/05/2007, 21h19
  5. [Ora 9.2] Rebuild index et move tablespace
    Par scornille dans le forum Oracle
    Dernier message: 03/02/2006, 00h41
