1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183
<web-app xmlns="http://java.sun.com/xml/ns/j2ee" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="2.4" xsi:schemaLocation="http://java.sun.com/xml/ns/j2ee http://java.sun.com/xml/ns/j2ee/web-app_2_4.xsd">
<display-name>CiwiShop</display-name>
<context-param>
<param-name>org.richfaces.SKIN</param-name>
<param-value>blueSky</param-value>
</context-param>
<context-param>
<description>State saving method: "client" or "server" (= default)
See JSF Specification 2.5.2</description>
<param-name>javax.faces.STATE_SAVING_METHOD</param-name>
<param-value>server</param-value>
</context-param>
<context-param>
<description>This parameter tells MyFaces if javascript code should be allowed in the
rendered HTML output.
If javascript is allowed, command_link anchors will have javascript code
that submits the corresponding form.
If javascript is not allowed, the state saving info and nested parameters
will be added as url parameters.
Default: "true"</description>
<param-name>org.apache.myfaces.ALLOW_JAVASCRIPT</param-name>
<param-value>true</param-value>
</context-param>
<context-param>
Default: "false"
Setting this param to true should be combined with STATE_SAVING_METHOD "server" for
best results.
This is an EXPERIMENTAL feature. You also have to enable the detector filter/filter mapping below to get
JavaScript detection working.</description>
<param-name>org.apache.myfaces.DETECT_JAVASCRIPT</param-name>
<param-value>false</param-value>
</context-param>
<context-param>
<description>If true, rendered HTML code will be formatted, so that it is "human readable".
i.e. additional line separators and whitespace will be written, that do not
influence the HTML code.
<param-name>org.apache.myfaces.PRETTY_HTML</param-name>
</context-param>
<context-param>
<description>If true, a javascript function will be rendered that is able to restore the
former vertical scroll on every request. Convenient feature if you have pages
with long lists and you do not want the browser page to always jump to the top
if you trigger a link or button action that stays on the same page.
Default: "false"</description>
<param-name>org.apache.myfaces.AUTO_SCROLL</param-name>
</context-param>
<context-param>
<param-name>javax.faces.CONFIG_FILES</param-name>
<param-value>/WEB-INF/faces-config.xml</param-value>
</context-param>
<context-param>
<param-name>javax.faces.DEFAULT_SUFFIX</param-name>
<param-value>.jsp</param-value>
</context-param>
<filter>
<display-name>RichFaces Filter</display-name>
<filter-name>richfaces</filter-name>
<filter-class>org.ajax4jsf.Filter</filter-class>
</filter>
<!-- Extensions Filter
<filter>
<filter-name>MyFacesExtensionsFilter</filter-name>
<filter-class>org.apache.myfaces.webapp.filter.ExtensionsFilter</filter-class>
<init-param>
<description>Set the size limit for uploaded files.
Format: 10 - 10 bytes
10k - 10 KB
10m - 10 MB
1g - 1 GB</description>
<param-name>maxFileSize</param-name>
<param-value>20m</param-value>
</init-param>
</filter> -->
<!-- Ajax4JSF filter as given in the 1.1.1 README file -->
<filter>
<display-name>Ajax4jsf Filter</display-name>
<filter-name>ajax4jsf</filter-name>
</filter>
<filter>
<filter-name>trinidad</filter-name>
<filter-class>org.apache.myfaces.trinidad.webapp.TrinidadFilter</filter-class>
</filter>
<filter-mapping>
<servlet-name>Faces Servlet</servlet-name>
<dispatcher>REQUEST</dispatcher>
<dispatcher>FORWARD</dispatcher>
<dispatcher>INCLUDE</dispatcher>
</filter-mapping>
<!--<filter-mapping>
servlet-name must match the name of your javax.faces.webapp.FacesServlet entry
</filter-mapping>-->
<!-- extension mapping for serving page-independent resources (javascript, stylesheets, images, etc.)
<filter-mapping>
<url-pattern>/faces/myFacesExtensionResource/*</url-pattern>
</filter-mapping>
<filter-mapping>
<url-pattern>*.jsp</url-pattern>
</filter-mapping> -->
<filter-mapping>
<url-pattern>/*</url-pattern>
</filter-mapping>
<filter-mapping>
<!-- This assumes that the FacesServlet has been registered -->
<!-- under the name "faces" -->
<servlet-name>faces</servlet-name>
</filter-mapping>
<!-- Listener, that does all the startup work (configuration, init). -->
<listener>
<listener-class>org.apache.myfaces.trinidadinternal.webapp.TrinidadListenerImpl</listener-class>
</listener>
<!-- Faces Servlet -->
<servlet>
<servlet-class>javax.faces.webapp.FacesServlet</servlet-class>
<load-on-startup>1</load-on-startup>
</servlet>
<servlet>
<servlet-name>resources</servlet-name>
<servlet-class>org.apache.myfaces.trinidad.webapp.ResourceServlet</servlet-class>
</servlet>
<servlet>
<servlet-name>Faces Servlet_tmp</servlet-name>
<load-on-startup>0</load-on-startup>
</servlet>
<!-- This cannot be configured currently -->
<servlet-mapping>
<url-pattern>/adf/*</url-pattern>
</servlet-mapping>
<servlet-mapping>
<url-pattern>*.jsf</url-pattern>
</servlet-mapping>
<servlet-mapping>
<url-pattern>/faces/*</url-pattern>
</servlet-mapping>
<servlet-mapping>
<url-pattern>*.faces</url-pattern>
</servlet-mapping>
<login-config>
<auth-method>BASIC</auth-method>
</login-config>
<!--Tomcat 5 Workaround: Listener used to initialize JSF on startup-->
<!--Remove comment tags to enable listener.
<listener>
<listener-class>com.sun.faces.config.ConfigureListener</listener-class>
</listener>
<!--Tomcat 5 Workaround: Listener implementation to handle web application lifecycle event-->
<listener>
<listener-class>com.sun.faces.application.WebappLifecycleListener</listener-class>
</listener>
</web-app> |
