1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236
GLuint fbo;
GLuint img;
GLuint txDepth;
int onlyFirst(const mesh_t *mesh,
face_t** boundary_face,
index_t* num_boundary_faces,real3 * origin, real3 * dir,real3 * up,unsigned int W,unsigned int H,float fovy,float near,float far)
GLuint program; /* notre program */
int use_shaders = 0;/* booleen indiquant si l'on utilise les shaders */
/* initialisation de la SDL en mode OpenGL */
if(SDL_Init(SDL_INIT_VIDEO) < 0)
exit(EXIT_FAILURE);
if(SDL_SetVideoMode(W, H, 32, SDL_OPENGL) == NULL)
ShutDown(EXIT_FAILURE);
/* nom de la fenetre */
SDL_WM_SetCaption("GLSL Shaders", NULL);
/* initialisation de glew */
glewInit();
// Now setup a texture to render to
glGenTextures(1, &img);
glBindTexture(GL_TEXTURE_2D, img);
glTexImage2D(GL_TEXTURE_2D, 0, GL_RGBA8, W, H, 0, GL_RGBA, GL_UNSIGNED_BYTE, NULL);
glTexParameterf(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, GL_REPEAT);
glTexParameterf(GL_TEXTURE_2D, GL_TEXTURE_WRAP_T, GL_REPEAT);
glTexParameterf(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER,GL_NEAREST);
glTexParameterf(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER,GL_NEAREST);
//setup a depth texture
glGenTextures(1, &txDepth);
glBindTexture(GL_TEXTURE_2D, txDepth);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, GL_REPEAT);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_T, GL_REPEAT);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_NEAREST);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_NEAREST);
glTexParameteri(GL_TEXTURE_2D, GL_DEPTH_TEXTURE_MODE, GL_INTENSITY);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_COMPARE_MODE, GL_COMPARE_R_TO_TEXTURE);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_COMPARE_FUNC, GL_LEQUAL);
//NULL means reserve texture memory, but texels are undefined
glTexImage2D(GL_TEXTURE_2D, 0, GL_DEPTH_COMPONENT32, W, H, 0, GL_DEPTH_COMPONENT, GL_UNSIGNED_BYTE, NULL);
glBindTexture( GL_TEXTURE_2D, 0 );
// Setup our FBO
glGenFramebuffersEXT(1, &fbo);
glBindFramebufferEXT(GL_FRAMEBUFFER_EXT, fbo);
// And attach it to the FBO so we can render to it
glFramebufferTexture2DEXT(GL_FRAMEBUFFER_EXT, GL_COLOR_ATTACHMENT0_EXT, GL_TEXTURE_2D, img, 0);
glFramebufferTexture2DEXT(GL_FRAMEBUFFER_EXT, GL_DEPTH_ATTACHMENT_EXT, GL_TEXTURE_2D, txDepth, 0);
GLubyte * data;
data = (GLubyte*)malloc(W*H*4*sizeof(GLubyte));
GLfloat * depthData;
depthData = (GLfloat*)malloc(W*H*sizeof(GLfloat));
int i;
GLenum status = glCheckFramebufferStatusEXT(GL_FRAMEBUFFER_EXT);
if(status != GL_FRAMEBUFFER_COMPLETE_EXT)
printf("status :%u",status);
exit(1);
glBindFramebufferEXT(GL_FRAMEBUFFER_EXT, 0);
// First we bind the FBO so we can render to it
// Save the view port and set it to the size of the texture
glEnable(GL_DEPTH_TEST);
glClearColor(255,255,255,255);
// S e t t h e p r o j e c t i o n t r a n s f o r m
glMatrixMode (GL_PROJECTION ) ;
glLoadIdentity ( ) ;
gluPerspective( fovy, (GLfloat)W/(GLfloat)H,near, far );
// S e t t h e camera o r i e n t a t i o n :
glMatrixMode (GL_MODELVIEW) ;
glLoadIdentity();
gluLookAt(origin->x, origin->y, origin->z,origin->x+dir->x,origin->y+dir->y,origin->z+dir->z, up->x, up->y, up->z);
glClear( GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT );
draw(mesh,
boundary_face,
num_boundary_faces);
//Recuperation des donées de la texture de rendu
/*glReadBuffer(GL_COLOR_ATTACHMENT0_EXT);
glReadPixels(0, 0, W, H,GL_RGBA,GL_UNSIGNED_BYTE,data); */
// the way i can get the pixel color before.
glGetTexImage(GL_TEXTURE_2D, 0, GL_RGBA8, GL_UNSIGNED_BYTE, data);
//the way not working
printf("BEGIN_RESULTS ONLY_FIRST \n");
for (i=0; i<(W*H*4); i=i+4)
printf("row =%u :",(i/4)/W);
printf("column =%u :",(i/4)%W);
printf("%u\n",indexConvert(data[i],data[i+1],data[i+2],data[i+3]));
glGetTexImage(GL_TEXTURE_2D, 0, GL_RED, GL_FLOAT, depthData);
printf("%f\n",depthData[i]);
printf("END_RESULTS ONLY_FIRST \n");
free(data);
free(depthData);
glDeleteFramebuffersEXT(1, &fbo);
glDeleteTextures(1,&img);
glDeleteTextures(1,&txDepth);
return EXIT_SUCCESS;
void colorConvert(unsigned int index)
GLubyte * pIdx = (GLubyte*)&index;
glColor4ub(pIdx[0],pIdx[1],0,0);
int indexConvert(GLushort r,GLushort g, GLubyte b, GLubyte a)
unsigned int idx;
GLubyte * pIdx=(GLubyte*)&idx;
pIdx[0]=r;
pIdx[1]=g;
pIdx[2]=b;
pIdx[3]=a;
return idx;
void draw(
const mesh_t *mesh,
index_t* num_boundary_faces)
glBegin(GL_QUADS);
glPushMatrix();
colorConvert(1001);
glVertex3f(-10, 0, 2 );
glVertex3f( 10,0, 2);
glVertex3f( 10,-10,2);
glVertex3f( -10,-10,2);
glPopMatrix();
glEnd();
