Persistance des données Java Discussion :
[debutant] Class [org.apache.derby.jdbc.ClientDriver] not found.
    Membre du Club
    Mars 2008
    Par défaut [debutant] Class [org.apache.derby.jdbc.ClientDriver] not found.
    a chaque fois que je lance l'application j'ai cette erreur
    run:
    [TopLink Info]: 2009.01.07 11:42:13.921--ServerSession(12115695)--TopLink, version: Oracle TopLink Essentials - 2.0.1 (Build b09d-fcs (12/06/2007))
    Exception in thread "main" Local Exception Stack:
    Exception [TOPLINK-4003] (Oracle TopLink Essentials - 2.0.1 (Build b09d-fcs (12/06/2007))): oracle.toplink.essentials.exceptions.DatabaseException
    Exception Description: Configuration error.  Class [org.apache.derby.jdbc.ClientDriver] not found.
            at oracle.toplink.essentials.exceptions.DatabaseException.configurationErrorClassNotFound(DatabaseException.java:101)
            at oracle.toplink.essentials.sessions.DefaultConnector.loadDriver(DefaultConnector.java:183)
            at oracle.toplink.essentials.sessions.DefaultConnector.connect(DefaultConnector.java:98)
            at oracle.toplink.essentials.sessions.DatasourceLogin.connectToDatasource(DatasourceLogin.java:184)
            at oracle.toplink.essentials.internal.sessions.DatabaseSessionImpl.loginAndDetectDatasource(DatabaseSessionImpl.java:582)
            at oracle.toplink.essentials.ejb.cmp3.EntityManagerFactoryProvider.login(EntityManagerFactoryProvider.java:280)
            at oracle.toplink.essentials.internal.ejb.cmp3.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:229)
            at oracle.toplink.essentials.internal.ejb.cmp3.base.EntityManagerFactoryImpl.getServerSession(EntityManagerFactoryImpl.java:93)
            at oracle.toplink.essentials.internal.ejb.cmp3.base.EntityManagerFactoryImpl.createEntityManagerImpl(EntityManagerFactoryImpl.java:126)
            at oracle.toplink.essentials.internal.ejb.cmp3.base.EntityManagerFactoryImpl.createEntityManagerImpl(EntityManagerFactoryImpl.java:120)
            at oracle.toplink.essentials.internal.ejb.cmp3.EntityManagerFactoryImpl.createEntityManager(EntityManagerFactoryImpl.java:91)
            at gestionpersonne.PersonneJpaController.getEntityManager(PersonneJpaController.java:28)
            at gestionpersonne.PersonneJpaController.create(PersonneJpaController.java:34)
            at gestionpersonne.Main.main(Main.java:20)
    Java Result: 1
    BUILD SUCCESSFUL (total time: 2 seconds)
    persistence.xml :
    <persistence version="1.0" xmlns="http://java.sun.com/xml/ns/persistence" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://java.sun.com/xml/ns/persistence http://java.sun.com/xml/ns/persistence/persistence_1_0.xsd">
      <persistence-unit name="gestionPersonnePU" transaction-type="RESOURCE_LOCAL">
        <provider>oracle.toplink.essentials.PersistenceProvider</provider>
        <class>gestionpersonne.Personne</class>
        <properties>
          <property name="toplink.jdbc.user" value="linuxien"/>
          <property name="toplink.jdbc.password" value="2020"/>
          <property name="toplink.jdbc.url" value="jdbc:derby://localhost:1527/GPersonne_db"/>
          <property name="toplink.jdbc.driver" value="org.apache.derby.jdbc.ClientDriver"/>
          <property name="toplink.ddl-generation" value="create-tables"/>
        </properties>
      </persistence-unit>
    </persistence>
    package gestionpersonne;
    import java.io.Serializable;
    import javax.persistence.Entity;
    import javax.persistence.GeneratedValue;
    import javax.persistence.GenerationType;
    import javax.persistence.Id;
     * @author linuxien
    @Entity
    public class Personne implements Serializable {
        private static final long serialVersionUID = 1L;
        @Id
        @GeneratedValue(strategy = GenerationType.AUTO)
        private Long id;
        private String nom;
        public Personne() {
        public Personne(String nom) {
            this.nom = nom;
         * Get the value of nom
         * @return the value of nom
        public String getNom() {
            return nom;
         * Set the value of nom
         * @param nom new value of nom
        public void setNom(String nom) {
            this.nom = nom;
        public Long getId() {
            return id;
        public void setId(Long id) {
            this.id = id;
        @Override
        public int hashCode() {
            int hash = 0;
            hash += (id != null ? id.hashCode() : 0);
            return hash;
        @Override
        public boolean equals(Object object) {
            // TODO: Warning - this method won't work in the case the id fields are not set
            if (!(object instanceof Personne)) {
                return false;
            Personne other = (Personne) object;
            if ((this.id == null && other.id != null) || (this.id != null && !this.id.equals(other.id))) {
                return false;
            return true;
        @Override
        public String toString() {
            return "gestionpersonne.Personne[id=" + id + "]";
    119
    120
    121
    122
    123
    124
    125
    126
    import gestionpersonne.exceptions.NonexistentEntityException;
    import java.util.List;
    import javax.persistence.EntityManager;
    import javax.persistence.EntityManagerFactory;
    import javax.persistence.Persistence;
    import javax.persistence.Query;
    import javax.persistence.EntityNotFoundException;
     * @author linxien
    public class PersonneJpaController {
        public PersonneJpaController() {
            emf = Persistence.createEntityManagerFactory("gestionPersonnePU");
        private EntityManagerFactory emf = null;
        public EntityManager getEntityManager() {
            return emf.createEntityManager();
        public void create(Personne personne) {
            EntityManager em = null;
            try {
                em = getEntityManager();
                em.getTransaction().begin();
                em.persist(personne);
                em.getTransaction().commit();
            } finally {
                if (em != null) {
                    em.close();
        public void edit(Personne personne) throws NonexistentEntityException, Exception {
            try {
                personne = em.merge(personne);
            } catch (Exception ex) {
                String msg = ex.getLocalizedMessage();
                if (msg == null || msg.length() == 0) {
                    Long id = personne.getId();
                    if (findPersonne(id) == null) {
                        throw new NonexistentEntityException("The personne with id " + id + " no longer exists.");
                throw ex;
            } finally {
                if (em != null) {
                    em.close();
        public void destroy(Long id) throws NonexistentEntityException {
            try {
                Personne personne;
                try {
                    personne = em.getReference(Personne.class, id);
                    personne.getId();
                } catch (EntityNotFoundException enfe) {
                    throw new NonexistentEntityException("The personne with id " + id + " no longer exists.", enfe);
                em.remove(personne);
            } finally {
                if (em != null) {
                    em.close();
        public List<Personne> findPersonneEntities() {
            return findPersonneEntities(true, -1, -1);
        public List<Personne> findPersonneEntities(int maxResults, int firstResult) {
            return findPersonneEntities(false, maxResults, firstResult);
        private List<Personne> findPersonneEntities(boolean all, int maxResults, int firstResult) {
            EntityManager em = getEntityManager();
            try {
                Query q = em.createQuery("select object(o) from Personne as o");
                if (!all) {
                    q.setMaxResults(maxResults);
                    q.setFirstResult(firstResult);
                return q.getResultList();
            } finally {
                em.close();
        public Personne findPersonne(Long id) {
            try {
                return em.find(Personne.class, id);
            } finally {
                em.close();
        public int getPersonneCount() {
            try {
                return ((Long) em.createQuery("select count(o) from Personne as o").getSingleResult()).intValue();
            } finally {
                em.close();
     * @author linuxien
    public class Main {
         * @param args the command line arguments
            Personne p = new Personne("alex");
            PersonneJpaController controller = new PersonneJpaController();
            controller.create(p);
    je precise que la lib toplink essentials est ajoutée
    et que ca se connecte avec netbeans
    merci d'avance
    Membre du Club
    Mars 2008
    résolu , après quelques recherches ...
    il fallait ajouter la librairie "Java DB driver"
    c'était évident quand on y pense
    Futur Membre du Club
    Juillet 2009
    slt j'ai eu le meme probleme pouvez vous plus preciser? parceque moi j'utilise mysql et non javaDB et netbeans 6.7 merci d'avance
  1. Réponses: 1
    Dernier message: 23/10/2013, 11h02
  2. Erreur "Could not resolve class: org.apache.wicket.Initializer"
    Par pcouas dans le forum Tests et Performance
    Dernier message: 16/10/2012, 06h34
  3. Réponses: 2
    Dernier message: 16/07/2010, 10h04
  4. [SAX] [Debutant]package org.apache.xml.serialize
    Par Ashgenesis dans le forum Format d'échange (XML, JSON...)
    Dernier message: 25/01/2008, 09h31
  5. Problème avec org.apache.log4j.jdbc.JDBCAppender
    Par dondano dans le forum Logging
    Dernier message: 17/08/2007, 21h54
