1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144
#include <gl/glew.h>
#include <GL/glut.h>
#include <GL/glext.h>
#include <iostream>
#include <fstream>
using namespace std;
GLuint fbID,texID;
// Affiche une teapot avec texID comme texture
void display()
GLfloat positionProperties[] = {-2.0f, -2.0f, 2.0f, 0.0f};
glLightfv( GL_LIGHT0, GL_POSITION, positionProperties);
glEnable(GL_LIGHTING);
glEnable(GL_DEPTH_TEST);
glViewport(0,0,512,512);
glClearColor(0,0,0,1);
glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT );
glMatrixMode(GL_PROJECTION);
glLoadIdentity();
gluPerspective(60.,512/(float)512,0.1,100.);
glTranslatef(0.,0.,-2.);
glMatrixMode(GL_MODELVIEW);
glLoadIdentity();
glEnable(GL_TEXTURE_2D);
glEnable(GL_LIGHT0);
glutSolidTeapot(0.5);
glDisable(GL_LIGHT0);
glDisable(GL_TEXTURE_2D);
glutSwapBuffers();
// display pour creer texID
void display2()
GLfloat positionProperties[] = {2.0f, 4.0f, -2.0f, 0.0f};
glClearColor(1,1,1,1);
glLoadIdentity();
glLoadIdentity();
void InitGLExtentions(void)
GLenum err = glewInit();
if (GLEW_OK != err)
char *s=(char*)glewGetErrorString(err);
cerr << s << endl;
void Init_FrameBufferObject()
// creation texture
glGenTextures(1, &texID);
glBindTexture(GL_TEXTURE_2D, texID);
glTexImage2D(GL_TEXTURE_2D,0,4,512,512,0,GL_RGBA,GL_FLOAT,NULL);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_LINEAR);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_LINEAR);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, GL_REPEAT);
glTexParameteri(GL_TEXTURE_3D, GL_TEXTURE_WRAP_T, GL_REPEAT);
// creation frame buffer
glGenFramebuffersEXT(1, &fbID);
glBindFramebufferEXT(GL_FRAMEBUFFER_EXT, fbID);
glFramebufferTexture2DEXT(GL_FRAMEBUFFER_EXT, GL_COLOR_ATTACHMENT0_EXT, GL_TEXTURE_2D, texID, 0);
display2();
GLenum status;
status = (GLenum) glCheckFramebufferStatusEXT(GL_FRAMEBUFFER_EXT);
switch(status) {
case GL_FRAMEBUFFER_COMPLETE_EXT:
printf("Frame Buffer Object Supported and complete \n");
break;
case GL_FRAMEBUFFER_UNSUPPORTED_EXT:
printf("Unsupported framebuffer format\n");
break;
case GL_FRAMEBUFFER_INCOMPLETE_MISSING_ATTACHMENT_EXT:
printf("Framebuffer incomplete, missing attachment\n");
break;
case GL_FRAMEBUFFER_INCOMPLETE_DUPLICATE_ATTACHMENT_EXT:
printf("Framebuffer incomplete, duplicate attachment\n");
break;
case GL_FRAMEBUFFER_INCOMPLETE_DIMENSIONS_EXT:
printf("Framebuffer incomplete, attached images must have same dimensions\n");
break;
case GL_FRAMEBUFFER_INCOMPLETE_FORMATS_EXT:
printf("Framebuffer incomplete, attached images must have same format\n");
break;
case GL_FRAMEBUFFER_INCOMPLETE_DRAW_BUFFER_EXT:
printf("Framebuffer incomplete, missing draw buffer\n");
break;
case GL_FRAMEBUFFER_INCOMPLETE_READ_BUFFER_EXT:
printf("Framebuffer incomplete, missing read buffer\n");
break;
default:
break;
glBindFramebufferEXT(GL_FRAMEBUFFER_EXT, 0);
void init_GLUT(int argc, char ** argv){
glutInit(&argc, argv);
glutInitDisplayMode( GLUT_DOUBLE | GLUT_RGBA |GLUT_DEPTH );
glutInitWindowSize(512,512 );
glutCreateWindow("test fbo");
printf("%s\n", glGetString(GL_VENDOR));
printf("%s\n", glGetString(GL_RENDERER));
printf("OpenGL %s\n", glGetString(GL_VERSION));
glutDisplayFunc(display);
int main(int argc,char **argv)
init_GLUT(argc,argv);
InitGLExtentions();
Init_FrameBufferObject();
glutMainLoop();
