1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217
const unsigned long FOURCC_DXT1 = 0x31545844; //(MAKEFOURCC('D','X','T','1'))
const unsigned long FOURCC_DXT3 = 0x33545844; //(MAKEFOURCC('D','X','T','3'))
const unsigned long FOURCC_DXT5 = 0x35545844; //(MAKEFOURCC('D','X','T','5'))
typedef struct
GLsizei width;
GLsizei height;
GLint components;
GLenum format;
int numMipMaps;
GLubyte *pixels;
DDS_IMAGE_DATA;
typedef struct
unsigned long dwSize;
unsigned long dwFlags;
unsigned long dwFourCC;
unsigned long dwRGBBitCount;
unsigned long dwRBitMask;
unsigned long dwGBitMask;
unsigned long dwBBitMask;
unsigned long dwABitMask;
DDS_PIXELFORMAT;
typedef struct
unsigned long dwHeight;
unsigned long dwWidth;
unsigned long dwLinearSize;
unsigned long dwDepth;
unsigned long dwMipMapCount;
unsigned long dwReserved1[11];
DDS_PIXELFORMAT ddpfPixelFormat;
unsigned long dwCaps1;
unsigned long dwCaps2;
unsigned long dwReserved2[3];
DDSURFACEDESC2;
PFNGLCOMPRESSEDTEXIMAGE2DARBPROC glCompressedTexImage2DARB;
DDS_IMAGE_DATA* loadDDSTextureFile( const char *filename )
DDS_IMAGE_DATA *pDDSImageData;
DDSURFACEDESC2 ddsd;
char filecode[4];
FILE *pFile;
int factor;
int bufferSize;
// Open the file
pFile = fopen( filename, "rb" );
if( pFile == NULL )
fclose( pFile );return 0;
// Verify the file is a true .dds file
fread( filecode, 1, 4, pFile );
if( strncmp( filecode, "DDS ", 4 ) != 0 )
fclose( pFile );
return 0;
// Get the surface descriptor
fread( &ddsd, sizeof(ddsd), 1, pFile );
pDDSImageData = (DDS_IMAGE_DATA*) malloc(sizeof(DDS_IMAGE_DATA));
memset( pDDSImageData, 0, sizeof(DDS_IMAGE_DATA) );
if( ddsd.ddpfPixelFormat.dwFourCC ==FOURCC_DXT1)
// DXT1's compression ratio is 8:1
pDDSImageData->format = GL_COMPRESSED_RGBA_S3TC_DXT1_EXT;
factor = 2;
pDDSImageData->components = 3;
else
if( ddsd.ddpfPixelFormat.dwFourCC ==FOURCC_DXT3)
// DXT3's compression ratio is 4:1
pDDSImageData->format = GL_COMPRESSED_RGBA_S3TC_DXT3_EXT;
factor = 4;
pDDSImageData->components = 4;
else
if( ddsd.ddpfPixelFormat.dwFourCC ==FOURCC_DXT5)
// DXT5's compression ratio is 4:1
pDDSImageData->format = GL_COMPRESSED_RGBA_S3TC_DXT5_EXT;
factor = 4;
else
return 0;
if( ddsd.dwLinearSize == 0 )
return 0;
if( ddsd.dwMipMapCount > 1 )
bufferSize = ddsd.dwLinearSize * factor;
else
bufferSize = ddsd.dwLinearSize;
pDDSImageData->pixels = (unsigned char*)malloc(bufferSize * sizeof(unsigned char));
fread( pDDSImageData->pixels, 1, bufferSize, pFile );
// Close the file
fclose( pFile );
pDDSImageData->width = ddsd.dwWidth;
pDDSImageData->height = ddsd.dwHeight;
pDDSImageData->numMipMaps = ddsd.dwMipMapCount;
return pDDSImageData;
int loadImage(int *l, char *file,int blur)
int f;
if (blur) f=GL_LINEAR; else f=GL_NEAREST;
pDDSImageData = loadDDSTextureFile(file);
if( pDDSImageData != NULL )
int nHeight = pDDSImageData->height;
int nWidth = pDDSImageData->width;
int nNumMipMaps = pDDSImageData->numMipMaps;
int nSize;
int nOffset = 0;
int i;
GLuint g_compressedTextureID = -1;
int nBlockSize;
if( pDDSImageData->format == GL_COMPRESSED_RGBA_S3TC_DXT1_EXT )
nBlockSize = 8;
else
nBlockSize = 16;
glGenTextures( 1, &g_compressedTextureID );
glBindTexture( GL_TEXTURE_2D, g_compressedTextureID );
*l = g_compressedTextureID;
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, GL_CLAMP);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_T, GL_CLAMP);
glTexParameteri( GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, f );
glTexParameteri( GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, f );
// Load the mip-map levels
unsigned int size = (((nWidth >> 2) + 3) & ~3) * (((nHeight >> 2) + 3) & ~3) * nBlockSize;
if (pDDSImageData->pixels != NULL)
glCompressedTexImage2DARB(GL_TEXTURE_2D, 0, pDDSImageData->format,
nWidth, nHeight, 0,
size,
pDDSImageData->pixels);
for(i = 0; i < nNumMipMaps; ++i )
if( nWidth == 0 ) nWidth = 1;
if( nHeight == 0 ) nHeight = 1;
nSize = ((nWidth+3)/4) * ((nHeight+3)/4) * nBlockSize;
glCompressedTexImage2DARB( GL_TEXTURE_2D,
i,
nWidth,
nHeight,
0,
nSize,
pDDSImageData->pixels + nOffset );
nOffset += nSize;
// Half the image size for the next mip-map level...
nWidth = (nWidth / 2);
nHeight = (nHeight / 2);
if( pDDSImageData->pixels != NULL )
free( pDDSImageData->pixels );
free( pDDSImageData );
return 1;
