J'ai un soucis de communication entre mon Projet Web(JSF) et mon Projet EJB. Lors de l'appel , coté web, d'une méthode coté EJB, l'objet passé en paramètre est apparemment "null".
Du côté EJB :
13 package com.ejb.IEJBSession; import java.util.List; import javax.ejb.Local; import javax.ejb.Remote; import com.ejb.entities.Wine; @Local public interface IWineSession { public void add(Wine wine); public void delete(Wine wine); public List<Wine> showListOfWines(); }
39 package com.ejb.EJBSession; import java.util.List; import javax.ejb.Stateless; import javax.persistence.EntityManager; import javax.persistence.PersistenceContext; import javax.persistence.Query; import com.ejb.IEJBSession.IWineSession; import com.ejb.entities.Wine; @Stateless public class WineSession implements IWineSession { @PersistenceContext(unitName="WineCaveEJB") private EntityManager em; public void add(Wine wine) { // TODO Auto-generated method stub em.persist(wine); } public void delete(Wine wine){ wine = em.merge(wine); em.remove(wine); } public List<Wine> showListOfWines() { // TODO Auto-generated method stub Query query = em.createNamedQuery("wineList"); List<Wine> wineList = query.getResultList(); return wineList; } }Coté client j'ai mon managed bean que je souhaite tester :
42 package com.ejb.entities; import java.io.Serializable; import javax.persistence.Entity; import javax.persistence.Id; import javax.persistence.NamedQueries; import javax.persistence.NamedQuery; @Entity @NamedQueries({ @NamedQuery(name ="wineList", query = "SELECT w from Wine w") }) public class Wine implements Serializable{ private static final long serialVersionUID = -4335426208843293310L; @Id private Integer id; private String name; public Wine(){}; public Wine(Integer id, String name){ this.id=id; this.name=name; } public Integer getId() { return id; } public void setId(Integer id) { this.id = id; } public String getName() { return name; } public void setName(String name) { this.name = name; } }
Quand j'exécute le projet, j'ai une erreur quand il appelle la methode wineSession.addWine(wine)
32 package com.bean; import javax.ejb.EJB; import com.ejb.EJBSession.WineSession; import com.ejb.IEJBSession.IWineSession; import com.ejb.entities.Wine; public class WineBean { @EJB private IWineSession wineSession; Wine currentWine; public WineBean(){setCurrentWine(new Wine());} public String addWine(){ Wine wine = new Wine(1,"Bordeaux"); wineSession.add(wine); System.out.println("Vin ajouté"); return "addedWine"; } public Wine getCurrentWine(){ return currentWine; } public void setCurrentWine(Wine wine){ this.currentWine=wine; } }
Voici l'erreur :
Apparemment l'objet Wine ne passe pas d'un projet à l'autre.java.lang.NullPointerException
at com.bean.WineBean.addWine(WineBean.java:40)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.apache.el.parser.AstValue.invoke(AstValue.java:170)
at org.apache.el.MethodExpressionImpl.invoke(MethodExpressionImpl.java:276)
at org.apache.jasper.el.JspMethodExpression.invoke(JspMethodExpression.java:68)
at javax.faces.component.MethodBindingMethodExpressionAdapter.invoke(MethodBindingMethodExpressionAdapter.java:88)
at com.sun.faces.application.ActionListenerImpl.processAction(ActionListenerImpl.java:102)
at javax.faces.component.UICommand.broadcast(UICommand.java:387)
at javax.faces.component.UIViewRoot.broadcastEvents(UIViewRoot.java:475)
at javax.faces.component.UIViewRoot.processApplication(UIViewRoot.java:756)
at com.sun.faces.lifecycle.InvokeApplicationPhase.execute(InvokeApplicationPhase.java:82)
at com.sun.faces.lifecycle.Phase.doPhase(Phase.java:100)
at com.sun.faces.lifecycle.LifecycleImpl.execute(LifecycleImpl.java:118)
at javax.faces.webapp.FacesServlet.service(FacesServlet.java:265)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFilter.java:96)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:235)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.jboss.web.tomcat.security.SecurityAssociationValve.invoke(SecurityAssociationValve.java:190)
at org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccContextValve.java:92)
at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.process(SecurityContextEstablishmentValve.java:126)
at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.invoke(SecurityContextEstablishmentValve.java:70)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.jboss.web.tomcat.service.jca.CachedConnectionValve.invoke(CachedConnectionValve.java:158)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:330)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:829)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:598)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
at java.lang.Thread.run(Unknown Source)
