Bonjour tout le monde,
Je travaille avec jdk 1.5 et xalan pour lancer ma transformation xsl.
J'utilise exslt pour manipuler les dates
21 File xmlFile = new File("c:/source.xml"); File xsltFile = new File("c:/xsl.xsl"); File htmlFile = new File("c:/result.html"); Source xmlSource = new StreamSource(xmlFile); Source xsltSource = new StreamSource(xsltFile); Result htmlResult = new StreamResult(htmlFile); TransformerFactory transFact = TransformerFactory.newInstance(); Transformer trans; try { trans = transFact.newTransformer(xsltSource); try { trans.transform(xmlSource, htmlResult); } catch (TransformerException e) { // TODO Auto-generated catch block e.printStackTrace(); } } catch (TransformerConfigurationException e) { // TODO Auto-generated catch block e.printStackTrace(); }
5 <xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:date="http://exslt.org/dates-and-times" extension-element-prefixes="date">Quand je lance ma transformation, j'ai l'exception suivante:
4 <xsl:variable name="now" select="date:date-time()"/> <xsl:variable name="dateRecrutement" select="//EmployerOrg[1/PositionHistory/StartDate/text()"/> <h2><xsl:value-of select="date:difference($now, $dateRecrutement)"/></h2>
Quelqu'un a une solution?
39 ERREUR : 'La méthode externe 'com.sun.org.apache.xalan.internal.lib.ExsltDatetime.difference' est introuvable (doit être publique).' ERREUR BLOQUANTE : 'Impossible de compiler la feuille de style' javax.xml.transform.TransformerConfigurationException: Impossible de compiler la feuille de style at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerFactoryImpl.newTemplates(TransformerFactoryImpl.java:829) at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerFactoryImpl.newTransformer(TransformerFactoryImpl.java:623) at com.cv.services.CvService.transformXsl(CvService.java:321) at com.cv.services.CvService.creerCv(CvService.java:308) at com.cv.controller.CvController.generateCv(CvController.java:518) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:585) at com.sun.faces.el.MethodBindingImpl.invoke(MethodBindingImpl.java:126) at org.apache.myfaces.application.ActionListenerImpl.processAction(ActionListenerImpl.java:61) at javax.faces.component.UICommand.broadcast(UICommand.java:312) at javax.faces.component.UIViewRoot.broadcastEvents(UIViewRoot.java:267) at javax.faces.component.UIViewRoot.processApplication(UIViewRoot.java:381) at com.sun.faces.lifecycle.InvokeApplicationPhase.execute(InvokeApplicationPhase.java:75) at com.sun.faces.lifecycle.LifecycleImpl.phase(LifecycleImpl.java:200) at com.sun.faces.lifecycle.LifecycleImpl.execute(LifecycleImpl.java:90) at javax.faces.webapp.FacesServlet.service(FacesServlet.java:197) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:252) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:173) at org.apache.myfaces.webapp.filter.ExtensionsFilter.doFilter(ExtensionsFilter.java:147) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:202) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:173) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:178) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:126) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:105) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:107) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:148) at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:869) at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:664) at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:527) at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:80) at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:684) at java.lang.Thread.run(Thread.java:595)
