1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245
* MenuGraph.java
* Created on 21 juillet 2008, 14:57
package monpaquet;
import java.sql.Connection;
import java.sql.DriverManager;
import java.sql.SQLException;
* @author Amé
public class MenuGraph extends javax.swing.JFrame {
/** Creates new form MenuGraph */
public MenuGraph() {
initComponents();
/** This method is called from within the constructor to
* initialize the form.
* WARNING: Do NOT modify this code. The content of this method is
* always regenerated by the Form Editor.
@SuppressWarnings("unchecked")
// <editor-fold defaultstate="collapsed" desc="Generated Code">
private void initComponents() {
jProgressBar1 = new javax.swing.JProgressBar();
BEnvoyer = new javax.swing.JButton();
BRecevoir = new javax.swing.JButton();
BExit = new javax.swing.JButton();
VarEmail = new javax.swing.JTextField();
VarNom = new javax.swing.JTextField();
VarPrenom = new javax.swing.JTextField();
jLabel1 = new javax.swing.JLabel();
jLabel2 = new javax.swing.JLabel();
jLabel3 = new javax.swing.JLabel();
jLabel4 = new javax.swing.JLabel();
Var2 = new javax.swing.JTextField();
jLabel5 = new javax.swing.JLabel();
Var1 = new javax.swing.JTextField();
jLabel6 = new javax.swing.JLabel();
Var3 = new javax.swing.JTextField();
setDefaultCloseOperation(javax.swing.WindowConstants.EXIT_ON_CLOSE);
BEnvoyer.setText("Envoyer");
BEnvoyer.addActionListener(new java.awt.event.ActionListener() {
public void actionPerformed(java.awt.event.ActionEvent evt) {
BEnvoyerActionPerformed(evt);
BRecevoir.setText("Recevoir");
BRecevoir.addActionListener(new java.awt.event.ActionListener() {
BRecevoirActionPerformed(evt);
BExit.setText("Exit");
BExit.addActionListener(new java.awt.event.ActionListener() {
BExitActionPerformed(evt);
jLabel1.setText("Email");
jLabel2.setText("Nom");
jLabel3.setText("Prénom");
jLabel4.setText("NomRecu");
jLabel5.setText("EmailReçu");
jLabel6.setText("Prénomrecu");
javax.swing.GroupLayout layout = new javax.swing.GroupLayout(getContentPane());
getContentPane().setLayout(layout);
layout.setHorizontalGroup(
layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
.addGroup(layout.createSequentialGroup()
.addGroup(layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
.addGap(150, 150, 150)
.addComponent(BEnvoyer)
.addPreferredGap(javax.swing.LayoutStyle.ComponentPlacement.UNRELATED)
.addComponent(BRecevoir)
.addPreferredGap(javax.swing.LayoutStyle.ComponentPlacement.RELATED)
.addComponent(BExit, javax.swing.GroupLayout.PREFERRED_SIZE, 58, javax.swing.GroupLayout.PREFERRED_SIZE))
.addGap(17, 17, 17)
.addGroup(layout.createParallelGroup(javax.swing.GroupLayout.Alignment.TRAILING, false)
.addComponent(jLabel2)
.addPreferredGap(javax.swing.LayoutStyle.ComponentPlacement.RELATED, javax.swing.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE)
.addComponent(VarNom, javax.swing.GroupLayout.PREFERRED_SIZE, 104, javax.swing.GroupLayout.PREFERRED_SIZE))
.addComponent(jLabel1)
.addComponent(VarEmail, javax.swing.GroupLayout.PREFERRED_SIZE, 104, javax.swing.GroupLayout.PREFERRED_SIZE))
.addComponent(jLabel3)
.addGap(18, 18, 18)
.addComponent(VarPrenom, javax.swing.GroupLayout.PREFERRED_SIZE, 104, javax.swing.GroupLayout.PREFERRED_SIZE)))))
.addContainerGap(49, Short.MAX_VALUE))
.addGroup(javax.swing.GroupLayout.Alignment.TRAILING, layout.createSequentialGroup()
.addContainerGap(215, Short.MAX_VALUE)
.addComponent(jLabel4)
.addComponent(Var2, javax.swing.GroupLayout.PREFERRED_SIZE, 104, javax.swing.GroupLayout.PREFERRED_SIZE))
.addComponent(jLabel5)
.addComponent(Var1, javax.swing.GroupLayout.PREFERRED_SIZE, 104, javax.swing.GroupLayout.PREFERRED_SIZE))
.addComponent(jLabel6)
.addComponent(Var3, javax.swing.GroupLayout.PREFERRED_SIZE, 104, javax.swing.GroupLayout.PREFERRED_SIZE)))
.addGap(41, 41, 41))
layout.setVerticalGroup(
.addGap(21, 21, 21)
.addGroup(layout.createParallelGroup(javax.swing.GroupLayout.Alignment.BASELINE)
.addComponent(VarEmail, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(jLabel1))
.addComponent(VarNom, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(jLabel2))
.addComponent(VarPrenom, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(jLabel3))
.addGap(50, 50, 50)
.addComponent(Var1, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(jLabel5))
.addComponent(Var2, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(jLabel4))
.addComponent(Var3, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(jLabel6))
.addPreferredGap(javax.swing.LayoutStyle.ComponentPlacement.RELATED, 41, Short.MAX_VALUE)
.addComponent(BExit))
.addContainerGap())
pack();
}// </editor-fold>
private void BEnvoyerActionPerformed(java.awt.event.ActionEvent evt) {
// Verification des saisies et affichage dans la zone Vérif
String chaine1, chaine2, chaine3, chaine4;
chaine1 = VarNom.getText();
chaine2 = VarPrenom.getText();
chaine3 = VarEmail.getText();
// Var1.setText(chaine1);
// Var2.setText(chaine2);
// Var3.setText(chaine3);
// test d'accès à la base
Client mon_client = new Client();
try {
Class.forName("com.microsoft.sqlserver.jdbc.SQLServerDriver");
String connectionUrl = "jdbc:sqlserver://192.168.1.100:1433;" +
"databaseName=DALAU;user=sa;password=adminpw;";
Connection con = DriverManager.getConnection(connectionUrl);
/*mon_client.setNom(chaine1);
mon_client.setPrenom(chaine2);
mon_client.setEmail(chaine3); */
} catch (SQLException e) {
System.out.println("SQL Exception: "+ e.toString());
} catch (ClassNotFoundException cE) {
System.out.println("Class Not Found Exception: "+ cE.toString());
// TODO add your handling code here:
private void BExitActionPerformed(java.awt.event.ActionEvent evt) {
System.exit(0);// TODO add your handling code here:
private void BRecevoirActionPerformed(java.awt.event.ActionEvent evt) {
* @param args the command line arguments
public static void main(String args[]) {
java.awt.EventQueue.invokeLater(new Runnable() {
public void run() {
new MenuGraph().setVisible(true);
// Variables declaration - do not modify
private javax.swing.JButton BEnvoyer;
private javax.swing.JButton BExit;
private javax.swing.JButton BRecevoir;
private javax.swing.JTextField Var1;
private javax.swing.JTextField Var2;
private javax.swing.JTextField Var3;
private javax.swing.JTextField VarEmail;
private javax.swing.JTextField VarNom;
private javax.swing.JTextField VarPrenom;
private javax.swing.JLabel jLabel1;
private javax.swing.JLabel jLabel2;
private javax.swing.JLabel jLabel3;
private javax.swing.JLabel jLabel4;
private javax.swing.JLabel jLabel5;
private javax.swing.JLabel jLabel6;
private javax.swing.JProgressBar jProgressBar1;
// End of variables declaration
